当前位置:首页 > 公众号精选 > 程序喵大人
[导读]大家平时工作,如果有计算函数耗时或者打印当前时间的需求,一定要来看看这篇文章!
首先介绍下C++标准中的chrono
chrono是一个关于时间的库,起源于boost,现在是C++的标准,话说现在的C++标准好多都是源于boost,要进标准的特性似乎都会先在boost试验一番。
首先看一下使用chrono简单计时的示例代码:
void func() { // 计时 std::chrono::time_point<std::chrono::high_resolution_clock> begin = high_resolution_clock::now(); std::this_thread::sleep_for(std::chrono::milliseconds(20)); auto end = high_resolution_clock::now(); cout << "time " << duration_cast(end - begin).count() << endl;}
chrono中有三个概念duration、time_point、clock
duration:表示一段时间,三分钟、三秒等,它的定义如下:
template <class _Rep, class _Period = ratio<1>> class duration;
ratio的定义如下:
 template <intmax_t N, intmax_t D = 1> class ratio;
Rep表示数据类型,int,long等,Period表示时间单位,N是分子,D是分母,直接看例子吧:
using atto = ratio<1, 1000000000000000000LL>;using femto = ratio<1, 1000000000000000LL>;using pico = ratio<1, 1000000000000LL>;using nano = ratio<1, 1000000000>;using micro = ratio<1, 1000000>;using milli = ratio<1, 1000>;using centi = ratio<1, 100>;using deci = ratio<1, 10>;using deca = ratio<10, 1>;using hecto = ratio<100, 1>;using kilo = ratio<1000, 1>;using mega = ratio<1000000, 1>;using giga = ratio<1000000000, 1>;using tera = ratio<1000000000000LL, 1>;using peta = ratio<1000000000000000LL, 1>;using exa = ratio<1000000000000000000LL, 1>;
using nanoseconds = duration<long long, nano>;using microseconds = duration<long long, micro>;using milliseconds = duration<long long, milli>;using seconds = duration<long long>;using minutes = duration<int, ratio<60>>;using hours = duration<int, ratio<3600>>;
using hours2 = duration<int, ratio<3600, 1>>;using hours2 = duration<int, ratio<7200, 2>>;
详细看完上述例子您也明白了,ratio的默认的时间单位是1秒,以小时为例,一小时等于3600秒,3600 / 1 == 7200 / 2 == 3600,所以hours == hours2 == hours3。
标准库还提供了duration_cast用于转换各种duration。
template <class _To, class _Rep, class _Period, enable_if_t<_Is_duration_v<_To>, int> = 0> constexpr _To duration_cast(const duration<_Rep, _Period>&) noexcept( is_arithmetic_v<_Rep>&& is_arithmetic_v);
template <class _Ty> _INLINE_VAR constexpr bool _Is_duration_v = _Is_specialization_v<_Ty, duration>;
template <class _Ty>_INLINE_VAR constexpr bool is_arithmetic_v = // determine whether _Ty is an arithmetic type is_integral_v<_Ty> || is_floating_point_v<_Ty>;
函数看着很繁琐,直接看看示例代码吧:
void func() { auto sec = std::chrono::seconds(10); auto mill = std::chrono::duration_cast<std::chrono::milliseconds>(sec); cout << sec.count() << endl; // 返回多少s cout << mill.count() << endl; // 返回多少ms}输出:1010000
time_point:用来表示某个具体时间点。
定义如下:
template <class _Clock, class _Duration = typename _Clock::duration> class time_point;
使用方式如下:
void func() { std::chrono::time_point<std::chrono::system_clock, std::chrono::milliseconds> tp(std::chrono::seconds(12)); cout << tp.time_since_epoch().count() << endl; std::time_t t = system_clock::to_time_t(tp); cout << "time " << ctime(&t) << endl;}输出:12000time Thu Jan 1 08:00:12 1970
这里有个函数time_since_epoch(),表示这个time_point距离元年也就是1970年1月1日所经过的duration。
time_point也有各种表示方式,类似于duration,也提供了转换函数time_point_cast()。
void func() { time_point tp(seconds(12)); cout << tp.time_since_epoch().count() << endl; time_point tp2 = time_point_cast(tp); cout << tp2.time_since_epoch().count() << endl;}输出:1200012
