STM32硬核DIY机械键盘|蓝牙USB双模|灯控
项目起因
想
项目简介
为什么叫创世一号(WorldEdit)呢?因为想着以后用这把键盘,闯荡天下,制造更多东西,就像一个创世神一样,所以就叫创世一号WorldEdit了
创世一号采用STM32F103RCT6主控,整合有锂电池充放电管理,稳压,蓝牙串口HID,USB-HID,LED灯阵列驱动,按键检测电路。可实现蓝牙连接模式(支持IOS、Android等平台),和USB连接模式。蓝牙连接时响应时间约15ms,USB连接模式主控响应时间约为0.3Ms。
靓照如下:
一、准备材料阶段
1.键盘配列
首先做机械键盘,需要了解键盘的配列。制作配列有很多工具可以用,我们在这一步需要把定位板的CAD图生成,用到以下两个网站:
配列编辑网站: http://www.keyboard-layout-editor.com/
定位板CAD生成网站:
http://builder.swillkb.com/
如果要做的配列和我的一样,可以直接使用我的配列CAD文件,我要做的配列如下:(这个网站可以很方便的修改配列,网上教程已经很多了,我就不详细介绍了)
然后将你的配列的Raw data复制到CAD生成网站。生成CAD定位板文件 (该文件在画PCB和键盘外壳都需要用到)
然后底下的这些是和轴体有关的,一般来说默认就行了。
点击
生成文件,然后点击右上DXF并将文件下载保存。
到这里,键盘配列就完成了。然后去网上冲浪 淘一淘 , 买键帽、蓝牙HID模块、主控啊、一些电容电阻啊、锂电池啊、等等需要用到的东西。
2. 元器件、模块、电池、轴体、键帽等采购
我的整个键盘需要的物品清单如下:
器件购买完毕后,就可以开始画电路了(不会的可以用我的PCB去加工,我100元做了5张PCB)由于整个项目都已开源,这里就不介绍具体电路了。
然后是设计外壳。由于没有加工条件,只能网上订制,所以就简单的设计了一个不包底的钢板做框架。最后成品也还可以。
二、组装调试
以上都准备完成后,就是焊电路,装轴,上键帽了。具体步骤,可以看我的制作视频。
三、优化程序代码
代码部分的思路就是检查键盘消息是否更新,更新了就生成按键数据包,然后串口传输给蓝牙模块。如果是USB模式的话就直接USB发送给电脑主机。按键物理上如何快速与程序代码链接起来呢,这里有一个思路,如果有更好的方法或建议请留言或私信,谢谢啦。这里将按键的位置与数组的顺序对应了起来,在后面处理按键消息的时候用起来很方便。
#define xxCK myKeyBoard_ControlKey
#define xxSK myKeyBoard_SpecialKey
const char * myKeyBoard_KeyMap_Name[6][16] =
"Esc","F1","F2","F3","F4","F5","F6","F7","F8","F9","F10","F11","F12","PrtSc","ScrollLock","PauseBreak",
"~","!","@","#","$","%","^","&","*","(",")","-","+","BackSpace","Insert","Home",
"Tab","Q","W","E","R","T","Y","U","I","O","P","{","}","|","Delete","End",
"CapsLock","A","S","D","F","G","H","J","K","L",";","'","Enter","","","PageUp",
"LShift","Z","X","C","V","B","N","M",",",".","/","RShift","Up","","","PageDown",
"LCtrl","Win","LAlt","Space","RAlt","FN","Menu","RCtrl","Left","Down","Right","","","","",""
const unsigned char myKeyBoard_KeyMap_ATValue[6][16] =
0x29,0x3A,0x3B,0x3C,0x3D,0x3E,0x3F,0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,
0x35,0x1E,0x1F,0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x2D,0x2E,0x2A,0x49,0x4A,
0x2B,0x14,0x1A,0x08,0x15,0x17,0x1C,0x18,0x0C,0x12,0x13,0x2F,0x30,0x31,0x4C,0x4D,
0x39,0x04,0x16,0x07,0x09,0x0A,0x0B,0x0D,0x0E,0x0F,0x33,0x34,0x28,0x00,0x00,0x4B,
xxCK,0x1D,0x1B,0x06,0x19,0x05,0x11,0x10,0x36,0x37,0x38,xxCK,0x52,0x00,0x00,0x4E,
xxCK,xxCK,xxCK,0x2C,xxCK,xxSK,xxSK,xxCK,0x50,0x51,0x4F,0x00,0x00,0x00,0x00,0x00,
main 函数如下:(具体代码已开源至GitHub)
int main()
sysInit();
//BTK05_Wake();//唤醒BTK05
while(1)
if(g_USBModeFlag)//USB模式下
if(sleepTime1SCounter <= 1000)
myKeyBoard_ScanKeyAndUpdataATBuffer();//键盘事件更新
if(g_myKeyBoard_DataWaitForUploadFlag == 1)
g_myKeyBoard_DataWaitForUploadFlag = 0;
if(bDeviceState == CONFIGURED)//如果连接上了 USB
Keyboard_Send(BTK05_ATKeyDataPack+4);
GPIO_SetBits(LED_LOGO_GPIOPort,LED_LOGO_GPIOPin);
else if(system_Status == 0)
system_Status = 1;
TIM_Cmd(TIM2, ENABLE); //使能TIMx
sleepTime1SCounter = 0;
if(LED_Status) LED_WakeUp();
else if(sleepTime1SCounter > 1000)
TIM_Cmd(TIM2, DISABLE); //失能TIMx
system_Status = 0;
LED_GoToSleep();
else//蓝牙模块模式
//如果键盘休眠计时器小于400并且键盘处于醒着的状态
if(sleepTime1SCounter <= 400 && BTK05_Status == BTK_WAKE)
//GPIO_ResetBits(LED_LOGO_GPIOPort,LED_LOGO_GPIOPin);
BTK05_UART_SendKeyData(BTK05_ATKeyDataPack,12);
if(ATKeyControlByte5 != 0)
else
//如果蓝牙处于休眠状态
else if(BTK05_Status == BTK_SLEEP)
system_Status = 1;
//如果 键盘休眠计时器大于600 即600S没有按下任何按键则然键盘进入休眠状态
else if(sleepTime1SCounter > 400)
//进入休眠模式...
BTK05_Sleep();//休眠BTK05
system_Status = 0;
LED_GoToSleep();
if(LED_BreathEfectFlag && LED_breath_Flag)
LED_BreathProcess();
LED_breath_Flag = 0;
Github:
https://github.com/firestaradmin/WorldEdit-No.1
项目制作全过程视频BiliBili:
https://www.bilibili.com/video/av81005730#reply2225849370
往期精彩
MCU串口命令解析器的实现
深圳云之手科技开源炫酷RGB灯板DIY项目
一个超火超给力的STM32开源疫情监控项目
云之手红外式测温计产品设计分享(基于合泰BH67F2752方案)
觉得本次分享的文章对您有帮助,随手点[在看]
并转发分享,也是对我的支持。
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
