当前位置:首页 > 技术学院 > 技术前线
[导读]基于STM32F407VGT6单片机的FSMC与FPGA通信
1. 关于FSMC
FSMC引脚定义:
地址线:A16-23 共8根地址线
数据线有16根(看单片机的原理图)
控制信号RD、WR、NE1/NCE2,这两个片选都接的是PD7,NE1即选中BAN1,用于扩展外部SRAM,FPGA相当于挂在单片机的BANK1,实质就是单片机进行读写FPGA。
2.FPGA测试程序(网上找的)
module STM32_FPGA(
input main_clk,
// output arm_clk,
output led,
input [2:0] addr,
inout [15:0] data,
input FPGA_CS0,//FPGA片选
input RD,
input WR
wire clk;
pll_50M pll_50M_inst (
.inclk0 ( main_clk ),//25M
.c0 ( clk ), //50M
.c1 ( arm_clk ) //8M
//reg [24:0] cnt = 0;
//always @(posedge clk)
// cnt <= cnt + 1'b1;
//assign led = cnt[24];
//AWE的上升沿,将数据写入FPGA寄存器
reg [15:0] ARM_FPGA_REG0;
reg [15:0] ARM_FPGA_REG1;
reg [15:0] ARM_FPGA_REG2;
reg [15:0] ARM_FPGA_REG3;
reg [15:0] ARM_FPGA_REG4;
reg [15:0] ARM_FPGA_REG5;
reg [15:0] ARM_FPGA_REG6;
reg [15:0] ARM_FPGA_REG7;
wire rd_en = ~FPGA_CS0 && ~RD;
reg [15:0] data_reg;
always @(*)
begin
if(rd_en)
begin
case(addr[2:0])
3'd0 : data_reg <= ARM_FPGA_REG0;
3'd1 : data_reg <= ARM_FPGA_REG1;
3'd2 : data_reg <= ARM_FPGA_REG2;
3'd3 : data_reg <= ARM_FPGA_REG3;
3'd4 : data_reg <= ARM_FPGA_REG4;
3'd5 : data_reg <= ARM_FPGA_REG5;
3'd6 : data_reg <= ARM_FPGA_REG6;
3'd7 : data_reg <= ARM_FPGA_REG7;
default: ;
endcase
end
end
/* AWE上升沿DSP的数据写入FPGA,即sampling point */
reg WR_tmp1;
reg WR_tmp2;
always @(posedge main_clk)//之前是CLK
begin
WR_tmp1 <= WR;
WR_tmp2 <= WR_tmp1;
end
wire WR_RISING = ~WR_tmp2 && WR_tmp1;//与clk同步
always @(*)
begin
if(WR_RISING)
begin
case(addr[2:0])
3'd0 : ARM_FPGA_REG0 <= data;
3'd1 : ARM_FPGA_REG1 <= data;
3'd2 : ARM_FPGA_REG2 <= data;
3'd3 : ARM_FPGA_REG3 <= data;
3'd4 : ARM_FPGA_REG4 <= data;
3'd5 : ARM_FPGA_REG5 <= data;
3'd6 : ARM_FPGA_REG6 <= data;
3'd7 : ARM_FPGA_REG7 <= data;
default: ;
endcase
end
end
assign data = rd_en ? data_reg : 16'hzzzz;
endmodule
3.STM32测试程序
//读写函数
#define fpga_write(offset,data) *((volatile unsigned short int *)(0x60000000 + (offset << 17))) = data
#define fpga_read(offset) *((volatile unsigned short int *)(0x60000000 + (offset << 17)))
//FSMC初始化函数,用LCD改的
void fcmc_Init(void )
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef p;
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOG, ENABLE);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_FSMC);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource3, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 |
GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 |
GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource2 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource3 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource4 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource5 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource6 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource10, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource11, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource12, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource13, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource14, GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource15, GPIO_AF_FSMC);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 |
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOG, GPIO_PinSource13, GPIO_AF_FSMC);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_Init(GPIOG, &GPIO_InitStructure);
p.FSMC_AddressSetupTime = 1;
p.FSMC_AddressHoldTime = 0;
p.FSMC_DataSetupTime = 4;
p.FSMC_BusTurnAroundDuration = 0;
p.FSMC_CLKDivision = 0;
p.FSMC_DataLatency = 0;
p.FSMC_AccessMode = FSMC_AccessMode_A;
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Enable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
//FSMC Bank1_SRAM1 Bank
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
delay_ms(50);
4.最后用quartusii中sigtapII测试
