当前位置:首页 > 汽车电子 > 汽车电子技术文库
[导读] On Semi公司的LC717A30UJ是单芯片容性触摸/接近传感方案.器件包括一个用于输入通道选择的集成的多路复用器,模数转换器,确定电容变化及模拟输出幅值的双级放大器,系统时钟,上电复位电路
On Semi公司的LC717A30UJ是单芯片容性触摸/接近传感方案.器件包括一个用于输入通道选择的集成的多路复用器,模数转换器,确定电容变化及模拟输出幅值的双级放大器,系统时钟,上电复位电路和所需的所有控制逻辑,以创建一个整体方案.器件提供8个电容传感输入通道,其响应时间测量为16毫秒(ms),工作电源电压2.6V至5.5 V,具有1µA的低功耗待机模式,主要用在应用于工业和消费终端产品的各种触摸或手势人机接口,如电磁炉,电冰箱,家庭娱乐系统,楼宇自动化设备,工业设备和照明控制等.本文介绍了LC717A30UJ主要特性,框图和几种应用电路,以及电容触摸评估板LC717A30UJGEVK特性,电路图,材料清单和PCB设计图.
The LC717A30UJ is a high performance, low cost, and highlyusable capacitance converter for electrostaTIc capaciTIve touch andproximity sensors.
8 capacitance-sensing input channels ideal for use in any endproducts that needs an array of switches. The LC717A30Jfacilitates a short system development TIme through its automaTIccalibration function and minimal external components. Thedetection result (ON/OFF) for each sensor is read out by the serialinterface (I2C or SPI).
LC717A30UJ主要特性:
 Differential capacitive detection using mutual capacitance.
 Operates with small to large capacitance sensor input pads.
 Capacitance detection down to femto-Farad level.
 Measurement time 16 ms for 8 sensors.
 Minimal external components.
 Selectable interface : I²C or SPI.
 Current consumption : 0.8 mA (VDD = 5.5 V)
 Supply voltage : 2.6 V to 5.5 V
 AEC-Q100 qualified and PPAP capable.
LC717A30UJ典型应用:
 Automotive : Smart key, Control switches, Car audio, Proximity
 Consumer : Home Appliance, White goods, Induction Cooking
 Industrial : Security lock
 Computing : PC Peripherals, Audio Visual equipment
 Lighting : Remote control switches
图1.LC717A30UJ简化框图
图2.LC717A30UJ应用电路(1)
图3.LC717A30UJ应用电路(2):8个小电容传感器通路,4线SPI接口
图4.LC717A30UJ应用电路(3): 8个大电容传感器通路,I2C接口
The Electrostatic capacitive sensor kit (LC717A30UJGEVK) has several evaluation boards to evaluate the operation of various switch patterns and the communication to PC.
电容触摸评估板LC717A30UJGEVK特性:
Evaluation of 2 channel Proximity Sensor
Evaluation of 8 channel Touch Switch
Evaluation of Liquid Level Sensing
Evaluation of Electrode Sheet of Film Type
Evaluation of Customer’s Sensor Board
Communication Module between this Kit and PC through USB
电容触摸评估板LC717A30UJGEVK应用
Automotive
Consumer
Industrial
Computing
Lighting
图5.电容触摸评估板LC717A30UJGEVK外形图
电容触摸评估板LC717A30UJGEVK包括:
图6.主控制板LC717A30UJ00GEVB电路图
主控制板LC717A30UJ00GEVB材料清单:
图7.主控制板LC717A30UJ00GEVB PCB设计图(1)
图8.主控制板LC717A30UJ00GEVB PCB设计图(2)
图9.主控制板LC717A30UJ00GEVB PCB设计图(3)
图10.主控制板LC717A30UJ00GEVB PCB设计图(4)
图11.主控制板LC717A30UJ00GEVB PCB设计图(5)
图12.主控制板LC717A30UJ00GEVB PCB设计图(6)
图13.主控制板LC717A30UJ00GEVB PCB外形尺寸图
图14.DIP转换板LC717A30UJDIPGEVB电路图
DIP转换板LC717A30UJDIPGEVB材料清单:
图15.DIP转换板LC717A30UJDIPGEVB PCB设计图(1,2)
图16.DIP转换板LC717A30UJDIPGEVB PCB设计图(3,4)
图17.DIP转换板LC717A30UJDIPGEVB PCB设计图(5,6)
图18.DIP转换板LC717A30UJDIPGEVB PCB设计图(7,8)
图19.FPC转换板LC717A30UJFPCGEVB电路图
FPC转换板LC717A30UJFPCGEVB材料清单:
图20.FPC转换板LC717A30UJFPCGEVB PCB设计图(1,2)
图21.FPC转换板LC717A30UJFPCGEVB PCB设计图(3,4)
图22.FPC转换板LC717A30UJFPCGEVB PCB设计图(5,6)
图23.FPC转换板LC717A30UJFPCGEVB PCB设计图(7,8)
图24.2通路传感器板LC717A30UJ2CH00GEVB电路图
2通路传感器板LC717A30UJ2CH00GEVB材料清单:
图25.2通路传感器板LC717A30UJ2CH00GEVB电路图
图26.2通路传感器板LC717A30UJ2CH00GEVB PCB设计图(1,2)
图27.2通路传感器板LC717A30UJ2CH00GEVB PCB设计图(3,4)
图28.2通路传感器板LC717A30UJ2CH00GEVB PCB设计图(5,6)
图29.2通路传感器板LC717A30UJ2CH00GEVB PCB设计图(7,8)
触摸开关板ELECTRODE00GEVB
图30.触摸开关板ELECTRODE00GEVB电路图
触摸开关板ELECTRODE00GEVB材料清单:
图31.触摸开关板ELECTRODE00GEVB PCB设计图(1)
图32.触摸开关板ELECTRODE00GEVB PCB设计图(2)
图33.触摸开关板ELECTRODE00GEVB PCB设计图(3)
图34.触摸开关板ELECTRODE00GEVB PCB设计图(4)
图35.触摸开关板ELECTRODE00GEVB PCB设计图(5)
图36.触摸开关板ELECTRODE00GEVB PCB设计图(6)
图37.触摸开关板ELECTRODE00GEVB PCB设计图(7)
图38.触摸开关板ELECTRODE00GEVB电极图
接近传感器板ELECTRODE01GEVB
图39.接近传感器板ELECTRODE01GEVB电路图
接近传感器板ELECTRODE01GEVB材料清单:
图40.接近传感器板ELECTRODE01GEVB PCB设计图(1)
图41.接近传感器板ELECTRODE01GEVB PCB设计图(2)
图42.接近传感器板ELECTRODE01GEVB PCB设计图(3)
图43.接近传感器板ELECTRODE01GEVB PCB设计图(4)
图44.接近传感器板ELECTRODE01GEVB PCB设计图(5)
图45.接近传感器板ELECTRODE01GEVB PCB设计图(6)
图46.接近传感器板ELECTRODE01GEVB PCB设计图(7)
液体水平传感板ELECTRODE02GEVB
图47.液体水平传感板ELECTRODE02GEVB电路图
液体水平传感板ELECTRODE02GEVB材料清单:
图48.液体水平传感板ELECTRODE02GEVB PCB设计图(1,2)
图49.液体水平传感板ELECTRODE02GEVB PCB设计图(3,4)
图50.液体水平传感板ELECTRODE02GEVB PCB设计图(5,6)
图51.液体水平传感板ELECTRODE02GEVB PCB设计图(7,8)
图52.液体水平传感板ELECTRODE02GEVB电极图
感应键片
图53.感应键片图
感应键片材料清单:
