AD9547网络时钟与同步方案
AD9547是双路/四路输入网络时钟发生器/同步器,能为许多系统包括同步光网络(SONET/SDH)提供同步.输入基准频率从1 kHz 到750 MHz,频率监视1ppm,输出频率高达450MHz,主要应用在网络同步,OC-192的SONET/SDH时钟,无线基站,控制器,有线基础设备和数据通信. 本文介绍了AD9547主要特性, 功能方框图,详细方框图, 输出同步方框图和评估板电路图以及评估板材料清单.
AD9547: Dual/Quad Input Network Clock Generator/Synchronizer
The AD9547 provides synchronization for many systems, including synchronous optical networks (SONET/SDH). The AD9547 generates an output clock that is synchronized to one of two differential or four single-ended external input references. The digital PLL allows for reduction of input time jitter or phase noise associated with the external references. The AD9547 continuously generates a clean (low jitter), valid output clock, even when all references fail, by means of digitally controlled loop and holdover circuitry. The AD9547 operates over an industrial temperature range of −40℃ to +85℃.
AD9547主要特性:
Supports Stratum 2 stability in holdover mode
Supports reference switchover with phase build-out
Supports hitless reference switchover
Automatic/manual holdover and reference switchover
2 pairs of reference input pins, with each pair configurable as a single differential input or as 2 independent single-ended inputs
Input reference frequencies from 1 kHz to 750 MHz
Reference validation and frequency monitoring (1 ppm)
Programmable input reference switchover priority
30-bit programmable input reference divider
2 pairs of clock output pins, with each pair configurable as a single differential LVDS/LVPECL output or as 2 single-ended CMOS outputs
Output frequencies up to 450 MHz
20-bit integer and 10-bit fractional programmable feedback divider
Programmable digital loop filter covering loop bandwidths from 0.001 Hz to 100 kHz
Optional low noise LC-VCO system clock multiplier
Optional crystal resonator for system clock input
On-chip EEPROM to store multiple power-up profiles
Software controlled power-down
64-lead LFCSP package
AD9547应用:
Network synchronization
Cleanup of reference clock jitter
SONET/SDH clocks up to OC-192, including FEC
Stratum 2 holdover, jitter cleanup, and phase transient control
Stratum 3E and Stratum 3 reference clocks
Wireless base stations, controllers
Cable infrastructure
Data communications
图1.AD9547功能方框图
图2.AD9547详细方框图
图3.AD9547输出同步方框图
图4.AD9547评估板电路图(1)
图5.AD9547评估板电路图(2)
图6.AD9547评估板电路图(3)
