Java 代码精简之道
Photo @ Priscilla Du Preez
文 | 常意,阿里巴巴中间件
前言
古语有云:
道为术之灵,术为道之体;以道统术,以术得道。
1.利用语法
1.1.利用三元表达式
String title;
if (isMember(phone)) {
title = "会员";
} else {
title = "游客";
String title = isMember(phone) ? "会员" : "游客";
1.2.利用 for-each 语句
double[] values = ...;
for(int i = 0; i < values.length; i++) {
double value = values[i];
// TODO: 处理value
List<Double> valueList = ...;
Iterator<Double> iterator = valueList.iterator();
while (iterator.hasNext()) {
Double value = iterator.next();
// TODO: 处理value
for(double value : values) {
// TODO: 处理value
for(Double value : valueList) {
// TODO: 处理value
1.3.利用 try-with-resource 语句
BufferedReader reader = null;
try {
reader = new BufferedReader(new FileReader("cities.csv"));
String line;
while ((line = reader.readLine()) != null) {
// TODO: 处理line
} catch (IOException e) {
log.error("读取文件异常", e);
} finally {
if (reader != null) {
try {
reader.close();
log.error("关闭文件异常", e);
try (BufferedReader reader = new BufferedReader(new FileReader("test.txt"))) {
String line;
// TODO: 处理line
1.4.利用 return 关键字
public static boolean hasSuper(@NonNull List<UserDO> userList) {
boolean hasSuper = false;
for (UserDO user : userList) {
if (Boolean.TRUE.equals(user.getIsSuper())) {
hasSuper = true;
break;
return hasSuper;
return true;
return false;
1.5.利用 static 关键字
public final class GisHelper {
public double distance(double lng1, double lat1, double lng2, double lat2) {
// 方法实现代码
GisHelper gisHelper = new GisHelper();
double distance = gisHelper.distance(116.178692D, 39.967115D, 116.410778D, 39.899721D);
public static double distance(double lng1, double lat1, double lng2, double lat2) {
// 方法实现代码
double distance = GisHelper.distance(116.178692D, 39.967115D, 116.410778D, 39.899721D);
1.6.利用 lambda 表达式
new Thread(new Runnable() {
public void run() {
// 线程处理代码
}).start();
new Thread(() -> {
// 线程处理代码
}).start();
1.7.利用方法引用
Arrays.sort(nameArray, (a, b) -> a.compareToIgnoreCase(b));
List<Long> userIdList = userList.stream()
.map(user -> user.getId())
.collect(Collectors.toList());
精简:
Arrays.sort(nameArray, String::compareToIgnoreCase);
.map(UserDO::getId)
1.8.利用静态导入
List<Double> areaList = radiusList.stream().map(r -> Math.PI * Math.pow(r, 2)).collect(Collectors.toList());
import static java.lang.Math.PI;
import static java.lang.Math.pow;
import static java.util.stream.Collectors.toList;
List<Double> areaList = radiusList.stream().map(r -> PI * pow(r, 2)).collect(toList());
1.9.利用 unchecked 异常
@Service
public class UserService {
public void createUser(UserCreateVO create, OpUserVO user) throws BusinessException {
checkOperatorUser(user);
private void checkOperatorUser(OpUserVO user) throws BusinessException {
if (!hasPermission(user)) {
throw new BusinessException("用户无操作权限");
@RestController
@RequestMapping("/user")
public class UserController {
@Autowired
private UserService userService;
@PostMapping("/createUser")
public Result<Void> createUser(@RequestBody @Valid UserCreateVO create, OpUserVO user) throws BusinessException {
userService.createUser(create, user);
return Result.success();
@Service
public void createUser(UserCreateVO create, OpUserVO user) {
