TD-SCDMA射频测试总结(三)
本期将简要介绍有关频谱方面的测试——占用带宽。
(1)测试环境:normal;参考TS34.122标准clauses G.2.1和G.2.2。
(2)测试频点:low range, mid range, high range ;参考TS34.122标准clauses G.2.4。
(1)设置手机在loopback的测试模式下并按照下表设置参数建立其和基站间的通话。
Parameter
Value/description
UL Reference measurement channel
12,2kbps, according to annex C.2.1
Uplink Power Control
SS level and signalling values such that UE transmits maximum power.
Data content
real life (sufficient irregular)
Parameter
Information data rate
12,2 kbps
RU's allocated
1TS (1*SF8) = 2RU/5ms
Midamble
144
Interleaving
20 ms
Power control (TPC)
4 Bit/user/10ms
TFCI
16 Bit/user/10ms
Synchronisation Shift (SS)
4 Bit/user/10ms
Inband signalling DCCH
2 kbps
Puncturing level at Code rate 1/3: DCH / DCCH
33% / 33%
