Python中的3D绘图命令
很多情况下,为了能够观察到数据之间的内部的关系,可以使用绘图来更好的显示规律。
比如在下面的几张动图中,使用matplotlib中的三维显示命令,使得我们可以对于logistic回归网络的性能与相关参数有了更好的理解。
下面的动图显示了在训练网络时,不同的学习速率对于算法收敛之间的影响。
下面给出了绘制这些动态曲线的相关的python指令:
01 3D plot
1.基本语法
在安装matplotlib之后,自动安装有 mpl_toolkits.mplot3d。
#Importing Libraries
import matplotlib.pyplot as plt
from mpl_toolkits.mplot3d import axes3d
#3D Plotting
fig = plt.figure()
ax = plt.axes(projection="3d")
#Labeling
ax.set_xlabel('X Axes')
ax.set_ylabel('Y Axes')
ax.set_zlabel('Z Axes')
plt.show()
2.Python Cmd
使用pythoncmd 插入相应的语句。
3.举例
(1) Ex1
#!/usr/local/bin/python
# -*- coding: gbk -*-
# TEST2.PY -- by Dr. ZhuoQing 2020-11-16
# Note:
from headm import *
ax = plt.axes(projection='3d')
x = [1,2,3,4,5,6,7,8,9]
y = [2,3,4,6,7,8,9,5,1]
z = [5,6,2,4,8,6,5,6,1]
ax.plot3D(x,y,z)
plt.show()
# END OF FILE : TEST2.PY
(2) Ex2
angle = linspace(0, 2*pi*5, 400)
x = cos(angle)
y = sin(angle)
z = linspace(0, 5, 400)
ax.plot3D(x,y,z)
plt.show()
(3) Ex3
import matplotlib as mpl
from mpl_toolkits.mplot3d import Axes3D
import numpy as np
mpl.rcParams['legend.fontsize'] = 10
fig = plt.figure()
ax = fig.gca(projection='3d')
theta = np.linspace(-4 * np.pi, 4 * np.pi, 100)
z = np.linspace(-2, 2, 100)
r = z**2 + 1
x = r * np.sin(theta)
y = r * np.cos(theta)
ax.plot(x, y, z, label='parametric curve')
ax.legend()
plt.show()
02 绘制Scatter
利用和上面的相同的绘制命令,将原来的plot3D修改成为 scatter即可。
angle = linspace(0, 2*pi*5, 40)
x = cos(angle)
y = sin(angle)
z = linspace(0, 5, 40)
ax.scatter(x,y,z, color='b')
plt.show()
03 绘制3D Surface
(1) Ex1
# Note:
from headm import *
x = arange(-5, 5, 0.1)
y = arange(-5, 5, 0.1)
x,y = meshgrid(x, y)
R = sqrt(x**2+y**2)
z = sin(R)
ax.plot_surface(x, y, z)
plt.show()
(2) 举例
3D surface (color map)
Demonstrates plotting a 3D surface colored with the coolwarm color map.
The surface is made opaque by using antialiased=False.
Also demonstrates using the LinearLocator and custom formatting for the
z axis tick labels.
from matplotlib import cm
from matplotlib.ticker import LinearLocator, FormatStrFormatter
import numpy as np
fig = plt.figure()
# Make data.
X = np.arange(-5, 5, 0.25)
Y = np.arange(-5, 5, 0.25)
X, Y = np.meshgrid(X, Y)
R = np.sqrt(X**2 + Y**2)
Z = np.sin(R)
# Plot the surface.
surf = ax.plot_surface(X, Y, Z, cmap=cm.coolwarm,
linewidth=0, antialiased=False)
# Customize the z axis.
ax.set_zlim(-1.01, 1.01)
ax.zaxis.set_major_locator(LinearLocator(10))
ax.zaxis.set_major_formatter(FormatStrFormatter('%.02f'))
# Add a color bar which maps values to colors.
fig.colorbar(surf, shrink=0.5, aspect=5)
plt.show()
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