private void checkOperatorUser(OpUserVO user) {
throw new BusinessRuntimeException("用户无操作权限");
@RestController
@Autowired
public Result<Void> createUser(@RequestBody @Valid UserCreateVO create, OpUserVO user) {
2.利用注解
2.1.利用 Lombok 注解
public class UserVO {
private Long id;
private String name;
public Long getId() {
return this.id;
public void setId(Long id) {
this.id = id;
public String getName() {
return this.name;
public void setName(String name) {
this.name = name;
@Getter
@Setter
@ToString
private Long id;
2.2.利用 Validation 注解
@Getter@Setter@ToStringpublic class UserCreateVO { @NotBlank(message = "用户名称不能为空") private String name; @NotNull(message = "公司标识不能为空") private Long companyId; ...}@Service@Validatedpublic class UserService { public Long createUser(@Valid UserCreateVO create) { // TODO: 创建用户 return null; }}
@Getter
@Setter
@ToString
@Service
@Validated
// TODO: 创建用户
return null;
2.3.利用 @NonNull 注解
public List<UserVO> queryCompanyUser(Long companyId) {
// 检查公司标识
if (companyId == null) {
return null;
// 查询返回用户
List<UserDO> userList = userDAO.queryByCompanyId(companyId);
return userList.stream().map(this::transUser).collect(Collectors.toList());
Long companyId = 1L;
List<UserVO> userList = queryCompanyUser(companyId);
if (CollectionUtils.isNotEmpty(userList)) {
for (UserVO user : userList) {
// TODO: 处理公司用户
public @NonNull List<UserVO> queryCompanyUser(@NonNull Long companyId) {
// TODO: 处理公司用户
2.4.利用注解特性
3.利用泛型
3.1.泛型接口
在 Java 没有引入泛型前,都是采用 Object 表示通用对象,最大的问题就是类型无法强校验并且需要强制类型转换。
public interface Comparable {
public int compareTo(Object other);
@Getter
@Setter
@ToString
public class UserVO implements Comparable {
private Long id;
@Override
public int compareTo(Object other) {
UserVO user = (UserVO)other;
return Long.compare(this.id, user.id);
public interface Comparable<T> {
public int compareTo(T other);
@Getter
@Setter
@ToString
public class UserVO implements Comparable<UserVO> {
private Long id;
@Override
public int compareTo(UserVO other) {
return Long.compare(this.id, other.id);
3.2.泛型类
@Getter
@Setter
@ToString
public class IntPoint {
private Integer x;
private Integer y;
@Getter
@Setter
@ToString
public class DoublePoint {
private Double x;
private Double y;
@Getter
@Setter
@ToString
public class Point<T extends Number> {
private T x;
private T y;
3.3.泛型方法
public static Map<String, Integer> newHashMap(String[] keys, Integer[] values) {
// 检查参数非空
if (ArrayUtils.isEmpty(keys) || ArrayUtils.isEmpty(values)) {
return Collections.emptyMap();
// 转化哈希映射
Map<String, Integer> map = new HashMap<>();
int length = Math.min(keys.length, values.length);
for (int i = 0; i < length; i++) {
map.put(keys[i], values[i]);
return map;
public static <K, V> Map<K, V> newHashMap(K[] keys, V[] values) {
// 检查参数非空
// 转化哈希映射
Map<K, V> map = new HashMap<>();
return map;
4.利用自身方法
4.1.利用构造方法
@Getter
@Setter
@ToString
public class PageDataVO<T> {
private Long totalCount;
private List<T> dataList;
PageDataVO<UserVO> pageData = new PageDataVO<>();
pageData.setTotalCount(totalCount);
pageData.setDataList(userList);
return pageData;
@Getter
@Setter
@ToString
@NoArgsConstructor
@AllArgsConstructor
return new PageDataVO<>(totalCount, userList);
