当前位置:首页 > 公众号精选 > 嵌入式微处理器
[导读]C语言字符串操作知识!
#字符串倒序输出
实现逻辑,通过strlen获取字符串长度,然后通过 len/2 进行交叉赋值,这里需要注意,不需要考虑len是奇数还是偶数的问题。
如果len是奇数,最后一个字符就不需要倒序,如果是偶数,最后两个字符就倒序。
#include "stdio.h"
void rechange_str(char *str)
 int i, len;
 char tmp;
 if (NULL == str) {
  return ;
 len = strlen(str);
 for (i = 0; i < len/2; i ++) {
  tmp = str[i];
  str[i] = str[len-i-1];
  str[len-i-1] = tmp;
int main(void)
 char str[20] = "hello,world";
 printf("%s\n",str);
 rechange_str(str);
 printf("%s\n",str);
 return (0);
程序输出
hello,world
dlrow,olleh
Process exited after 0.02841 seconds with return value 0
请按任意键继续. . .
#整型转字符串
实现逻辑,每个整数看其转换进制,从个位到十位百位都可以通过%操作加上/操作获得,再用一个字符数组保存0-F。
用个位数对应值转为字符,注意转换出的字符串是反向的,还要考虑传入的若是负数如何处理,再用翻转字符串完成最后整个操作
下面这段代码需要好好研究一下,最好自己运行试试。
#include "stdio.h"
char *sky_itoa(int value, char *str, unsigned int radix)
 char list[] = "0123456789ABCDEF";
 unsigned int tmp_value;
 int i, j, k;
 if (NULL == str) {
  return NULL;
 if (2 != radix && 8 != radix && 10 != radix && 16 != radix) {
  return NULL;
 i = 0;
 k = 0;
 if (radix == 10 && value < 0) {
  tmp_value = (unsigned int)(0 - value);
  str[i++] = '-';
  k = 1;
 } else {
  tmp_value = (unsigned int)value;
 do {
  str[i++] = list[tmp_value%radix];
  tmp_value /= radix;
 } while(tmp_value);
 str[i] = '\0';
 //翻转
 char tmp;
 for (j = k; j < (i+k)/2; j++) {
  tmp = str[j];
  str[j] = str[i+k-j-1];
  str[i+k-j-1] = tmp;
 return str;
int main(void)
 int a = 1254545;
 char str[100] ={0};
 printf("%s\n",sky_itoa(a,str,2));
 printf("%s\n",sky_itoa(a,str,8));
 printf("%s\n",sky_itoa(a,str,10));
 printf("%s\n",sky_itoa(a,str,16));
 return (0);
程序输出
100110010010010010001
4622221
1254545
132491
Process exited after 0.02963 seconds with return value 0
请按任意键继续. . .
#字符串复制
实现逻辑,逐个赋值直到遇到'\0'停止即可
#include "stdio.h"
char *sky_strcpy(char *dst, const char *str)
 if (NULL == dst ||  NULL == str) {
  return NULL;
 char *ret = dst;
 while (*str != '\0') {
  *dst ++ = *str ++;
 return ret;
int main(void)
 char str_1[100] = "hello,world";
 char str[100] ={0};
 sky_strcpy(str,str_1);
 printf("str_1:%s\n",str_1);
 printf("str:%s\n",str);
 return (0);
程序输出
str_1:hello,world
str:hello,world
Process exited after 0.03334 seconds with return value 0
请按任意键继续. . .
#字符串比较
1、正常比较是否相同 实现逻辑,判断字符串长度是否相同,若相同逐个比较字符是否相同
#include "stdio.h"
int sky_strcmp(char *dst, char *str)
 int i, len;
  return 0;
 if (strlen(dst) != strlen(str)) {
  return 0;
 len = strlen(dst);
 for (i = 0; i < len; i++) {
  if (*dst++ != *str++) {
   return 0;
 return 1;
int main(void)
 char str_2[100] = "hello,world";
 char str[100] = "adfs";
 printf("%d\n",sky_strcmp(str_1,str));
 printf("%d\n",sky_strcmp(str_1,str_2));
 return (0);
程序输出
Process exited after 0.02802 seconds with return value 0
请按任意键继续. . .
