当前位置:首页 > 电源 > 数字电源
[导读]</a>LED" title="LED">LED" title="LED">LED装饰灯,可调光LED照明,离线LED驱动器和商业照明.本文介绍了CS1610/11/12/13主要特性,方框图,典型应用电路以及典型反激电路图和降压电路图,以及CRD 1611-8W和CRD 1610-8W参
</a>LED" title="LED">LED" title="LED">LED装饰灯,可调光LED照明,离线LED驱动器和商业照明.本文介绍了CS1610/11/12/13主要特性,方框图,典型应用电路以及典型反激电路图和降压电路图,以及CRD 1611-8W和CRD 1610-8W参考设计主要特性和指标.
The CS1610/11/12/13 is a digital control IC engineered to deliver a high-efficiency, cost-effective, flicker-free, phase-dimmable, solid-state lighting (SSL) solution for the incandescent lamp replacement market. The CS1610/11 is designed to control a quasi-resonant flyback topology. The CS1612/13 is designed to control a buck topology. The CS1610/12 and CS1611/13 are designed for 120VAC and 230VAC line voltage applications, respectively.
The CS1610/11/12/13 integrates a critical conduction mode (CRM) boost converter that provides power factor correction and dimmer compatibility with a constant output current, quasiresonant second stage. An adaptive dimmer compatibility algorithm controls the boost stage and dimmer compatibility operation mode to enable flicker-free operation to <2% output current with leading-edge, trailing-edge, and digital dimmers (dimmers with an integrated power supply).