4.2.利用 Set 的 add 方法
Set<Long> userIdSet = new HashSet<>();
List<UserVO> userVOList = new ArrayList<>();
for (UserDO userDO : userDOList) {
if (!userIdSet.contains(userDO.getId())) {
userIdSet.add(userDO.getId());
userVOList.add(transUser(userDO));
SSet<Long> userIdSet = new HashSet<>();
if (userIdSet.add(userDO.getId())) {
4.3.利用 Map 的 computeIfAbsent 方法
Map<Long, List<UserDO>> roleUserMap = new HashMap<>();
Long roleId = userDO.getRoleId();
List<UserDO> userList = roleUserMap.get(roleId);
if (Objects.isNull(userList)) {
userList = new ArrayList<>();
roleUserMap.put(roleId, userList);
userList.add(userDO);
roleUserMap.computeIfAbsent(userDO.getRoleId(), key -> new ArrayList<>())
.add(userDO);
4.4.利用链式编程
StringBuilder builder = new StringBuilder(96);
builder.append("select id, name from ");
builder.append(T_USER);
builder.append(" where id = ");
builder.append(userId);
builder.append(";");
.append(T_USER)
.append(userId)
.append(";");
5.利用工具方法
5.1.避免空值判断
if (userList != null && !userList.isEmpty()) {
// TODO: 处理代码
// TODO: 处理代码
5.2.避免条件判断
double result;
if (value <= MIN_LIMIT) {
result = MIN_LIMIT;
} else {
result = value;
double result = Math.max(MIN_LIMIT, value);
5.3.简化赋值语句
public static final List<String> ANIMAL_LIST;
static {
List<String> animalList = new ArrayList<>();
animalList.add("dog");
animalList.add("cat");
animalList.add("tiger");
ANIMAL_LIST = Collections.unmodifiableList(animalList);
// JDK流派
public static final List<String> ANIMAL_LIST = Arrays.asList("dog", "cat", "tiger");
// Guava流派
public static final List<String> ANIMAL_LIST = ImmutableList.of("dog", "cat", "tiger");
5.4.简化数据拷贝
UserVO userVO = new UserVO();
userVO.setId(userDO.getId());
userVO.setName(userDO.getName());
userVO.setDescription(userDO.getDescription());
userVOList.add(userVO);
BeanUtils.copyProperties(userDO, userVO);
List<UserVO> userVOList = JSON.parseArray(JSON.toJSONString(userDOList), UserVO.class);
精简代码,但不能以过大的性能损失为代价。例子是浅层拷贝,用不着 JSON 这样重量级的武器。
5.5.简化异常断言
if (Objects.isNull(userId)) {
throw new IllegalArgumentException("用户标识不能为空");
Assert.notNull(userId, "用户标识不能为空");
5.6.简化测试用例
@Test
public void testCreateUser() {
UserCreateVO userCreate = new UserCreateVO();
userCreate.setName("Changyi");
userCreate.setTitle("Developer");
userCreate.setCompany("AMAP");
Long userId = userService.createUser(OPERATOR, userCreate);
Assert.assertNotNull(userId, "创建用户失败");
精简:
@Test
String jsonText = ResourceHelper.getResourceAsString(getClass(), "createUser.json");
UserCreateVO userCreate = JSON.parseObject(jsonText, UserCreateVO.class);
5.7.简化算法实现
int totalSize = valueList.size();
List<List<Integer>> partitionList = new ArrayList<>();
for (int i = 0; i < totalSize; i += PARTITION_SIZE) {
partitionList.add(valueList.subList(i, Math.min(i + PARTITION_SIZE, totalSize)));
精简:
List<List<Integer>> partitionList = ListUtils.partition(valueList, PARTITION_SIZE);
5.8.封装工具方法
// 设置参数值
if (Objects.nonNull(user.getId())) {
statement.setLong(1, user.getId());
} else {
statement.setNull(1, Types.BIGINT);
/** SQL辅助类 */
public final class SqlHelper {
/** 设置长整数值 */
public static void setLong(PreparedStatement statement, int index, Long value) throws SQLException {
