[导读]PD69101是单端混合信号高压以太网供电(PoE)驱动器,它采用以太网开关和使能网络器件在同一电缆上共享电源和数据,能检测EEE802.3af-2003兼容的受电设备(PD)和IEEE802.3at大功率设备.DC输入电压44 - 57 VDC,内置了3.3V
PD69101是单端混合信号高压以太网供电(PoE)驱动器,它采用以太网开关和使能网络器件在同一电缆上共享电源和数据,能检测EEE802.3af-2003兼容的受电设备(PD)和IEEE802.3at大功率设备.DC输入电压44 - 57 VDC,内置了3.3V DC稳压器,工作温度从-40°到+85℃,具有超温保护和电压监视与保护等.本文介绍PD69101主要特性,方框图以及2对和4对(数据和供电)典型应用电路图.
Microsemi’s PD69101 is a single port, mixed-signal, high-voltage Power over Ethernet driver. The device is utilized in Ethernet switches and enables network devices to share power and data over the same cable. It enables detection of IEEE802.3af-2003 compliant PDs (Powered Devices) and IEEE802.3at High Power Devices, thus, ensuring safe power feeding and disconnection of ports with full digital control and a minimum of external components. Integrating power, analog and state of the art logic, the PD69101 device fits into a single 24-pin, plastic QFN package.
A “plug and play” device, the PD69101 executes all real time functions as specified in the IEEE802.3af-2003 (“AF”) and IEEE802.3at High Power (“AT”) standards, including load detection, “AF” and “AT” classification, and using Multiple Classification Attempts (MCA).
The PD69101 :
• Is designed to detect and disable disconnected ports, utilizing DC disconnection methods, as specified in the IEEE 802.3af-2003 and IEEE802.3ar-2009 standards.
• Can optionally detect legacy/pre-standard PD devices.
• Provides PD protection such as over-load, under-load, over-voltage, over-temperature and short-circuiting.
• Supports supply voltages ranging from 44 V to 57 VDC with no need for additional power supply sources.
• Is a low power device using an internal 0.3 Ω MOSFET and an external 0.5 Ω sense resistor.
The chip includes built-in internal thermal protection.
Two LEDs provide port state’s indication and port type (AF/AT).
PD69101主要特性:
Fully IEEE802.3af-2003 and IEEE802.3at-2009 compliant
Includes two-event classification
Supports pre-standard PD detection
Supports Cisco devices detection
Single DC voltage input (44 - 57 VDC)
Supports 2 Pairs and 4 Pairs (Data and Spare Power Feeding)
VMAIN Out of Range Protection
Wide temperature range: -40°to +85℃
Over-temperature protection
Low thermal dissipation (0.5 Ω sense resistor)
Includes on/off command pin
2 x direct LEDs drive
Continuous port monitoring and system data
Configurable load current setting
Configurable AT/AF modes
Configurable standard and legacy detection mode
Power soft start mechanism
On-chip thermal protection
Voltage monitoring & protection
Built in 3.3 VDC regulator
Internal power on reset
RoHS compliant
Low Rdson FET: 0.3 Ω
[!--empirenews.page--]
图1.PD69101内部方框图
图2.PD69101典型的2对应用电路图
图3.PD69101典型的4对应用电路图
关键字:
阿维塔
塞力斯
华为
关键字:
AWS
AN
BSP
数字化
关键字:
汽车
人工智能
智能驱动
BSP
关键字:
亚马逊
解密
控制平面
BSP
关键字:
腾讯
编码器
CPU
关键字:
华为
12nm
EDA
半导体
关键字:
华为
12nm
手机
卫星通信
关键字:
通信
BSP
电信运营商
数字经济
关键字:
VI
传输协议
音频
BSP
关键字:
BSP
信息技术
山海路引 岚悦新程 三亚2024年8月27日 /美通社/ -- 近日,海南地区六家凯悦系酒店与中国高端新能源车企岚图汽车(VOYAH)正式达成战略合作协议。这一合作标志着两大品牌在高端出行体验和环保理念上的深度融合,将...
关键字:
新能源
BSP
PLAYER
ASIA
上海2024年8月28日 /美通社/ -- 8月26日至8月28日,AHN LAN安岚与股神巴菲特的孙女妮可•巴菲特共同开启了一场自然和艺术的疗愈之旅。 妮可·巴菲特在疗愈之旅活动现场合影 ...
关键字:
MIDDOT
BSP
LAN
SPI
8月29日消息,近日,华为董事、质量流程IT总裁陶景文在中国国际大数据产业博览会开幕式上表示,中国科技企业不应怕美国对其封锁。
关键字:
华为
12nm
EDA
半导体
上海2024年8月26日 /美通社/ -- 近日,全球领先的消费者研究与零售监测公司尼尔森IQ(NielsenIQ)迎来进入中国市场四十周年的重要里程碑,正式翻开在华发展新篇章。自改革开放以来,中国市场不断展现出前所未有...
关键字:
BSP
NI
SE
TRACE
上海2024年8月26日 /美通社/ -- 第二十二届跨盈年度B2B营销高管峰会(CC2025)将于2025年1月15-17日在上海举办,本次峰会早鸟票注册通道开启,截止时间10月11日。 了解更多会议信息:cc.co...
关键字:
BSP
COM
AI
INDEX
上海2024年8月26日 /美通社/ -- 今日,高端全合成润滑油品牌美孚1号携手品牌体验官周冠宇,开启全新旅程,助力广大车主通过驾驶去探索更广阔的世界。在全新发布的品牌视频中,周冠宇及不同背景的消费者表达了对驾驶的热爱...
关键字:
BSP
汽车制造
此次发布标志着Cision首次为亚太市场量身定制全方位的媒体监测服务。 芝加哥2024年8月27日 /美通社/ -- 消费者和媒体情报、互动及传播解决方案的全球领导者Cis...
关键字:
CIS
IO
SI
BSP
上海2024年8月27日 /美通社/ -- 近来,具有强大学习、理解和多模态处理能力的大模型迅猛发展,正在给人类的生产、生活带来革命性的变化。在这一变革浪潮中,物联网成为了大模型技术发挥作用的重要阵地。 作为全球领先的...
关键字:
模型
移远通信
BSP
高通
北京2024年8月27日 /美通社/ -- 高途教育科技公司(纽约证券交易所股票代码:GOTU)("高途"或"公司"),一家技术驱动的在线直播大班培训机构,今日发布截至2024年6月30日第二季度未经审计财务报告。 2...
关键字:
BSP
电话会议
COM
TE
8月26日消息,华为公司最近正式启动了“华为AI百校计划”,向国内高校提供基于昇腾云服务的AI计算资源。
关键字:
华为
12nm
EDA
半导体