2、忽略大小写字符串比较
实现逻辑,在比较字符时可以将其统一转换为大写或小写,然后再进行比对即可,和正常对比无其他不同
 #include "stdio.h"
 #define CONVERT(c) (((c) >= 'A' && (c) <= 'Z') ? ((c) - 'A' + 'a') : (c))
  int i, len;
   return 0;
   return 0;
  len = strlen(dst);
   if (CONVERT(*dst) != CONVERT(*str)) {
    return 0;
   dst ++;
   str ++;
  return 1;
 int main(void)
  char str_1[100] = "heLlo,world";
  return (0);
程序输出
Process exited after 0.04624 seconds with return value 0
请按任意键继续. . .
#memcpy函数实现
实现逻辑,主要就是逐个赋值即可完成
1、不考虑拷贝覆盖问题
#include "stdio.h"
#include "string.h"
void *sky_memecpy(void *dst, const void *str, int n)
 if (NULL == dst || NULL == str || n <= 0) {
  return NULL;
 char *pdst = (char *)dst;
 char *pstr = (char *)str;
 while (n --) {
  *pdst ++ = *pstr ++;
 return dst;
int main(void)
 char str_2[100] = "sdfsdfs";
 sky_memecpy(str_2,str_1,strlen(str_1));
 printf("%s\n",str_2);
 return (0);
程序输出
heLlo,world
Process exited after 0.02516 seconds with return value 0
请按任意键继续. . .
2、考虑拷贝覆盖问题
拷贝覆盖是我们在拷贝字符串的时候需要注意的一个问题,我下面的示例程序,使用第一个函数的时候,就出现了问题,使用第二个函数就没有出现问题。
原因是,我们源字符串和目的字符串的地址都是一样的,我们希望把字符串往后移动一个位置,但是实际上出现了问题。
 #include "stdio.h"
 #include "string.h"
 void *sky_memecpy_1(void *dst, const void *str, int n)
   return NULL;
  while (n --) {
  return dst;
   return NULL;
  if (pdst > pstr && pdst < pstr + n) {
   pdst = pdst + n - 1;
   pstr = pstr + n - 1;
   while (n --) {
    *pdst -- = *pstr --;
  } else {
   while (n --) {
  return dst;
 int main(void)
  char str_2[100] = "heLlo,world";
  sky_memecpy_1(str_1+1,str_1,strlen(str_1));
  printf("%s\n",str_1);
  sky_memecpy(str_2+1,str_2,strlen(str_2));
  return (0);
程序输出
hhhhhhhhhhhh
hheLlo,world
Process exited after 0.02773 seconds with return value 0
请按任意键继续. . .
针对上面的拷贝覆盖问题,单独写了一个测试程序
#include "stdio.h"
#include "string.h"
  return NULL;
 while (n --) {
  printf("dst:%c--->str:%c\n",*pdst,*pstr);
 return dst;
int main(void)
 sky_memecpy(str_1+1,str_1,strlen(str_1));
 return (0);
程序输出
dst:e--->str:h
dst:L--->str:h
dst:l--->str:h
dst:o--->str:h
dst:,--->str:h
dst:w--->str:h
dst:o--->str:h
dst:r--->str:h
dst:l--->str:h
dst:d--->str:h
dst: --->str:h
hhhhhhhhhhhh
Process exited after 0.02575 seconds with return value 0
请按任意键继续. . .
初始的时候,dst指向 e 字符,str 指向h 字符,然后每次都是dst先移动,str再移动,就出现了dst被h字符所覆盖。
好了,就这些内容,希望大家好好消化,这些代码对面试很有帮助。
END
来源:嵌入式Linux
版权归原作者所有,如有侵权,请联系删除。
推荐阅读
飞机上一般是什么操作系统?
高速CAN、容错CAN、LIN总线有什么区别?
大佬终于把鸿蒙OS讲明白了,收藏了!
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
嵌入式ARM
扫描二维码,关注更多精彩内容
