当前位置:首页 > 电源 > 数字电源
[导读]#include<reg51.h>#define uint unsigned int #define uchar unsigned char #define ms *77 // f = 12 M #define LEDLen 4 #define Dj_star() {IE=0x81; pri_dj=0; } #define Dj_stop() {IE=0x00; pri_dj=1;
#include<reg51.h>
#define ms *77
// f = 12 M
#define LEDLen 4
#define Dj_stop() {IE=0x00; pri_dj=1; P1=0xff; shache="0"; delay(800ms); delay(800ms);delay(400ms); shache = 1; }
#define Chilun_Num 8
/* 齿轮数 8 个*/
#define set_display_num() { LEDBuf[0] = tmp / 1000;     LEDBuf[1] = tmp / 100 % 10;
                            LEDBuf[2] = tmp / 10 % 10;  LEDBuf[3] = tmp % 10;        }
uchar LEDBuf[LEDLen] = {0,0,0,0};
void  read_num ();                /* 读播码盘 到 set_round_num  * 8 */
void  display  ();
void  delay(uint  delay_time) { uint  i; for (i=0; i < delay_time ; i++) ; }
void  run ();
void  fx_run();
uint  round_num     = 0;           /* 记录已转的 齿轮数 , 中断1次 加 1*/
uint  set_round_num = 0;           /* 播码盘设置 圈数 */
uint  set_pwm_width = 0;           /* 播码盘设置 步进电机 正向速度 */
bit   one_round_flg = 0;
sbit  led_1000      = P0^7;        //use for display
sbit  led_100       = P0^6;        //use for display
sbit  led_10        = P0^5;        //use for display
sbit  led_1         = P0^4;        //use for display
sbit  key_start     = P3^0;
sbit  key_puse      = P3^0;
sbit  key_clear     = P3^1;
                                   /*  P3^2 接齿轮传感器 中断  */
sbit  bujin_zx_stop = P3^3;        /* 接步进电机 ,正向到位传感器 ,为 0 停机 */
sbit  bujin_fx_stop = P3^4;        /* 接步进电机 ,反向到位传感器 ,为 0 停机 */
sbit  shache        = P3^5;        /* 接刹车控制继电器   0 电位有效 */
sbit  pri_dj        = P3^6;        /* 接主电机控制继电器 0 电位有效 */
void main(){
        TCON = 0x01;
        display();
        while(1) {
            IE="0x00";
            round_num = 0;
            display();
            if ( bujin_fx_stop ) fx_run();
            while ( key_start );
            delay ( 8ms );
            if(!key_start){
                read_num();
                //set_round_num  = 8;
                while ( !key_start );
                run ();
                fx_run();
void run () {
    #define Delay_time   180
    /* 转一圈 50 次循环,每循环 4 步 ,50 * 4 = 200 , 200 * 1。8 = 360 */
    uchar i ;
    P1 = 0xff;
    set_pwm_width = 15 + set_pwm_width / 10;
    while ( 1 ) {
            while( !shache | !key_start );
            Dj_star();
            for ( i="0" ; bujin_zx_stop & !pri_dj;i++ ){
                P1 =  0xf9;
                delay ( Delay_time  );        // bujin_zx_stop = P3^3;
                P1 =  0xfc;                   // bujin_fx_stop = P3^4;
                delay ( Delay_time);          // key_puse      = P3^0;
                P1 =  0xf6;                   // key_clear     = P3^1;
                delay ( Delay_time  );        // shache        = P3^5;
                P1 =  0xf3;                   // pri_dj        = P3^6;
                if( i == set_pwm_width ) { P1 = 0xff; i = 0; one_round_flg = 0; while ( !one_round_flg & key_puse );}
                if(!key_puse) { delay(4ms);  if(!key_puse) break;  }
            P1 = 0xff;
            if ( pri_dj )  break;
            if ( !key_puse ) {
                delay ( 8ms );
                if ( !key_puse  ) {
                    Dj_stop();
                    while ( !key_puse );
                    // next pree key
                    while( !shache );
                    while(1){
                        while (  key_puse &  key_clear );
                        delay ( 8ms );
                        if ( !key_clear )  { round_num = 0; display(); }
                        if ( !key_puse  )  break;
                    while( !key_puse );
                    delay(8ms);
                    while( !key_puse );
}[!--empirenews.page--]
void ext_int0(void) interrupt 0  {   /* 主电机 齿轮 中断 */
    uint tmp;
    EA = 0;
    if( !pri_dj ){
            round_num ++;
            if (round_num % Chilun_Num == 0 ){
                one_round_flg = 1;
                tmp = round_num  / Chilun_Num ;
                set_display_num();
                P0 = 0xf0;
                P0 = P0 | LEDBuf[0] ;
                led_1000  = 0;
                P0 |= 0xf0;
                P0 = 0xf0;
                P0 = P0 | LEDBuf[1] ;
                led_100   = 0;
                P0 |= 0xf0;
                P0 = 0xf0;
                P0 = P0 | LEDBuf[2] ;
                led_10    = 0;
                P0 |= 0xf0;
                P0 = 0xf0;
                P0 = P0 | LEDBuf[3] ;
                led_1     = 0;
                P0 |= 0xf0;
                P0 = 0xf0;
            if ( round_num >= set_round_num  ) Dj_stop();
    EA = 0x81;
void display(){
     uchar i;
     uint tmp = 0;
     set_display_num();
     for(i = 0; i < LEDLen ; i ++){
           P0 = 0xf0;
           P0 = P0 | LEDBuf[i] ;
           if(i==0) led_1000  = 0;        //P0^4
           if(i==1) led_100   = 0;        //P0^5
           if(i==2) led_10    = 0;        //P0^6
           if(i==3) led_1     = 0;        //P0^7
           P0 |= 0xf0;
     P0 = 0xf0;
void read_num(){
     /* 读播码盘 到 set_round_num  ,set_pwm_width  */
     uchar tmp;
     P2 =  0xFF;
     P2 =  0xEF;    // 1110 1111
     delay ( 1ms  );
     tmp =   ~(P2  | 0xF0);
     P2 =  0xDF;    // 1101 1111
     delay ( 1ms  );
     tmp = (~(P2 | 0xF0 )) * 10   + tmp;
     set_round_num = tmp;
     P2 =  0xBF;    // 1011 1111
     delay ( 1ms  );
     tmp = (~(P2 | 0xF0));
     P2 =  0x7F;    // 0111 1111
     delay ( 1ms  );
     tmp = (~(P2 | 0xF0)) * 10 + tmp;
     set_round_num = set_round_num  + tmp * 100;
     set_round_num = set_round_num  * Chilun_Num;
     P2 =  0xFF;
     P1 =  0xbF;    // 0111 1111
     delay ( 1ms );
     tmp =   ~(P2  | 0xF0) ;
     P1  =  0xFF;
     P2  =  0xFF;
     P1 &=  0x7F;    // 1011 1111
     delay ( 1ms );
     tmp = (~(P2 | 0xF0)) * 10 + tmp ;
     set_pwm_width = tmp ;
     P1  = 0xFF;
     P2  = 0xFF;
void  fx_run(){
    #define f_Delay_time 180
    while ( bujin_fx_stop ) {   /* 反向 回车 直到 传感器 动作*/
        P1 =  0xf3;                   //0011
        delay ( f_Delay_time );
        P1 =  0xf6;                   //0110
        P1 =  0xfc;                   //1100
        P1 =  0xf9;                   //1001
    P1 = 0xff;
