当前位置:首页 > 通信技术 > 移动通信
[导读] Linear公司的LT3791是同步的四开关升压-降压LED驱动控制器,可使VIN高于,低于或等于VOUT,效率高达98.5%,输入电压4.7V-60V,输出电压0-60V,LED电流精度±6%
Linear公司的LT3791是同步的四开关升压-降压LED驱动控制器,可使VIN高于,低于或等于VOUT,效率高达98.5%,输入电压4.7V-60V,输出电压0-60V,LED电流精度±6%,真彩色PWM和模拟调光,每个IC输入功率100W或大于100W,主要用于汽车前灯/行驶灯和通用照明.本文介绍了LT3791主要特性,方框图,多种应用电路以及演示板DC1666A主要特性,电路图,材料清单和PCB元件布局图,测试电路图.
he LT®3791 is a synchronous 4-switch buck-boost LED driver controller. The controller can regulate LED current up to 52V of LED string with input voltages above, below, or equal to the output voltage. The constant-frequency, forced-continuous current mode architecture allows its frequency to be adjusted or synchronized from 200kHz to 700kHz. No top MOSFET refresh switching cycle is needed in buck or boost operaTIon. With 60V input, 60V output capability and seamless transiTIons between operaTIng regions, the LT3791 is ideal for LED driver applicaTIons in automotive, industrial, and even battery-powered systems.
The LT3791 provides input current monitor, LED current monitor, and open or shorted LED fault condition, during which the LT3791 either restarts or latches off.
LT3791主要特性:
4-Switch Single Inductor Architecture Allows VIN Above, Below or Equal to VOUT
Synchronous Switching: Up to 98.5% Efficiency
Wide VIN Range: 4.7V to 60V
Wide VOUT Range: 0V to 60V (52V LED)
±6% LED Current Accuracy: 0V ≤ VLED < 52V
True Color PWM™ and Analog Dimming
LED and Input Current Regulation with Current Monitor Outputs
No Top MOSFET Refresh in Buck or Boost
VOUT Disconnected From VIN During Shutdown
Open or Shorted LED Fault Protection
Capable of 100W or Greater per IC
38-Lead TSSOP with Exposed Pad
LT3791应用:
Automotive Head Lamps/Running Lamps
General Purpose Lighting
图1.LT3791方框图