Clocks
这里的时钟大体有三种:
system_clock
steady_clock
system_clock表示当前的系统时钟,有三个函数:
now():表示当前时间的time_pointto_time_t():将time_point转换成time_t秒from_time_t():将time_t转换成time_point
源码如下:
struct system_clock { // wraps GetSystemTimePreciseAsFileTime/GetSystemTimeAsFileTime using rep = long long;
using period = ratio_multiply1>, nano>;
using duration = chrono::duration; using time_point = chrono::time_point; static constexpr bool is_steady = false;
_NODISCARD static time_point now() noexcept { // get current time return time_point(duration(_Xtime_get_ticks())); }
_NODISCARD static __time64_t to_time_t(const time_point& _Time) noexcept { // convert to __time64_t return static_cast<__time64_t>(_Time.time_since_epoch().count() / _XTIME_TICKS_PER_TIME_T); }
_NODISCARD static time_point from_time_t(__time64_t _Tm) noexcept { // convert from __time64_t return time_point(duration(_Tm * _XTIME_TICKS_PER_TIME_T)); }};
steady_clock表示稳定的时钟,它只有一个函数,就是now(),后一次调用now()肯定比上一次调用now()的返回值大,不受系统时间修改的影响。
源码如下:
struct steady_clock { // wraps QueryPerformanceCounter using rep = long long; using period = nano; using duration = nanoseconds; using time_point = chrono::time_point; static constexpr bool is_steady = true;
_NODISCARD static time_point now() noexcept { // get current time const long long _Freq = _Query_perf_frequency(); // doesn't change after system boot const long long _Ctr = _Query_perf_counter(); static_assert(period::num == 1, "This assumes period::num == 1."); const long long _Whole = (_Ctr / _Freq) * period::den; const long long _Part = (_Ctr % _Freq) * period::den / _Freq; return time_point(duration(_Whole + _Part)); }};
使用方式和之前的都相同:
void func() { // 计时 std::chrono::time_point<std::chrono::steady_clock> begin = steady_clock::now(); std::this_thread::sleep_for(std::chrono::milliseconds(20)); auto end = steady_clock::now(); cout << "time " << duration_cast(end - begin).count() << endl;}
high_resolution_clock表示高精度时钟,是系统可用的最高精度的时钟,它其实就是system_clock或者steady_clock的别名:
using high_resolution_clock = steady_clock;
介绍完了C++的chrono那下面再看下C语言的各种时间相关的API吧:
首先可以通过C语言的clock拿到程序执行时处理器所使用的时钟数来计时:
clock_t clock(void);
该函数返回程序执行起(一般为程序的开头),处理器时钟所使用的时间。也获取 CPU 所使用的秒数,除以 CLOCKS_PER_SEC即可,返回的clock_t其实就是long类型的重命名。
使用方式如下:
void func() { clock_t start_t = clock(); cout << start_t << " 个时钟 \n"; for (int i = 0; i < 100000000; i++) { } clock_t end_t = clock(); cout << end_t << " 个时钟 \n"; cout << "循环的秒数:" << (double)(end_t - start_t) / CLOCKS_PER_SEC << endl;}
如何获取当前时间戳,单位为秒
void func() { // 获取当前时间戳,单位为秒 struct timeval time; gettimeofday(&time, NULL); cout << time.tv_sec << " s \n";}
也可以使用time函数:
time_t time(time_t *time);
该函数返回系统的当前日历时间,返回的是自1970年1月1日以来所经过的秒数。
time_t其实就是一个整数类型,是int64_t的重命名,该函数直接使用返回值就好,参数一般传空即可。
timer 存取结果的时间指针变量,类型为time_t,指针变量可以为null。
如果timer指针非null,则time()函数返回值变量与timer指针一样,都指向同一个内存地址;
否则如果timer指针为null,则time()函数返回一个time_t变量时间。
void func() { // 获取当前时间戳,单位为秒 time_t now = time(NULL); cout << static_cast<int64_t>(now) << " s \n";}
如何获取当前时间戳?单位为毫秒
void func() { // 获取当前时间戳,单位为毫秒 struct timeval time; gettimeofday(&time, NULL); cout << time.tv_sec * 1000 + time.tv_usec / 1000 << " ms \n";}
