代码优化导致的奇葩问题
这个是今天在微信群里讨论的一个问题,先看图片
代码流程大概是这个样子的
查看 length
和 space1
的值,明显看到 length
小于 space1
的值,即使是这样小白都能搞懂流程的情况下,代码还是跑到else里面区执行
然后 我们就在群里讨论,有的大神说这个是内存越界
,也有大神说可能是人品有问题,也有大神说这个是因为写代码前没有选好一个良辰吉日,反正大家想法都非常多,也非常古怪,这可能就是讨论群存在的一个原因了。
经过不断的验证,发现这个问题是因为编译器优化的问题
如果在设置里面把优化选项去掉代码就执行正确
当然还有一个问题,就是如果我想开启优化,毕竟代码太大占用的存储空间是很大的,如果能节省点空间是最好的了。所以就出现了一种,只针对某些代码不优化的设置
像这样
我们使用GCC编译的时候,也是有可能因为代码优化导致这样的问题的,庆幸的是,GCC也有设置不进行优化的开关。
#使用GCC编译器设置选择性不优化某段代码
#pragma GCC push_options
#pragma GCC optimize ("O0")
#pragma GCC pop_options
push 的意思是把当前的编译优化选项压栈,然后再设置当前的优化选项,之后再出栈,把之前压栈的选项提取出来。
具体可以参考链接:
https://gcc.gnu.org/onlinedocs/gcc-4.4.2/gcc/Function-Specific-Option-Pragmas.html
链接里面还介绍了一些其他的用法,原文如下
5.52.12 Function Specific Option Pragmas
#pragma GCC target ("string"...)
This pragma allows you to set target specific options for functions defined later in the source file. One or more strings can be specified. Each function that is defined after this point will be as if attribute((target("STRING"))) was specified for that function. The parenthesis around the options is optional. See Function Attributes, for more information about the target attribute and the attribute syntax.
The `#pragma GCC target' pragma is not implemented in GCC versions earlier than 4.4, and is currently only implemented for the 386 and x86_64 backends.
#pragma GCC optimize ("string"...)
This pragma allows you to set global optimization options for functions defined later in the source file. One or more strings can be specified. Each function that is defined after this point will be as if attribute((optimize("STRING"))) was specified for that function. The parenthesis around the options is optional. See Function Attributes, for more information about the optimize attribute and the attribute syntax.
The `#pragma GCC optimize' pragma is not implemented in GCC versions earlier than 4.4.
These pragmas maintain a stack of the current target and optimization options. It is intended for include files where you temporarily want to switch to using a different `#pragma GCC target' or `#pragma GCC optimize' and then to pop back to the previous options.
The `#pragma GCC push_options' and `#pragma GCC pop_options' pragmas are not implemented in GCC versions earlier than 4.4.
#pragma GCC reset_options
This pragma clears the current #pragma GCC target and #pragma GCC optimize to use the default switches as specified on the command line.
The `#pragma GCC reset_options' pragma is not implemented in GCC versions earlier than 4.4.
#当然还有指定某个函数设置优化等级
int max(int a, int b) __attribute__((optimize("O0")));
return a < b ? a : b;
#使用volatile 关键字避免编译器优化
volatile 的作用是提醒CPU,如果遇到被volatile 修饰的变量,要从内存里面去取值,而不要偷懒,直接从缓存里面取值,我们一般是用在那些被中断处理函数使用的那些变量。
如果有些代码,你不希望CPU偷懒,那你就可以加上volatile ,让CPU从内存取数据。
CSDN上有这样一个例子
https://blog.csdn.net/qq_28637193/article/details/88988951
今天碰到一个gcc优化相关的问题,为了让一个页变成脏页(页表中dirty位被置上),需要执行下面这段代码:
1 uint32_t *page;
2 // ...
3 page[0] = page[0];
最后一行代码很有可能被gcc优化掉,因为这段代码看起来没有任何实际的作用。那么如何防止gcc对这段代码做优化呢?
设置gcc编译时优化级别为-O0肯定是不合适的,这样对程序性能影响会比较大。stackoverflow上的Dietrich Epp给出了一个强制类型转换的方案:
((unsigned char volatile *)page)[0] = page[0];
通过volatile关键字禁止gcc的优化
#总结、什么情况会导致这样的问题?
1、堆栈溢出应该是一个原因,之前我有遇到的情况是栈空间设置太小,然后溢出到堆空间导致问题。
2、使用某个函数导致溢出,我们使用的函数,比如,内存拷贝函数
,如果长度设置不对,也会导致影响到其他的代码。
3、还有就是上面说的编译器优化导致的问题。
原创不易,欢迎转发、留言、点赞、分享给你的朋友,感谢您的支持!
长按识别二维码关注获取更多内容
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