if (Objects.nonNull(value)) {
statement.setLong(index, value.longValue());
} else {
statement.setNull(index, Types.BIGINT);
// 设置参数值
SqlHelper.setLong(statement, 1, user.getId());
6.利用数据结构
6.1.利用数组简化
public static int getGrade(double score) {
if (score >= 90.0D) {
return 1;
if (score >= 80.0D) {
return 2;
if (score >= 60.0D) {
return 3;
if (score >= 30.0D) {
return 4;
return 5;
private static final double[] SCORE_RANGES = new double[] {90.0D, 80.0D, 60.0D, 30.0D};
for (int i = 0; i < SCORE_RANGES.length; i++) {
if (score >= SCORE_RANGES[i]) {
return i + 1;
return SCORE_RANGES.length + 1;
6.2.利用 Map 简化
public static String getBiologyClass(String name) {
switch (name) {
case "dog" :
return "animal";
case "cat" :
return "animal";
case "lavender" :
return "plant";
default :
return null;
精简:
private static final Map<String, String> BIOLOGY_CLASS_MAP
= ImmutableMap.<String, String>builder()
.put("dog", "animal")
.put("cat", "animal")
.put("lavender", "plant")
.build();
return BIOLOGY_CLASS_MAP.get(name);
6.3.利用容器类简化
@Setter
@Getter
@ToString
@AllArgsConstructor
public static class PointAndDistance {
private Point point;
private Double distance;
public static PointAndDistance getNearest(Point point, Point[] points) {
// 计算最近点和距离
// 返回最近点和距离
return new PointAndDistance(nearestPoint, nearestDistance);
public static Pair<Point, Double> getNearest(Point point, Point[] points) {
// 计算最近点和距离
// 返回最近点和距离
return ImmutablePair.of(nearestPoint, nearestDistance);
6.4.利用 ThreadLocal 简化
public static String formatDate(Date date, DateFormat format) {
return format.format(date);
public static List<String> getDateList(Date minDate, Date maxDate, DateFormat format) {
List<String> dateList = new ArrayList<>();
Calendar calendar = Calendar.getInstance();
calendar.setTime(minDate);
String currDate = formatDate(calendar.getTime(), format);
String maxsDate = formatDate(maxDate, format);
while (currDate.compareTo(maxsDate) <= 0) {
dateList.add(currDate);
calendar.add(Calendar.DATE, 1);
return dateList;
精简:
private static final ThreadLocal<DateFormat> LOCAL_DATE_FORMAT = new ThreadLocal<DateFormat>() {
@Override
protected DateFormat initialValue() {
return new SimpleDateFormat("yyyyMMdd");
public static String formatDate(Date date) {
return LOCAL_DATE_FORMAT.get().format(date);
public static List<String> getDateList(Date minDate, Date maxDate) {
String currDate = formatDate(calendar.getTime());
String maxsDate = formatDate(maxDate);
return dateList;
7.利用 Optional
7.1.保证值存在
Integer thisValue;
thisValue = value;
} else {
thisValue = DEFAULT_VALUE;
Integer thisValue = Optional.ofNullable(value).orElse(DEFAULT_VALUE);
7.2.保证值合法
Integer thisValue;
if (Objects.nonNull(value) && value.compareTo(MAX_VALUE) <= 0) {
thisValue = value;
} else {
thisValue = MAX_VALUE;
精简:
.filter(tempValue -> tempValue.compareTo(MAX_VALUE) <= 0).orElse(MAX_VALUE);
7.3.避免空判断
String zipcode = null;
if (Objects.nonNull(user)) {
Address address = user.getAddress();
if (Objects.nonNull(address)) {
Country country = address.getCountry();
if (Objects.nonNull(country)) {
zipcode = country.getZipcode();
精简:
tring zipcode = Optional.ofNullable(user).map(User::getAddress)
