RTOS支持STemWin(以RT-Thread为例)
之前在小熊派上移植过一个裸机版本的STemWin,耍了不少例程:
实战贴:STemWin在小熊派上的移植
1.获取项目:
git clone https://gitee.com/morixinguan/bear-pi.git
以下是其中一到两个裸机项目的显示效果:
2.渐变色条显示实验:
多文本控件实验:
后面计划在小熊派的屏幕上实现一个串口终端,支持RT-Thread的shell哈,那一定非常有趣!
目前RTOS的使用率越来越高,STemWin也提供了RTOS的配置模板:
源文件如下:
#include "GUI.h" /* FreeRTOS include files */ #include "cmsis_os.h" /*********************************************************************
* Global data
//定义一个互斥锁
static osMutexId osMutex;
//定义一个信号量
static osSemaphoreId osSemaphore;
* Timing:
* GUI_X_GetTime()
* GUI_X_Delay(int)
Some timing dependent routines require a GetTime
and delay function. Default time unit (tick), normally is
1 ms.
//获取Tick
int GUI_X_GetTime(void)
{ return ((int) xTaskGetTickCount());
//GUI延时函数
void GUI_X_Delay(int ms)
vTaskDelay( ms );
* GUI_X_Init()
* Note:
* GUI_X_Init() is called from GUI_Init is a possibility to init
* some hardware which needs to be up and running before the GUI.
* If not required, leave this routine blank.
//一般不填写
void GUI_X_Init(void) {
* GUI_X_ExecIdle
* Note:
* Called if WM is in idle state
//WM空闲状态接口
void GUI_X_ExecIdle(void) {}
* Multitasking:
* GUI_X_InitOS()
* GUI_X_GetTaskId()
* GUI_X_Lock()
* GUI_X_Unlock()
* Note:
* The following routines are required only if emWin is used in a
* true multi task environment, which means you have more than one
* thread using the emWin API.
* In this case the
* #define GUI_OS 1 * needs to be in GUIConf.h
//针对OS通信需要初始化的内容
/* Init OS */
void GUI_X_InitOS(void)
/* Create Mutex lock */
osMutexDef(MUTEX);
/* Create the Mutex used by the two threads */
osMutex = osMutexCreate(osMutex(MUTEX));
/* Create Semaphore lock */
osSemaphoreDef(SEM);
/* Create the Semaphore used by the two threads */
osSemaphore= osSemaphoreCreate(osSemaphore(SEM), 1);
//给出互斥量
void GUI_X_Unlock(void)
osMutexRelease(osMutex);
//获取互斥量
void GUI_X_Lock(void)
osMutexWait(osMutex , osWaitForever) ;
//获取当前线程句柄
/* Get Task handle */
U32 GUI_X_GetTaskId(void)
{ return ((U32) osThreadGetId());
//获取信号量
void GUI_X_WaitEvent (void)
osSemaphoreWait(osSemaphore , osWaitForever) ;
//释放信号量
void GUI_X_SignalEvent (void)
osMutexRelease(osSemaphore);
* Logging: OS dependent
Note:
Logging is used in higher debug levels only. The typical target
build does not use logging and does therefor not require any of
the logging routines below. For a release build without logging
the routines below may be eliminated to save some space.
