漫画:什么是 “建造者模式” ?
时间:2021-09-28 16:33:28
手机看文章![](https://img.21ic.com/qrcode/qrcode.php?url=https://www.21ic.com/article/903644.html)
[导读]————— 第二天 ————————————————— 首先,我们来定义一个Product类:public class Product { ArrayList parts = new ArrayList(); public void add(String part) { parts.add(part); } public void show() { System.out.println(parts); }} 接下来,我们定义抽象的Builder类:public abstract class Builder { public abs...
————— 第二天 —————
首先,我们来定义一个Product类:
parts.add(part);
public abstract void buildPartA();
public abstract void buildPartB();
public abstract Product getResult() ;
然后,是具体的Builder实现类:
public class ConcreteBuilder extends Builder {
private Product product = new Product();
public Product getResult() {
return product;
@Override
public void buildPartA() {
product.add("构建产品的上半部分");
@Override
public void buildPartB() {
product.add("构建产品的下半部分");
在Builder类之外,则是Director类来控制Builder的生产过程:
public class Director {
private Builder builder;
public Director(Builder builder) {
this.builder = builder;
public void construct() {
builder.buildPartA();
builder.buildPartB();
最后,是客户端的测试代码:
Builder builder = new ConcreteBuilder();
Director director = new Director(builder);
director.construct();
Product product = builder.getResult();
product.show();
我们来看一下运行的结果:
[构建产品的上半部分, 构建产品的下半部分]
// 默认采用Builder进行建造
public OkHttpClient() {
this(new Builder());
// 由builder配置分发器、代理、协议以及自定义拦截器等
OkHttpClient(Builder builder) {
this.dispatcher = builder.dispatcher;
this.proxy = builder.proxy;
this.protocols = builder.protocols;
/** 省略大段代码 */
boolean isTLS = false;
for (ConnectionSpec spec : connectionSpecs) {
isTLS = isTLS || spec.isTls();
/** 省略大段代码. */
if (interceptors.contains(null)) {
throw new IllegalStateException("Null interceptor: " interceptors);
if (networkInterceptors.contains(null)) {
throw new IllegalStateException("Null network interceptor: " networkInterceptors);
public static final class Builder {
public Builder() {
// 分发器、协议、代理的默认参数
dispatcher = new Dispatcher();
protocols = DEFAULT_PROTOCOLS;
proxySelector = ProxySelector.getDefault();
if (proxySelector == null) {
proxySelector = new NullProxySelector();
Builder(OkHttpClient okHttpClient) {
// 反向配置分发器、代理、协议
this.dispatcher = okHttpClient.dispatcher;
this.proxy = okHttpClient.proxy;
this.protocols = okHttpClient.protocols;
// 新增所有自定义拦截器和自定义网络拦截器
this.interceptors.addAll(okHttpClient.interceptors);
this.networkInterceptors.addAll(okHttpClient.networkInterceptors);
// 配置代理
public Builder proxy(@Nullable Proxy proxy) {
this.proxy = proxy;
return this;
// 向拦截器链中增加自定义拦截器
public Builder addInterceptor(Interceptor interceptor) {
if (interceptor == null) throw new IllegalArgumentException("interceptor == null");
interceptors.add(interceptor);
return this;
// 最后是build()方法,生成OkHttpClient对象
public OkHttpClient build() {
return new OkHttpClient(this);
/**将指定的字符串追加到此字符序列*/
@Override
public StringBuilder append(CharSequence s) {
super.append(s);// 实现过程略
return this;
/**将此字符序列用其反转形式取代*/
@Override
public StringBuilder reverse() {
super.reverse();// 实现过程略
return this;
下面让我们来编写一下测试代码:StringBuilder sb = new StringBuilder("若为自由故");
sb.append("只要主义真");
sb.reverse();
System.out.println(sb);
StringBuilder sb1 = new StringBuilder("若为自由故");
sb1.reverse();
sb1.append("只要主义真");
System.out.println(sb1);
测试结果如下:
System.out: 真义主要只故由自为若
System.out: 故由自为若只要主义真
建造者模式与简单工程模式的区别,在于建造者模式多出一个Builder类,使得创建对象的灵活性大大增加,适用于如下场景:
(1)创建一个对象,多个同样的方法的调用顺序不同,产生的结果不同(2)创建一个对象,特别复杂,参数多,而且很多参数都有默认值
System.out.println("Hello World");
短短一行代码,背后有什么样的机制呢?
Java的编译原理,是将Hello.java编译成能被VM理解的Hello.class,然后再转化为能被不同硬件设备理解的bytecode进而执行的。
著名的字节码增强框架ASM,就是在Hello.java编译成Hello.class时可以读取并分析类信息、改变类行为、增强类功能甚至生成新的类的bytecode分析和操作框架。
我们来看一下相关的代码,代码当中的mv,来自ASM框架的MethodVisitor接口。
// 访问System类的类型为PrintSystem类型的静态变量out
mv.visitFieldInsn(Opcodes.GETSTATIC, "java/lang/System", "out", "Ljava/io/PrintStream;");
// 访问常量池中的数据"Hello World"
mv.visitLdcInsn("Hello World");
// 调用PrintStream类的println()方法并把刚才获取到的对象当做String类型的参数传入
mv.visitMethodInsn(Opcodes.INVOKEVIRTUAL, "java/io/PrintStream", "println", "(Ljava/lang/String;)V", false);