.map(Address::getCountry).map(Country::getZipcode).orElse(null);
8.利用 Stream
流(Stream)是Java 8的新成员,允许你以声明式处理数据集合,可以看成为一个遍历数据集的高级迭代器。流主要有三部分构成:获取一个数据源→数据转换→执行操作获取想要的结果。每次转换原有 Stream 对象不改变,返回一个新的 Stream 对象,这就允许对其操作可以像链条一样排列,形成了一个管道。流(Stream)提供的功能非常有用,主要包括匹配、过滤、汇总、转化、分组、分组汇总等功能。
8.1.匹配集合数据
boolean isFound = false;
if (Objects.equals(user.getId(), userId)) {
isFound = true;
break;
精简:
boolean isFound = userList.stream()
.anyMatch(user -> Objects.equals(user.getId(), userId));
8.2.过滤集合数据
List<UserDO> resultList = new ArrayList<>();
resultList.add(user);
精简:
List<UserDO> resultList = userList.stream()
.filter(user -> Boolean.TRUE.equals(user.getIsSuper()))
8.3.汇总集合数据
double total = 0.0D;
for (Account account : accountList) {
total += account.getBalance();
精简:
double total = accountList.stream().mapToDouble(Account::getBalance).sum();
8.4.转化集合数据
普通:
精简:
List<UserVO> userVOList = userDOList.stream()
8.5.分组集合数据
.add(userDO);
精简:
Map<Long, List<UserDO>> roleUserMap = userDOList.stream()
.collect(Collectors.groupingBy(UserDO::getRoleId));
8.6.分组汇总集合
Map<Long, Double> roleTotalMap = new HashMap<>();
Long roleId = account.getRoleId();
Double total = Optional.ofNullable(roleTotalMap.get(roleId)).orElse(0.0D);
roleTotalMap.put(roleId, total + account.getBalance());
精简:
roleTotalMap = accountList.stream().collect(Collectors.groupingBy(Account::getRoleId, Collectors.summingDouble(Account::getBalance)));
8.7.生成范围集合
int[] array1 = new int[N];
for (int i = 0; i < N; i++) {
array1[i] = i + 1;
int[] array2 = new int[N];
array2[0] = 1;
for (int i = 1; i < N; i++) {
array2[i] = array2[i - 1] * 2;
精简:
int[] array1 = IntStream.rangeClosed(1, N).toArray();
int[] array2 = IntStream.iterate(1, n -> n * 2).limit(N).toArray();
9.利用程序结构
9.1.返回条件表达式
public boolean isSuper(Long userId)
UserDO user = userDAO.get(userId);
if (Objects.nonNull(user) && Boolean.TRUE.equals(user.getIsSuper())) {
return true;
return false;
精简:
return Objects.nonNull(user) && Boolean.TRUE.equals(user.getIsSuper());
9.2.最小化条件作用域
Result result = summaryService.reportWorkDaily(workDaily);
if (result.isSuccess()) {
String message = "上报工作日报成功";
dingtalkService.sendMessage(user.getPhone(), message);
} else {
String message = "上报工作日报失败:" + result.getMessage();
log.warn(message);
精简:
String message;
} else {
log.warn(message);
9.3.调整表达式位置
String line = readLine();
while (Objects.nonNull(line)) {
... // 处理逻辑代码
line = readLine();
普通2:
for (String line = readLine(); Objects.nonNull(line); line = readLine()) {
... // 处理逻辑代码
精简:
String line;
while (Objects.nonNull(line = readLine())) {
... // 处理逻辑代码
注意:有些规范可能不建议这种精简写法。
9.4.利用非空对象
private static final int MAX_VALUE = 1000;
boolean isMax = (value != null && value.equals(MAX_VALUE));
boolean isTrue = (result != null && result.equals(Boolean.TRUE));
private static final Integer MAX_VALUE = 1000;
boolean isMax = MAX_VALUE.equals(value);
boolean isTrue = Boolean.TRUE.equals(result);
10.利用设计模式
10.1.模板方法模式
@Repository
public class UserValue {
/** 值操作 */
@Resource(name = "stringRedisTemplate")
private ValueOperations<String, String> valueOperations;
/** 值模式 */
private static final String KEY_FORMAT = "Value:User:%s";
