当前位置:首页 > 电源 > 数字电源
[导读]简述CAT6500 is an automatic power switch designed to select between two power sources and direct that power to a load for battery charging or system power.CAT65
简述
CAT6500’s power inputs withstand voltages of up to 18V and protect the downstream load from voltages exceeding7V. In the event of a polarity reversal at either input CAT6500’s internal power switches will shut off to prevent discharge of the system’s internal power source.
Low resistance power switches handle currents in excess of 3 A and when OFF block current flow in both directions. CAT6500 can operate in reverse mode in which internal system power is be directed to either of the power input ports for powering an external device, such as a USB On−The−Go appliance.
特性
Autonomous Switching between 2 Power Sources
Withstands +18 V to −5 V on Either Power Input
80 m_ Switches (typ.) for Low Power Loss
Reverse−Mode for Powering External Devices
Over Voltage Protection of Downstream Load
Compatible with USB−OTG Devices
2−Lead WQFN 4.4 mm x 4.4 mm Package
This Device is Pb−Free, Halogen Free/BFR Free and is RoHS Compliant
典型应用
Mobile Phones
PDAs
Personal Navigation Devices
Figure 1. Typical Application Circuit
涵盖了CAT6500的技术方案和CAT6500的应用笔记以及CAT6500的电路图,为工程师学习CAT6500提供了一站式学习环境。
