AKMAK7782双路音频信号处理解决方案
AKM 公司的AK7782是集成24位5路ADC和SRC的双路音频信号处理器(DSP),同时还集成了8:2立体声输入选择器,取样速率转换器,速率高达96kHz,ADC取样频率从7.35kHz 到96kHz.本文介绍了AK7782主要特性,方框图,DSP方框图,AK7782评估板AKD7782-A主要功能,方框图,电路图以及元件布局图.
The AK7782 is an audio digital signal processor with integrated 24bit 5ch ADCs, an 8:2 stereo input selector and sample rate converters that support 2ch inputs and the frequency up to 96kHz. The ADC supports wide range of sampling frequency from 7.35kHz to 96kHz. Two integrated audio DSPs have high performance processing speed of 2560step/fs (at 48kHz sampling), and two 6k-word delay RAMs allow surround processing, time alignment adjusting and FIR filtering. As the AK7782 is a RAM based DSP, it is programmable for various user requirements. It is housed in a 100pin LQFP package.