/** 设置值 */
public void set(Long id, UserDO value) {
String key = String.format(KEY_FORMAT, id);
valueOperations.set(key, JSON.toJSONString(value));
/** 获取值 */
public UserDO get(Long id) {
String value = valueOperations.get(key);
return JSON.parseObject(value, UserDO.class);
@Repository
public class RoleValue {
/** 值操作 */
/** 值模式 */
private static final String KEY_FORMAT = "Value:Role:%s";
/** 设置值 */
public void set(Long id, RoleDO value) {
/** 获取值 */
public RoleDO get(Long id) {
return JSON.parseObject(value, RoleDO.class);
精简:
public abstract class AbstractDynamicValue<I, V> {
/** 值操作 */
/** 设置值 */
public void set(I id, V value) {
valueOperations.set(getKey(id), JSON.toJSONString(value));
/** 获取值 */
public V get(I id) {
return JSON.parseObject(valueOperations.get(getKey(id)), getValueClass());
/** 获取主键 */
protected abstract String getKey(I id);
/** 获取值类 */
protected abstract Class<V> getValueClass();
@Repository
public class UserValue extends AbstractValue<Long, UserDO> {
/** 获取主键 */
@Override
protected String getKey(Long id) {
return String.format("Value:User:%s", id);
/** 获取值类 */
@Override
protected Class<UserDO> getValueClass() {
return UserDO.class;
@Repository
public class RoleValue extends AbstractValue<Long, RoleDO> {
/** 获取主键 */
@Override
return String.format("Value:Role:%s", id);
/** 获取值类 */
@Override
protected Class<RoleDO> getValueClass() {
return RoleDO.class;
10.2.建造者模式
public interface DataHandler<T> {
/** 解析数据 */
public T parseData(Record record);
/** 存储数据 */
public boolean storeData(List<T> dataList);
public <T> long executeFetch(String tableName, int batchSize, DataHandler<T> dataHandler) throws Exception {
// 构建下载会话
DownloadSession session = buildSession(tableName);
// 获取数据数量
long recordCount = session.getRecordCount();
if (recordCount == 0) {
return 0;
// 进行数据读取
long fetchCount = 0L;
try (RecordReader reader = session.openRecordReader(0L, recordCount, true)) {
// 依次读取数据
Record record;
List<T> dataList = new ArrayList<>(batchSize);
while ((record = reader.read()) != null) {
// 解析添加数据
T data = dataHandler.parseData(record);
if (Objects.nonNull(data)) {
dataList.add(data);
// 批量存储数据
if (dataList.size() == batchSize) {
boolean isContinue = dataHandler.storeData(dataList);
fetchCount += batchSize;
dataList.clear();
if (!isContinue) {
break;
// 存储剩余数据
if (CollectionUtils.isNotEmpty(dataList)) {
fetchCount += dataList.size();
dataList.clear();
// 返回获取数量
return fetchCount;
// 使用案例
long fetchCount = odpsService.executeFetch("user", 5000, new DataHandler() {
/** 解析数据 */
public T parseData(Record record) {
UserDO user = new UserDO();
user.setId(record.getBigint("id"));
user.setName(record.getString("name"));
return user;
/** 存储数据 */
public boolean storeData(List<T> dataList) {
userDAO.batchInsert(dataList);
return true;
public <T> long executeFetch(String tableName, int batchSize, Function<Record, T> dataParser, Function<List<T>, Boolean> dataStorage) throws Exception {
// 构建下载会话
// 获取数据数量
return 0;
// 进行数据读取
// 依次读取数据
Record record;
// 解析添加数据
T data = dataParser.apply(record);
dataList.add(data);
// 批量存储数据
Boolean isContinue = dataStorage.apply(dataList);
dataList.clear();
