为什么阿里巴巴禁止使用Apache Beanutils进行属性的copy?
public class PersonDO {
private Integer id;
private String name;
private Integer age;
private Date birthday;
//省略setter/getter
public class PersonDTO {
private void mappingBySpringBeanUtils(PersonDO personDO, int times) {
StopWatch stopwatch = new StopWatch();
stopwatch.start();
for (int i = 0; i < times; i++) {
PersonDTO personDTO = new PersonDTO();
org.springframework.beans.BeanUtils.copyProperties(personDO, personDTO);
stopwatch.stop();
System.out.println("mappingBySpringBeanUtils cost :" + stopwatch.getTotalTimeMillis());
private void mappingByCglibBeanCopier(PersonDO personDO, int times) {
stopwatch.start();
BeanCopier copier = BeanCopier.create(PersonDO.class, PersonDTO.class, false);
copier.copy(personDO, personDTO, null);
stopwatch.stop();
System.out.println("mappingByCglibBeanCopier cost :" + stopwatch.getTotalTimeMillis());
private void mappingByApacheBeanUtils(PersonDO personDO, int times)
throws InvocationTargetException, IllegalAccessException {
stopwatch.start();
BeanUtils.copyProperties(personDTO, personDO);
stopwatch.stop();
System.out.println("mappingByApacheBeanUtils cost :" + stopwatch.getTotalTimeMillis());
private void mappingByApachePropertyUtils(PersonDO personDO, int times)
throws InvocationTargetException, IllegalAccessException, NoSuchMethodException {
stopwatch.start();
PropertyUtils.copyProperties(personDTO, personDO);
stopwatch.stop();
System.out.println("mappingByApachePropertyUtils cost :" + stopwatch.getTotalTimeMillis());
public static void main(String[] args)
PersonDO personDO = new PersonDO();
personDO.setName("Hollis");
personDO.setAge(26);
personDO.setBirthday(new Date());
personDO.setId(1);
MapperTest mapperTest = new MapperTest();
mapperTest.mappingBySpringBeanUtils(personDO, 100);
mapperTest.mappingBySpringBeanUtils(personDO, 1000);
mapperTest.mappingBySpringBeanUtils(personDO, 10000);
mapperTest.mappingBySpringBeanUtils(personDO, 100000);
mapperTest.mappingBySpringBeanUtils(personDO, 1000000);
mapperTest.mappingByCglibBeanCopier(personDO, 100);
mapperTest.mappingByCglibBeanCopier(personDO, 1000);
mapperTest.mappingByCglibBeanCopier(personDO, 10000);
mapperTest.mappingByCglibBeanCopier(personDO, 100000);
mapperTest.mappingByCglibBeanCopier(personDO, 1000000);
mapperTest.mappingByApachePropertyUtils(personDO, 100);
mapperTest.mappingByApachePropertyUtils(personDO, 1000);
mapperTest.mappingByApachePropertyUtils(personDO, 10000);
mapperTest.mappingByApachePropertyUtils(personDO, 100000);
mapperTest.mappingByApachePropertyUtils(personDO, 1000000);
mapperTest.mappingByApacheBeanUtils(personDO, 100);
mapperTest.mappingByApacheBeanUtils(personDO, 1000);
mapperTest.mappingByApacheBeanUtils(personDO, 10000);
mapperTest.mappingByApacheBeanUtils(personDO, 100000);
mapperTest.mappingByApacheBeanUtils(personDO, 1000000);
工具类 | 执行1000次耗时 | 执行10000次耗时 | 执行100000次耗时 | 执行1000000次耗时 |
Spring BeanUtils | 5ms | 10ms | 45ms | 169ms |
Cglib BeanCopier | 4ms | 18ms | 45ms | 91ms |
Apache PropertyUtils | 60ms | 265ms | 1444ms | 11492ms |
Apache BeanUtils | 138ms | 816ms | 4154ms | 36938ms |
Dozer | 566ms | 2254ms | 11136ms | 102965ms |
画了一张折线图更方便大家进行对比
<!--Apache PropertyUtils、Apache BeanUtils-->
<dependency>
<groupId>commons-beanutils</groupId>
<artifactId>commons-beanutils</artifactId>
<version>1.9.4</version>
</dependency>
<dependency>
<groupId>commons-logging</groupId>
<artifactId>commons-logging</artifactId>
<version>1.1.2</version>
</dependency>
<!--Spring PropertyUtils-->
<dependency>
<groupId>org.springframework</groupId>
<artifactId>org.springframework.beans</artifactId>
<version>3.1.1.RELEASE</version>
</dependency>
<!--cglib-->
<dependency>
<groupId>cglib</groupId>
<artifactId>cglib-nodep</artifactId>
<version>2.2.2</version>
</dependency>
<!--dozer-->
<dependency>
<groupId>net.sf.dozer</groupId>
<artifactId>dozer</artifactId>
<version>5.5.1</version>
</dependency>
<!--日志相关-->
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.7.7</version>
</dependency>
<dependency>
<artifactId>jul-to-slf4j</artifactId>
</dependency>
<dependency>
<artifactId>jcl-over-slf4j</artifactId>
</dependency>
<dependency>
<artifactId>log4j-over-slf4j</artifactId>
</dependency>
<dependency>
<artifactId>slf4j-jdk14</artifactId>
</dependency>
喜欢本文的朋友,欢迎关注公众号 程序员小灰,收看更多精彩内容
点个[在看],是对小灰最大的支持!
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
