提高UVM Sequences 复用程度的3大准则
sequence的编写和调试是非常体现验证工程师编码能力的地方之一,如果每一个sequnce都有着完全不同的工作模式,那么维护起来非常痛苦。
网络上有一个段子,程序员最讨厌4件事情:1、写文档2、别人不写文档3、写注释4、别人不写注释
想象一下,如果你验证同事离职,交接给你上百个定向且诡异的测试用例或者sequence?你会不会立马想去重构。
sequences 由多个事务激励组成,在UVM中其继承自参数化类uvm_sequence。通过这些事务触发一些验证工程师希望触及的场景,而sequence的分层会创建一些更加复杂的场景激励。验证空间随着设计规模指数级上升,验证激励自然也会越来越复杂。
class usb_simple_sequence extends uvm_sequence #(usb_transfer); rand int unsigned sequence_length; constraint reasonable_seq_len { sequence_length < 10 }; //Constructor function new(string name=”usb_simple_bulk_sequence”); super.new(name); endfunction //Register with factory `uvm_object_utils(usb_simple_bulk_sequence) //the body() task is the actual logic of the sequence virtual task body(); repeat(sequence_length) `uvm_do_with(req, { //Setting the device_id to 2 req.device_id == 8’d2; //Setting transfer type to BULK req.type == usb_transfer::BULK_TRANSFER; }) endtask : body endclass |
class usb_simple_bulk_test extends uvm_test; … virtual function void build_phase(uvm_phase phase ); … uvm_config_db#(uvm_object_wrapper)::set(this, "sequencer_obj. main_phase","default_sequence", usb_simple_sequence::type_id::get()); … endfunction : build_phase endclass |
1、只在base sequence 类中的pre_start和post_start任务中raising objections和 dropping objections来管理测试用例的开始和结束。通过这种方式,能够减少每一个sequence子类中的相关phase控制代码。
task pre_start() if(starting_phase != null) starting_phase.raise_objection(this); endtask : pre_start task post_start() if(starting_phase != null) starting_phase.drop_objection(this); endtask : post_start |
class usb_simple_bulk_test extends uvm_test; usb_simple_sequence seq; … virtual function void main_phase(uvm_phase phase ); … //User need to set the starting_phase as sequence start method is explicitly called to invoke the sequence seq.starting_phase = phase; seq.start(); … endfunction : main_phase endclass |
class usb_simple_sequence extends uvm_sequence #(usb_transfer); rand int unsigned sequence_length; constraint reasonable_seq_len { sequence_length < 10 }; … virtual task body(); usb_transfer::type_enum local_type; bit[7:0] local_device_id; //Get the values for the variables in case toplevel //test/sequence sets it. uvm_config_db#(int unsigned)::get(null, get_full_name(), “sequence_length”, sequence_length); uvm_config_db#(usb_transfer::type_enum)::get(null, get_full_name(), “local_type”, local_type); uvm_config_db#(bit[7:0])::get(null, get_full_name(),? “local_device_id”, local_device_id); repeat(sequence_length) `uvm_do_with(req, { req.device_id == local_device_id; req.type == local_type; }) endtask : body endclass |
uvm_config_db#()::set
中使用的参数类型和字符串(第三个参数)应该与uvm_config_db#()::get
中使用的类型相匹配,否则将无法正确配置。这个地方如果出错会非常痛苦,但好在不需要经常修改,痛苦一次就好。另外,这几个配置项是随机类型,相应的配置值也需要满足约束范围。3、在创建复杂sequence的时候尽量去复用简单的sequence。例如,在下面的sequence 中顺序发送不同的sequnce(层次化和模块化,永远是编码规范之一):
class usb_complex_sequence extends uvm_sequence #(usb_transfer); //Object of simple sequence used for sending bulk transfer usb_simple_sequence simp_seq_bulk; //Object of simple sequence used for sending interrupt transfer usb_simple_sequence simp_seq_int; … virtual task body(); //Variable for getting device_id for bulk transfer bit[7:0] local_device_id_bulk; //Variable for getting device_id for interrupt transfer bit[7:0] local_device_id_int; //Variable for getting sequence length for bulk int unsigned local_seq_len_bulk; //Variable for getting sequence length for interrupt int unsigned local_seq_len_int; //Get the values for the variables in case top level //test/sequence sets it. uvm_config_db#(int unsigned)::get(null, get_full_name(), “local_seq_len_bulk”,local_seq_len_bulk); uvm_config_db#(int unsigned)::get(null, get_full_name(), “local_seq_len_int”,local_seq_len_int); uvm_config_db#(bit[7:0])::get(null, get_full_name(), “local_device_id_bulk”,local_device_id_bulk); uvm_config_db#(bit[7:0])::get(null, get_full_name(), “local_device_id_int”,local_device_id_int); //Set the values for the variables to the lowerlevel //sequence/sequence item, which we got from //above uvm_config_db::get. //Setting the values for bulk sequence uvm_config_db#(int unsigned)::set(null, {get_full_name(),”.”, ”simp_seq_bulk”}, “sequence_length”,local_seq_len_bulk); uvm_config_db#(usb_transfer::type_enum)::set(null, {get_full_name(), “.”,“simp_seq_bulk”} , “local_type”,usb_transfer::BULK_TRANSFER); uvm_config_db#(bit[7:0])::set(null, {get_full_name(), “.”, ”simp_seq_bulk”}, “local_device_id”,local_device_id_bulk); //Setting the values for interrupt sequence uvm_config_db#(int unsigned)::set(null, {get_full_name(),”.”, ”simp_seq_int”}, “sequence_length”,local_ seq_len_int); uvm_config_db#(usb_transfer::type_enum)::set(null, {get_full_name(), “.”,“simp_seq_int”} , “local_type”,usb_transfer::INT_TRANSFER); uvm_config_db#(bit[7:0])::set(null,{get_full_name(),“.”, ”simp_seq_bulk”},“local_device_id”,local_device_id_int); `uvm_do(simp_seq_bulk) simp_seq_bulk.get_response(); `uvm_send(simp_seq_int) simp_seq_int.get_response(); endtask : body endclass |
