CAT6500自动电源选择开关详细介绍
CAT6500 is an automatic power switch designed to select between two power sources and direct that power to a load for battery charging or system power.
CAT6500’s power inputs withstand voltages of up to 18 V and protect the downstream load from voltages exceeding 7V. In the event of a polarity reversal at either input CAT6500’s internal power switches will shut off to prevent discharge of the system’s internal power source.
功能框图:
CAT6500功能框图
管脚定义:
CAT6500管脚定义
引脚功能描述:
Pin No.
Pin Name
Description
1, 2, 3, 4
PWR_OUT
Power Output. Must be tied to PWR_OUT on opposite side of chip. Use all 3 pins each side.
NIC
No Internal Connection. A signal or voltage applied to this pin will have no effect on device operation.
6, 7, 8, 9, 10
PS2
Power Source #2. External power input
11, 12
NIC
13
VCC
Power input from battery.
14
GND
Ground. Reference point for all voltages.
15
C1
Filter capacitor for CAT6500’s internal power bus
16
NIC
17
NIC
18
PRIORITY
Priority selects preferred power source when both PS1 and PS2 are powered.
19
RM_EN2
Reverse Mode Enable 2. Overrides PRIORITY and turns SW2 ON.
20
GND
21
RM_EN1
Reverse Mode Enable 1. Overrides PRIORITY and turns SW1 ON.
22
PS1
Power Source #1. External power input.
23
SW2_STAT
Power Source 2 Status. An open drain LOW true logic level output indicating that the switch SW2 is
24
SW1_STAT
Power Source 1 Status. An open drain LOW true logic level output indicating that the switch SW1 is
25, 26, 27, 28
PS1
29
NIC
30, 31, 32
PWR_OUT
33
PWR_OUT
Electrically active thermal pad. Does not need to be connected to other PWR_OUTs. Can be left float-ing but must not be connected to other signal paths or Ground.
34
PS2
Electrically active thermal pad. Does not need to be connected to other PS2 pins. Can be left floating but must not be connected to other signal paths or Ground.
35
Mechanical support for control IC. This chip does not generate any significant heat and does not need a separate heat sinking connection. Electrically this may be left floating or can be grounded. It should NOT be connected to other signals or voltages.
36
PS1
Electrically active thermal pad. Does not need to be connected to other PS1 pins. Can be left floating but must not be connected to other signal paths or Ground.
CAT6500技术方案、应用案例、电路图集锦
涵盖了CAT6500的技术方案和CAT6500的应用笔记以及CAT6500的电路图,为工程师学习CAT6500提供了一站式学习环境。
