当前位置:首页 > 智能硬件 > 人工智能AI
[导读]   摘要:在银行金融界及非金融界,越来越多地用到了DES 算法, DES 全称为Data EncrypTIon Standard即数据加密算法。下面来说说DES算法的应用误区及安全性分析。
  DES算法详述
  DES算法把64位的明文输入块变为64位的密文输出块,它所使用的密钥也是64位,整个算法的主流程图如下:
  其功能是把输入的64位数据块按位重新组合,并把输出分为L0、R0两部分,每部分各长32位,其置换规则见下表:
  58,50,12,34,26,18,10,2,60,52,44,36,28,20,12,4,
  62,54,46,38,30,22,14,6,64,56,48,40,32,24,16,8,
  57,49,41,33,25,17, 9,1,59,51,43,35,27,19,11,3,
  61,53,45,37,29,21,13,5,63,55,47,39,31,23,15,7,
  即将输入的第58位换到第一位,第50位换到第2位,。。。,依此类推,最后一位是原来的第7位。L0、R0则是换位输出后的两部分,L0是输出的左32位,R0 是右32位,例:设置换前的输入值为D1D2D3.。。。。.D64,则经过初始置换后的结果为:L0=D58D50.。.D8;R0=D57D49.。.D7。
  经过26次迭代运算后。得到L16、R16,将此作为输入,进行逆置换,即得到密文输出。逆置换正好是初始置的逆运算,例如,第1位经过初始置换后,处于第40位,而通过逆置换,又将第40位换回到第1位,其逆置换规则如下表所示:
  40,8,48,16,56,24,64,32,39,7,47,15,55,23,63,31,
  38,6,46,14,54,22,62,30,37,5,45,13,53,21,61,29,
  36,4,44,12,52,20,60,28,35,3,43,11,51,19,59,27,
  34,2,42,10,50,18,58 26,33,1,41, 9,49,17,57,25,
  放大换位表
  32, 1, 2, 3, 4, 5, 4, 5, 6, 7, 8, 9, 8, 9, 10,11,
  12,13,12,13,14,15,16,17,16,17,18,19,20,21,20,21,
  22,23,24,25,24,25,26,27,28,29,28,29,30,31,32, 1,
  单纯换位表
  16,7,20,21,29,12,28,17, 1,15,23,26, 5,18,31,10,
  2,8,24,14,32,27, 3, 9,19,13,30, 6,22,11, 4,25,
  在f(Ri,Ki)算法描述图中,S1,S2.。.S8为选择函数,其功能是把6bit数据变为4bit数据。下面给出选择函数Si(i=1,2.。。。。.8)的功能表:
  选择函数Si
  S1:
  14,4,13,1,2,15,11,8,3,10,6,12,5,9,0,7,
  0,15,7,4,14,2,13,1,10,6,12,11,9,5,3,8,
  4,1,14,8,13,6,2,11,15,12,9,7,3,10,5,0,
  15,12,8,2,4,9,1,7,5,11,3,14,10,0,6,13,
  S2:
  15,1,8,14,6,11,3,4,9,7,2,13,12,0,5,10,
  3,13,4,7,15,2,8,14,12,0,1,10,6,9,11,5,
  0,14,7,11,10,4,13,1,5,8,12,6,9,3,2,15,
  13,8,10,1,3,15,4,2,11,6,7,12,0,5,14,9,
  S3:
  10,0,9,14,6,3,15,5,1,13,12,7,11,4,2,8,
  13,7,0,9,3,4,6,10,2,8,5,14,12,11,15,1,
  13,6,4,9,8,15,3,0,11,1,2,12,5,10,14,7,
  1,10,13,0,6,9,8,7,4,15,14,3,11,5,2,12,
  S4:
  7,13,14,3,0,6,9,10,1,2,8,5,11,12,4,15,
  13,8,11,5,6,15,0,3,4,7,2,12,1,10,14,9,
  10,6,9,0,12,11,7,13,15,1,3,14,5,2,8,4,
