当前位置:首页 > 汽车电子 > 汽车电子技术文库
[导读] Cypress公司的EZ-PD™ CCG2是USB type-c型控制器,它符合最新USB type-c 型和PD 标准。EZ-PD CCG2 为无源线缆,主动线缆和电源配件提供了一
Cypress公司的EZ-PD™ CCG2是USB type-c型控制器,它符合最新USB type-c 型和PD 标准。EZ-PD CCG2 为无源线缆,主动线缆和电源配件提供了一个完整的USB type-c 和USB 供电端口控制解决方案.EZ-PDCCG2 使用赛普拉斯的专用M0S8 技术,该技术使用了带有32 KB 闪存的32 位48 MHz ARM® Cortex®-M0 处理器;该处理器集成了一个包括RP、RD 和RAtype-c 型电阻的完整的Type-C 型收发器。主要用在 USB Type-C 型的EMCA 线缆, 供电配件, 上行方向端口以及下行方向端口。本文介绍了EZ-PD™ CCG2主要特性,逻辑框图,功能框图以及USB-PD子系统框图,CCG2 60W汽车充电器参考设计文件,电路图和材料清单。
EZ-PD™ CCG2 is a USB Type-C controller that complies with the latest USB Type-C and PD standards. EZ-PD CCG2 provides acomplete USB Type-C and USB Power Delivery port control soluTIon for passive cables, acTIve cables, and powered accessories. Itcan also be used in many upstream and downstream facing port applicaTIons.EZ-PD CCG2 uses Cypress’s proprietary M0S8technology with a 32-bit, 48-MHz ARM® Cortex®-M0 processor with 32-KB flash and integrates a complete Type-C Transceiverincluding the Type-C terminaTIon resistors RP, RD and RA.
EZ-PD™ CCG2主要特性:
32-bit MCU Subsystem
■ 48-MHz ARM Cortex-M0 CPU
■ 32-KB Flash
■ 4-KB SRAM
■ In-system reprogrammable
Integrated Digital Blocks
■ Integrated timers and counters to meet response timesrequired by the USB-PD protocol
■ Run-time reconfigurable serial communication block (SCB)with reconfigurable I2C, SPI, or UART functionality
Clocks and Oscillators
■ Integrated oscillator eliminating the need for external clock
Type-C Support
■ Integrated transceiver (baseband PHY)
■ Integrated UFP (RD), EMCA (RA) termination resistors, andcurrent sources for DFP (RP)
■ Supports one USB Type-C port
Low-Power Operation
■ 2.7-V to 5.5-V operation
■ Two independent VCONN rails with integrated isolationbetween the two
■ Independent supply voltage pin for GPIO that allows 1.71-V to5.5-V signaling on the I/Os
■ Reset: 1.0 μA, Deep Sleep: 2.5 μA, Sleep: 2.0 mA
System-Level ESD on CC and VCONN Pins
■ ± 8-kV Contact Discharge and ±15-kV Air Gap Discharge basedon IEC61000-4-2 level 4C
Packages
■ 1.63 mm × 2.03 mm, 20-ball wafer-level CSP (WLCSP) with0.4-mm ball pitch
■ 2.5 mm × 3.5 mm × 0.6 mm 14-pin DFN
■ 4.0 mm × 4.0 mm, 0.55 mm 24-pin QFN
■ Supports industrial (40℃ to +85℃) and extended industrial(40℃ to +105℃) temperature ranges
EZ-PD™ CCG2应用:
■ USB Type-C EMCA cables
■ USB Type-C powered accessories
■ USB Type-C upstream facing ports
■ USB Type-C downstream facing ports
图1.EZ-PD™ CCG2逻辑框图
图2. EZ-PD™ CCG2框图
图3. EZ-PD™ CCG2 USB-PD子系统框图
CCG2 60W汽车充电器参考设计
The CCG2 60W Car Charger Reference Design Board is a receptacle based USB-C Charger with USB PD 2.0 and QC 3.0 (Class –A and Class –B) support. In the PD mode, it supports 5V@3A, 7V@3A, 8V@3A, 9V@3A, 12V@3A, 15V@3A and 20V@3A output.  The board can be programmed to support any output voltage between 0 to 20V with 100mV resolution. It is designed to work with standard Car Lighter Attachment (CLA). It works with any DC input between 4V to 24V.
The two major components on the board are Cypress’s EZ-PD CCG2 (CYPD2134-24LQXIT) controller and On Semiconductor’s NCP81239 DC-DC Buck-Boost controller.
图4.CCG2 60W汽车充电器参考设计外形图
The CCG2 device handles USB Type-C interface, Power Delivery (PD) 2.0, QC 3.0, Cable compensation and primary Over Current Protection (OCP). The buck-boost conversion, Over Current Protection (OCP) and Over Voltage Protection (OVP) are handled by On Semiconductor’s NCP81239 DC-DC Buck-Boost controller. The board hardware design files (schematic, bill of materials, layout etc) are readily available below for customers to reduce the design cycle.
图5. CCG2 60W汽车充电器参考设计电路图(1)
图6. CCG2 60W汽车充电器参考设计电路图(2)
图7. CCG2 60W汽车充电器参考设计电路图(3)
CCG2 60W汽车充电器参考设计材料清单:
CCG2 60W汽车充电器参考设计文件见:
