采用dsPIC33F和PIC24H的Microstick开发方案设计
本文 首先介绍了PIC24H系列16 位高性能单片机主要特性,方框图,接着介绍了Microstick 开发板主要特性及其电路图。
Microstick 开发板是Microchip 公司的用来开发16位数字信号控制器(DSC)dsPIC33F 和16位MCU PIC24H,主要用来开发智能传感器和其它嵌入式控制应用。Microstick 开发板的成本很低,它集成了编程器/调试器,可以单独使用,也可以插入原型板进行开发,成本很低。
PIC24H系列16 位高性能单片机主要特性:
通信模块:
• 4 线SPI (最多2 个模块):
- 帧支持与简单编解码器的I/O 接口
- 支持8 位和16 位数据
- 支持所有串行时钟格式和采样模式
比较器模块:
• 带可编程输入/ 输出配置的两个模拟比较器
CMOS 闪存技术:
• 低功耗高速闪存技术
• 全静态设计
• 3.3V (±10%)工作电压
• 工业级和扩展级温度
• 低功耗
封装:
• 28 引脚SPDIP/SOIC/QFN-S
• 44 引脚TQFP/QFN
图1。PIC24HJ32GP302/304、PIC24HJ64GPX02/X04 和PIC24HJ128GPX02/X04框图
dsPIC33F 和PIC24H开发板Microstick
Microstick for dsPIC33F and PIC24H Development Board
The Microstick for dsPIC33F and PIC24H devices is designed to provide an easy to use, economical development environment for 16-bit digital signal controllers and microcontrollers. The board includes an integrated debugger/programmer, a socket for the device under test and pins that facilitate insertion into a prototyping board for extremely flexible development.
图1。dsPIC33F 和PIC24H开发板Microstick外形图[!--empirenews.page--]
The Microstick for dsPIC33F and PIC24H devices is designed to provide designers with an easy to use, economical development environment for 16-bit Digital Signal Controllers and Microcontrollers.
Microstick provides all you need to get started at a very low cost. It has an integrated programmer / debugger. It can be used stand-alone or plugged into a prototyping board for extremely flexible development. The device under test is socketed for easy change-out, and Microchip’s MPLAB Integrated Development Environment supports Microstick. It has never been more affordable to get started with Microchip 16-bit devices!
开发板Microstick主要特性:
Low Cost – Priced at $24.99 at Microchip Direct
Integrated USB programmer / debugger – No external debugger required
USB Powered – Ease of use, No external power required
Socketed dsPIC/PIC24 – Flexible, Easy device replacement
0.025” Pin headers – Enables plug-in to Breadboard with room for jumper wires
Easy access to all device signals for probing
Small size - Smaller than a stick of gum at 20 x76mm – Easily Portable
On board debug LED, Utility LED and Reset Switch
Free demo code
图3。dsPIC33F 和PIC24H开发板Microstick电路图