  3,15,0,6,10,1,13,8,9,4,5,11,12,7,2,14,
  S5:
  2,12,4,1,7,10,11,6,8,5,3,15,13,0,14,9,
  14,11,2,12,4,7,13,1,5,0,15,10,3,9,8,6,
  4,2,1,11,10,13,7,8,15,9,12,5,6,3,0,14,
  11,8,12,7,1,14,2,13,6,15,0,9,10,4,5,3,
  S6:
  12,1,10,15,9,2,6,8,0,13,3,4,14,7,5,11,
  10,15,4,2,7,12,9,5,6,1,13,14,0,11,3,8,
  9,14,15,5,2,8,12,3,7,0,4,10,1,13,11,6,
  4,3,2,12,9,5,15,10,11,14,1,7,6,0,8,13,
  S7:
  4,11,2,14,15,0,8,13,3,12,9,7,5,10,6,1,
  13,0,11,7,4,9,1,10,14,3,5,12,2,15,8,6,
  1,4,11,13,12,3,7,14,10,15,6,8,0,5,9,2,
  6,11,13,8,1,4,10,7,9,5,0,15,14,2,3,12,
  S8:
  13,2,8,4,6,15,11,1,10,9,3,14,5,0,12,7,
  1,15,13,8,10,3,7,4,12,5,6,11,0,14,9,2,
  7,11,4,1,9,12,14,2,0,6,10,13,15,3,5,8,
  2,1,14,7,4,10,8,13,15,12,9,0,3,5,6,11,
  在此以S1为例说明其功能,我们可以看到:在S1中,共有4行数据,命名为0,1、2、3行;每行有16列,命名为0、1、2、3,。。。。。。,14、15列。
  现设输入为: D=D1D2D3D4D5D6
  令:列=D2D3D4D5
  行=D1D6
  然后在S1表中查得对应的数,以4位二进制表示,此即为选择函数S1的输出。下面给出子密钥Ki(48bit)的生成算法
  从子密钥Ki的生成算法描述图中我们可以看到:初始Key值为64位,但DES算法规定,其中第8、16、。。。。。.64位是奇偶校验位,不参与DES运算。故Key 实际可用位数便只有56位。即:经过缩小选择换位表1的变换后,Key 的位数由64 位变成了56位,此56位分为C0、D0两部分,各28位,然后分别进行第1次循环左移,得到C1、D1,将C1(28位)、D1(28位)合并得到56位,再经过缩小选择换位2,从而便得到了密钥K0(48位)。依此类推,便可得到K1、K2、。。。。。。、K15,不过需要注意的是,16次循环左移对应的左移位数要依据下述规则进行:
  循环左移位数
  1,1,2,2,2,2,2,2,1,2,2,2,2,2,2,1
  以上介绍了DES算法的加密过程。DES算法的解密过程是一样的,区别仅仅在于第一次迭代时用子密钥K15,第二次K14、。。。。。。,最后一次用K0,算法本身并没有任何变化。
  DES算法的安全性
  自分组密码(DES算法)1977年首次公诸于世以来,引起了学术界和企业界的广泛重视。学术界对DES密码进行了深入的研究,围绕它的安全性和破译方法展开了激烈的争论,在一定意义上对密码学的理论研究也起了推动作用。同时人们也一直对DES的安全性持怀疑态度,对密钥的长度、迭代次数及S盒的设计众说纷纭
  1.对称分组密码算法的问题
  DES是对称的分组密码算法。对称的分组密码算法最主要的问题是:由于加解密双方都要使用相同的密钥,因此在发送、接收数据之前,必须完成密钥的分发。因而,密钥的分发便成了该加密体系中的最薄弱、风险最大的环节,各种基本的手段均很难保障安全地完成此项工作,从而使密钥更新的周期加长,给他人破译密钥提供了机会。实际上这与传统的保密方法差别不大。在历史战争中,破获他国情报的纪录不外是两种方式:一种是在敌方更换“密码本”的过程中截获对方密码本;另一种是敌人密钥变动周期太长,被长期跟踪,找出规律从而被破获。在对称算法中,尽管由于密钥强度增强,跟踪找出规律破获密钥的机会大大减小了,但密钥分发的困难问题几乎无法解决。如,设有n方参与通信,若n方都采用同一个对称密钥,一旦密钥被破解,整个体系就会崩溃;若采用不同的对称密钥则需n(n-1)个密钥,密钥数与参与通信人数的平方数成正比,这便使大系统密钥的管理几乎成为不可能。
