C语言#和##连接符在项目中的应用(漂亮)
之前看见ST官方一个老外的风格,看完之后大赞。看看他是怎么写的:
#ifndef RINGBUFF_HDR_H
#define RINGBUFF_HDR_H
#ifdef __cplusplus
extern "C" {
#endif
#include <string.h>
#include <stdint.h>
* \defgroup RINGBUFF Ring buffer
* \brief Generic ring buffer manager
/* --- Buffer unique part starts --- */
* \brief Buffer function/typedef prefix string
* It is used to change function names in zero time to easily re-use same library between applications.
* Use `#define BUF_PREF(x) my_prefix_ ## x` to change all function names to (for example) `my_prefix_buff_init`
* \note Modification of this macro must be done in header and source file aswell
#define BUF_PREF(x) ring ## x
/* --- Buffer unique part ends --- */
* \brief Buffer structure
typedef struct {
uint8_t* buff; /*!< Pointer to buffer data.
Buffer is considered initialized when `buff != NULL` and `size` */
size_t size; /*!< Size of buffer data. Size of actual buffer is `1` byte less than value holds */
size_t r; /*!< Next read pointer. Buffer is considered empty when `r == w` and full when `w == r - 1` */
size_t w; /*!< Next write pointer. Buffer is considered empty when `r == w` and full when `w == r - 1` */
} BUF_PREF(buff_t);
uint8_t BUF_PREF(buff_init)(BUF_PREF(buff_t)* buff, void* buffdata, size_t size);
void BUF_PREF(buff_free)(BUF_PREF(buff_t)* buff);
void BUF_PREF(buff_reset)(BUF_PREF(buff_t)* buff);
/* Read/Write functions */
size_t BUF_PREF(buff_write)(BUF_PREF(buff_t)* buff, const void* data, size_t btw);
size_t BUF_PREF(buff_read)(BUF_PREF(buff_t)* buff, void* data, size_t btr);
size_t BUF_PREF(buff_peek)(BUF_PREF(buff_t)* buff, size_t skip_count, void* data, size_t btp);
/* Buffer size information */
size_t BUF_PREF(buff_get_free)(BUF_PREF(buff_t)* buff);
size_t BUF_PREF(buff_get_full)(BUF_PREF(buff_t)* buff);
/* Read data block management */
void * BUF_PREF(buff_get_linear_block_read_address)(BUF_PREF(buff_t)* buff);
size_t BUF_PREF(buff_get_linear_block_read_length)(BUF_PREF(buff_t)* buff);
size_t BUF_PREF(buff_skip)(BUF_PREF(buff_t)* buff, size_t len);
/* Write data block management */
void * BUF_PREF(buff_get_linear_block_write_address)(BUF_PREF(buff_t)* buff);
size_t BUF_PREF(buff_get_linear_block_write_length)(BUF_PREF(buff_t)* buff);
size_t BUF_PREF(buff_advance)(BUF_PREF(buff_t)* buff, size_t len);
#undef BUF_PREF /* Prefix not needed anymore */
#ifdef __cplusplus
#endif
#endif /* RINGBUFF_HDR_H */
这个老外实现的是一个环形缓冲,然而他巧妙的将ring这个字串去掉,最后阅读代码看到的是非常整齐的:
BUF_PREF(buffer_init)
BUF_PREF(buff_free)
BUF_PREF(buff_read)
等等。。。
接下来看看到底是怎么用的:
"##" 表示将左边的字符串和右边的字符串连接起来,但是只能黏贴C语言除了关键字以外的合法标识符 于是上面展开的效果如下:
ring_buffer_init
ring_buffer_free
ring_buffer_write
ring_buffer_read
等等。。。
既然知道了原理,那我在项目上可以这么来用。
之前,你写个LED驱动或者别的可能是这样的,定义了这么多个函数
void led_device_open(void);
void led_device_close(void);
uint8_t led_device_read(void);
uint8_t led_device_write(uint8_t status);
看起来很统一,我一眼看出这是一个LED的操作方法,但操作一个LED不就是open,close,read,write方法吗?
我们可以让它看起来更优雅:
#define LED_CLASS(x) led_device_ ## x
void LED_CLASS(open)(void);
void LED_CLASS(close)(void);
uint8_t LED_CLASS(read)(void);
uint8_t LED_CLASS(write)(uint8_t status);
如果我写另外一个驱动,也是一样有open,close,read,write接口,假设是个FLASH设备。那还是一样的:
#define FLASH_CLASS(x) flash_device_ ## x
void FLASH_CLASS(open)(void);
void FLASH_CLASS(close)(void);
uint8_t FLASH_CLASS(read)(void);
uint8_t FLASH_CLASS(write)(uint8_t status);
看起来舒服多了!Good!
那么##和#又有什么区别呢?
##刚刚已经说了,是黏贴字符串
而#表示的是将参数转换为字符串
下面写一个跟#相关的例子:
#include <stdio.h>
#define Print(x) printf("%s %d\n",#x,x);
int main(void)
Print(100);
return 0 ;
运行结果:
公众号粉丝福利时刻
这里我给大家申请到了福利,本公众号读者购买小熊派开发板可享受9折优惠,有需要购买小熊派的朋友,淘宝搜索即可,跟客户说你是公众号:嵌入式云IOT技术圈 的粉丝,立享9折优惠!
往期精彩
C语言字符串的另类用法
别瞎找了,你要的C语言经典示例都在这~
C语言表驱动法编程实践(精华帖,建议收藏并实践)
嵌入式C语言代码优化方案(深度好文,建议花时间研读并收藏)
若觉得本次分享的文章对您有帮助,随手点[在看]
并转发分享,也是对我的支持。
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