(If the linker is not function aware and eliminates unreferenced functions automatically)
//LOG相关,一般不实现
void GUI_X_Log (const char *s) { }
void GUI_X_Warn (const char *s) { }
void GUI_X_ErrorOut(const char *s) { }
/*************************** End of file ****************************/
那么如何用RT-Thread的接口来代替呢??只要按照要求实现如下常用的接口就行了,其它不常用的就不用管:
int GUI_X_GetTime(void);
void GUI_X_Delay(int ms);
void GUI_X_Init(void);
void GUI_X_ExecIdle(void);
void GUI_X_InitOS(void);
void GUI_X_Unlock(void);
void GUI_X_Lock(void);
U32 GUI_X_GetTaskId(void) ;
void GUI_X_WaitEvent (void) ;
void GUI_X_SignalEvent (void) ;
void GUI_X_Log (const char *s);
void GUI_X_Warn (const char *s);
void GUI_X_ErrorOut(const char *s);
于是,我们复制GUI_X_OS这个文件,然后改名为GUI_X_RT_Thread,也就相当于定义了一个基于RT-Thread的配置模板,然后基于新的配置模板对一些接口的实现和修改:
然后只要按照要求实现以下常用的接口就行了:
接下来对文件的内容进行修改:
包含对应的头文件
/* RT-Thread include files */
//#include "cmsis_os.h" #include
将全局变量定义进行修改
//static osMutexId osMutex;
//static osSemaphoreId osSemaphore;
/*定义一个互斥锁*/
static rt_mutex_t osMutex = RT_NULL;
/*定义一个信号量*/
static rt_sem_t osSemaphore = RT_NULL;
实现GUI_X_GetTime和GUI_X_Delay函数
int GUI_X_GetTime(void) //主要用于时机触发,代替裸机下的OS_TimeMS变量
//return ((int) xTaskGetTickCount());
//使用RT-Thread的rt_tick_get函数获取tick return rt_tick_get();
//vTaskDelay( ms );
//使用RT-Thread的延时函数,单位ms
rt_thread_mdelay(ms);
实现GUI_X_ExecIdle函数
//空闲状态下1ms延时即可
GUI_X_Delay(1);
实现GUI_X_InitOS函数
/*创建互斥信号量,用于资源共享*/
osMutex = rt_mutex_create("osMutex", RT_IPC_FLAG_FIFO);
RT_ASSERT(osMutex != RT_NULL);
/*创建信号量,用于事件触发*/
osSemaphore = rt_sem_create("osSem", 0, RT_IPC_FLAG_FIFO);
RT_ASSERT(osSemaphore != RT_NULL);
实现GUI_X_Unlock函数
//osMutexRelease(osMutex);
//给出互斥量
rt_mutex_release(osMutex);
实现GUI_X_Lock函数
//osMutexWait(osMutex , osWaitForever) ; if(osMutex == RT_NULL)
GUI_X_InitOS();
//获取互斥量
rt_mutex_take(osMutex, RT_WAITING_FOREVER);
实现GUI_X_GetTaskId函数
//return ((U32) osThreadGetId());
/*获取当前线程句柄*/ return (U32) rt_thread_self();
实现GUI_X_WaitEvent函数
// osSemaphoreWait(osSemaphore , osWaitForever) ;
/*获取信号量*/ while(rt_sem_take(osSemaphore, RT_WAITING_FOREVER) != RT_EOK);
实现GUI_X_SignalEvent函数
//osMutexRelease(osSemaphore);
/*给出信号量*/
rt_sem_release(osSemaphore);
这样模板就修改完了,接下来,将之前裸机的工程的EMWIN目录拷贝到我移植好的RT-Thread工程上:(移植的工程来源于以下作品,我把里面很多逻辑裁掉了)
开源作品:基于RT-Thread 智慧农业监测系统产品级开发
并添加好对应的文件:
然后GUIConf.h中,要让GUI支持OS,则需要在Keil菜单对定义一个全局宏,使其全局生效,这样STemWin就支持RTOS了,其它配置参数和裸机驱动STemWin配置毫无二致,参考文初那篇文章的配置方法就可以了,唯一不同的地方就是使用的模板不同。
最后我定义了一个任务,编写了一个简单的STemWin显示实验和按键切换背景色的demo,实现效果如下:
获取项目:
免责声明:本文内容由21ic获得授权后发布,版权归原作者所有,本平台仅提供信息存储服务。文章仅代表作者个人观点,不代表本平台立场,如有问题,请联系我们,谢谢!