如何显示当前的系统时间呢?可以使用ctime显示当前时间:
char* ctime(const time_t* time);
该函数返回一个表示当地时间的字符串指针,输出内容格式如下:
day month year hours:minutes:seconds year\n\0。
示例代码如下:
void func() { time_t now = time(NULL); char* dt = ctime(&now); cout << "cur time is: " << dt;}输出:Tue Sep 22 22:01:40 2020
可以使用tm结构自定义显示当前时间的格式:
struct tm * localtime(const time_t * timer);
将日历时间转换为本地时间,从1970年起始的时间戳转换为1900年起始的时间数据结构
另一个类似的函数是gmtime函数:
struct tm *gmtime(const time_t *time);
只是该函数返回的是UTC时间,协调世界时(UTC)也被称为格林尼治标准时间(GMT)。
tm结构如下:
struct tm { int tm_sec; // 秒,正常范围从 0 到 59,但允许至 61 int tm_min; // 分,范围从 0 到 59 int tm_hour; // 小时,范围从 0 到 23 int tm_mday; // 一月中的第几天,范围从 1 到 31 int tm_mon; // 月,范围从 0 到 11 int tm_year; // 自 1900 年起的年数 int tm_wday; // 一周中的第几天,范围从 0 到 6,从星期日算起 int tm_yday; // 一年中的第几天,范围从 0 到 365,从 1 月 1 日算起 int tm_isdst; // 夏令时};
tm_sec 在C89的范围是[0-61],在C99更正为[0-60]。通常范围是[0-59],貌似有些系统会出现60秒的跳跃。
tm_mon 是从零开始的,所以一月份为0,十二月份为11。
tm_year是从1900年开始计算,所以显示年份的时候需要加上1900
void func() { time_t rawtime = time(NULL); struct tm* ptminfo = localtime(&rawtime); printf("cur time is: %02d-%02d-%02d %02d:%02d:%02d\n", ptminfo->tm_year + 1900, ptminfo->tm_mon + 1, ptminfo->tm_mday, ptminfo->tm_hour, ptminfo->tm_min, ptminfo->tm_sec); ptminfo = gmtime(&rawtime); printf("cur time is: %02d-%02d-%02d %02d:%02d:%02d\n", ptminfo->tm_year + 1900, ptminfo->tm_mon + 1, ptminfo->tm_mday, ptminfo->tm_hour, ptminfo->tm_min, ptminfo->tm_sec);}输出:cur time is: 2020-09-23 21:27:37cur time is: 2020-09-23 13:27:37
可以通过asctime显示tm结构的时间:
char * asctime ( const struct tm * time );
和ctime类似,返回的都是一个固定时间格式的字符串,只是传入的参数不同。
void func() { time_t rawtime = time(NULL); struct tm* info1 = localtime(&rawtime); cout << "正常 日期和时间:" << asctime(info1) << endl; info1 = gmtime(&rawtime); cout << "UTC 日期和时间:" << asctime(info1) << endl;}输出:正常 日期和时间:Wed Sep 23 21:47:44 2020UTC 日期和时间:Wed Sep 23 13:47:44 2020
也可以使用strftime()函数,该函数可用于格式化日期和时间为指定的格式,如果产生的 C 字符串小于 size 个字符(包括空结束字符),则会返回复制到 str 中的字符总数(不包括空结束字符),否则返回零。
size_t strftime( char *str, // 指向目标数组的指针,用来复制产生的C字符串 size_t maxsize, // 最多传出字符数量 const char *format, // 格式化方式 const struct tm *timeptr // tm指针);
format格式如下:
%a 星期几的缩写%A 星期几的全称%b 月份的缩写%B 月份的全称%c 标准的日期的时间串%C 年份的前两位数字%d 十进制表示的每月的第几天(值从1到31)%D 月/天/年%e 在两字符域中,十进制表示的每月的第几天%F 年-月-日%g 年份的后两位数字,使用基于周的年%G 年份,使用基于周的年%h 简写的月份名%H 24小时制的小时(值从0到23)%I 12小时制的小时(值从1到12)%j 十进制表示的每年的第几天(值从1到366)%m 十进制表示的月份(值从1到12)%M 十时制表示的分钟数(值从0到59)%n 换行符%p 本地的AM或PM的等价显示%r 12小时的时间%R 显示小时和分钟:hh:mm%S 十进制的秒数(值从0到61)%t 水平制表符%T 显示时分秒:hh:mm:ss%u 每周的第几天,星期一为第一天 (值从1到7,星期一为1)%U 第年的第几周,把星期日作为第一天(值从0到53)%V 每年的第几周,使用基于周的年%w 十进制表示的星期几(值从0到6,星期天为0)%W 每年的第几周,把星期一做为第一天(值从0到53)%x 标准的日期串%X 标准的时间串%y 不带世纪的十进制年份(值从0到99)%Y 带世纪部分的十制年份%Z 时区名称,如果不能得到时区名称则返回空字符。%% 一个%符号
使用代码如下:
void func() { time_t rawtime = time(NULL); char buf[256]; strftime(buf, sizeof(buf), "%Y-%m-%d %H:%M:%S", localtime(&rawtime)); cout << buf << endl;}
参考资料:
https://www.runoob.com/cprogramming/c-function-strftime.html
https://www.runoob.com/cprogramming/c-function-clock.html
https://www.runoob.com/cplusplus/cpp-date-time.html
https://www.cnblogs.com/jwk000/p/3560086.html
往期推荐
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