if (!Boolean.TRUE.equals(isContinue)) {
break;
// 存储剩余数据
dataList.clear();
// 返回获取数量
return fetchCount;
// 使用案例
long fetchCount = odpsService.executeFetch("user", 5000, record -> {
return user;
}, dataList -> {
return true;
10.3.代理模式
@Slf4j
@RestController
/** 用户服务 */
@Autowired
/** 查询用户 */
@PostMapping("/queryUser")
public Result<?> queryUser(@RequestBody @Valid UserQueryVO query) {
try {
PageDataVO<UserVO> pageData = userService.queryUser(query);
return Result.success(pageData);
} catch (Exception e) {
log.error(e.getMessage(), e);
return Result.failure(e.getMessage());
@RestController
/** 用户服务 */
@Autowired
/** 查询用户 */
public Result<PageDataVO<UserVO>> queryUser(@RequestBody @Valid UserQueryVO query) {
@Slf4j
@ControllerAdvice
public class GlobalControllerAdvice {
/** 处理异常 */
@ResponseBody
@ExceptionHandler(Exception.class)
public Result<Void> handleException(Exception e) {
// UserController代码同"精简1"
@Slf4j
@Aspect
public class WebExceptionAspect {
/** 点切面 */
@Pointcut("@annotation(org.springframework.web.bind.annotation.RequestMapping)")
private void webPointcut() {}
/** 处理异常 */
@AfterThrowing(pointcut = "webPointcut()", throwing = "e")
public void handleException(Exception e) {
Result<Void> result = Result.failure(e.getMessage());
writeContent(JSON.toJSONString(result));
11.利用删除代码
“少即是多”,“少”不是空白而是精简,“多”不是拥挤而是完美。删除多余的代码,才能使代码更精简更完美。
11.1.删除已废弃的代码
import lombok.extern.slf4j.Slf4j;
@Slf4j
@Service
public class ProductService {
@Value("discardRate")
private double discardRate;
private ProductVO transProductDO(ProductDO productDO) {
ProductVO productVO = new ProductVO();
BeanUtils.copyProperties(productDO, productVO);
// productVO.setPrice(getDiscardPrice(productDO.getPrice()));
return productVO;
private BigDecimal getDiscardPrice(BigDecimal originalPrice) {
@Service
return productVO;
11.2.删除接口方法的public对于接口(interface),所有的字段和方法都是public的,可以不用显式声明为public。普通:public interface UserDAO {
public Long countUser(@Param("query") UserQuery query);
public List<UserDO> queryUser(@Param("query") UserQuery query);
11.2.删除接口方法的public
public Long countUser( UserQuery query);
public List<UserDO> queryUser( UserQuery query);
11.3.删除枚举构造方法的 private
public enum UserStatus {
DISABLED(0, "禁用"),
ENABLED(1, "启用");
private final Integer value;
private final String desc;
private UserStatus(Integer value, String desc) {
this.value = value;
this.desc = desc;
DISABLED(0, "禁用"),
ENABLED(1, "启用");
this.value = value;
this.desc = desc;
11.4.删除 final 类方法的 final
public final Rectangle implements Shape {
@Override
public final double getArea() {
return width * height;
@Override
public double getArea() {
11.5.删除基类 implements 的接口
public interface Shape {
double getArea();
public abstract AbstractShape implements Shape {
public final Rectangle extends AbstractShape implements Shape {
@Override
public final Rectangle extends AbstractShape {
@Override
11.6.删除不必要的变量
public Boolean existsUser(Long userId) {
Boolean exists = userDAO.exists(userId);
return exists;
return userDAO.exists(userId);
后记
古语又云:
有道无术,术尚可求也;有术无道,止于术。
陈昌毅,花名常意,地图技术专家。
特别推荐一个分享架构+算法的优质内容,还没关注的小伙伴,可以长按关注一下:
长按订阅更多精彩▼
如有收获,点个在看,诚挚感谢
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
