当前位置:首页 > 汽车电子 > 汽车电子技术文库
[导读] Avnet公司的MicroZed开发板是基于Xilinx公司的Zynq®-7000全编程SoC器件的低成本开发板,其独特的设计既可用作基本SoC实验的独立评估板,也可配合载卡用作嵌入式的模块上系
Avnet公司的MicroZed开发板是基于Xilinx公司的Zynq®-7000全编程SoC器件的低成本开发板,其独特的设计既可用作基本SoC实验的独立评估板,也可配合载卡用作嵌入式的模块上系统(SOM).该套件包含了开发产品, IoT支持和工业处理系统所需的必备模块.可支持设计人员开发边界到云端的基于互联网连接的解决方案,能迅速提升具备认知能力的物联网解决方案.主要用在ADAS,医疗电子,小型蜂窝基带,机器视角系统,4K/2K超高清电视机以及多功能打印机.本文介绍了开发板MicroZed主要特性,框图,电路图,材料清单和PCB设计图.
MicroZed™ is a low-cost development board based on the Xilinx Zynq®-7000 All Programmable SoC. Its unique design allows it to be used as both a stand-alone evaluation board for basic SoC experimentaTIon, or combined with a carrier card as an embeddable system-on-module (SOM). MicroZed contains two I/O headers that provide connecTIon to two I/O banks on the programmable logic (PL) side of the Zynq®-7000 All Programmable SoC device. In stand-alone mode, these 100 PL I/O are inacTIve. When plugged into a carrier card, the I/O are accessible in a manner defined by the carrier card design.
In addiTIon to the evaluation kit, MicroZed is also available for volume purchase as a module only (no cable, license voucher, or uSD Card). This System-On-Module or SOM version of MicroZed comes in either the Zynq 7Z010 or 7Z020 version.
图1.开发板MicroZed外形图
开发板MicroZed主要特性:
– Xilinx Zynq 7010/7020 CLG400 AP SOC
– Primary configuration = QSPI Flash
– Auxiliary configuration options
– JTAG (through PL via Xilinx PC4 Header)
– MicroSD Card
– Memory
– 1 GB DDR3 (x32)
– 128 Mb QSPI Flash
– GB MicroSD Card (Evaluation Kit only, AES-Z7MB-7Z010-G)
– Interfaces
– Xilinx PC4 Header for programming
– Accesses Programmable Logic (PL) JTAG
– Processing System (PS) JTAG pins connected through DigilentPmod™ compatible interface
– 10/100/1000 Ethernet
USB Host 2.0
– MicroSD Card
– USB 2.0 Full-Speed USB-UART bridge
– One DigilentPmod compatible interface, connected to PS MIO
– Two 100-pin MicroHeaders
– Reset Button
– 1 User Push Button
– 1 User LEDs
– DONE LED
– On-board Oscillator
– 33.333 MHz
– Power
– High-efficiency regulators for Vccint, Vccpint, Vccbram, Vccaux, Vccpaux, Vccpll, Vcco_0, Vcco_ddr, Vcco_mio
– Three potential powering methods
– USB Bus Power from USB-UART interface
– Optional barrel jack and AC/DC supply
– Optional carrier card
– Software
– Vivado Design Suite
– Download from
– Vivado Design Suite: Design Edition license voucher (node-locked, device-locked to the XC7Z010 – Evaluation Kit only, AES-Z7MB-7Z010-G)
图2.开发板MicroZed框图
图3.开发板MicroZed电路图(1)
图4.开发板MicroZed电路图(2)
图5.开发板MicroZed电路图(3)
图6.开发板MicroZed电路图(4)
图7.开发板MicroZed电路图(5)
图8.开发板MicroZed电路图(6)
图9.开发板MicroZed电路图(7)
图10.开发板MicroZed电路图(8)
图11.开发板MicroZed电路图(9)
开发板MicroZed材料清单:
图12.开发板MicroZed尺寸图(顶视,吋)
图13.开发板MicroZed尺寸图(底视,吋)
图14.开发板MicroZed PCB设计图(1)
图15.开发板MicroZed PCB设计图(2)
图16.开发板MicroZed PCB设计图(3)
图17.开发板MicroZed PCB设计图(4)
图18.开发板MicroZed PCB设计图(5)
图19.开发板MicroZed PCB设计图(6)
图20.开发板MicroZed PCB设计图(7)
图21.开发板MicroZed PCB设计图(8)
图22.开发板MicroZed PCB设计图(9)
图23.开发板MicroZed PCB设计图(10)
图24.开发板MicroZed PCB设计图(11)
图25.开发板MicroZed PCB设计图(12)
图26.开发板MicroZed PCB设计图(13)
图27.开发板MicroZed PCB设计图(14)
图28.开发板MicroZed PCB设计图(15)
图29.开发板MicroZed PCB设计图(16)
图30.开发板MicroZed PCB设计图(17)
详情请见:
5276-MicroZed-HW-UG-v1-7-V1.pdf
MicroZed_RevF_Layout_131029.pdf
Schematic_G-04-02.zip
MicroZed_RevG_BOMs.zip
