从内核驱动到android app
该文不得作为商业用途,仅为学习积累所用,转载请注明出处:http://blog.csdn.net/callon_h/article/details/51909169
了解android驱动框架:
1.方法1——jni调用底层驱动
在android框架中写入c/c++直接调用底层linux驱动,并向上提供jni接口给应用程序:
优点:简单易行;
缺点:主要在于驱动程序,由于在linux中需要遵循GPL协议,需要开源,而许多厂商的一些代码不希望开源。
2.方法2——增加硬件抽象层
将驱动程序一分为二,一部分开源在内核中,一部分不开源在android框架中:
led android驱动:
从这里我们将看到整个应用框架层到底层驱动的走向。首先,无论是哪种方法,我们都需要实现一个linux驱动以供上层访问led资源。
1.linux驱动:
linux的字符设备驱动编写:
#include#include#include#include#include#include#include#includestatic struct cdev dev; static dev_t dev_num; #define GPM4CON 0x110002E0 #define GPM4DAT 0X110002E4 #define LED_ON _IOW('G',0,int) #define LED_OFF _IOW('G',1,int) static unsigned int *led_con = NULL; static unsigned int *led_dat = NULL; static struct class *led_class = NULL; static long led_ioctl(struct file *file, unsigned int cmd, unsigned long arg) { switch(cmd) { case LED_ON: { writel(readl(led_dat)& ~(0x1<<arg), led_dat); break; } case LED_OFF: { writel(readl(led_dat)| (0x1<<arg), led_dat); break; } default: { return -EINVAL; break; } } return 0; } static struct file_operations led_fops = { .owner = THIS_MODULE, .unlocked_ioctl = led_ioctl, }; static void hw_init()//GPM4_0-3 { //1.2.1 映射地址 led_con = ioremap(GPM4CON,4); led_dat = ioremap(GPM4DAT,4); //1.2.2 设置为输出状态 writel((readl(led_con)& ~0xffff) | 0x1111, led_con); //1.2.3 设置为高电平 writel(readl(led_dat)|0xf, led_dat); } static int led_init() { //1.1 cdev字符设备初始化 //1.1.1 分配cdev结构(静态分配) //1.1.2 初始化cdev结构 alloc_chrdev_region(&dev_num,0,1,"callon_led"); cdev_init(&dev, &led_fops); dev.owner = THIS_MODULE; //1.1.3 注册cdev结构 cdev_add(&dev,dev_num,1); //1.2 硬件初始化 hw_init(); //1.3 创建设备文件 //1.3.1 创建类 led_class = class_create(THIS_MODULE,"callon_led"); //1.3.2 创建设备 device_create(led_class,NULL,dev_num,NULL,"%s","callon_led"); printk("init led device is OK!n"); return 0; } static void led_exit() { device_destroy(led_class,dev_num); class_destroy(led_class); iounmap(led_dat); iounmap(led_con); cdev_del(&dev); unregister_chrdev_region(dev_num,1); } module_init(led_init); module_exit(led_exit);
2 实现第一种方法:
首先,说明一下为什么使用jni:
1.基于对代码的保护,java相对容易被反编译,而c/c++库反汇编难度较大;
2.可以方便地使用现存的开源库;
3.提高执行效率;
4.java在某些文件操作方面,找不到相关的API,如此处的ioctl.
其次,为什么使用ndk?
ndk提供了一系列的工具,能够帮助开发者快速开发c/c++的动态库,并能自动将.so动态库和java一起打包成apk.
第一种方法的设计思路如下所示:
在第一步中想要使用javah命令自动产生头文件需要先编写app程序,但是此时的app程序并不需要很完善,只需要提出一个你想要的native接口就好(但是你的android程序必须要Rebuild正确才会正确产生头文件):
package com.led.ndk.example.callon.ndk_led; import android.app.Activity; import android.os.Bundle; import android.view.View; import android.widget.CheckBox; public class MainActivity extends Activity { private CheckBox[] Led = new CheckBox[4]; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); Led[0] = (CheckBox)findViewById(R.id.checkbox_led1); Led[1] = (CheckBox)findViewById(R.id.checkbox_led2); Led[2] = (CheckBox)findViewById(R.id.checkbox_led3); Led[3] = (CheckBox)findViewById(R.id.checkbox_led4); } private void SendCmd(View view) { for(int i =1; i<5; i++) { if(Led[i].isChecked()) { cmdLeds(1, i); } else { cmdLeds(0, i); } } } public native void cmdLeds(int cmd, int arg); }
根据如上简单的app,使用命令:
javah -d jni -classpath 你的sdk目录/platforms/你的平台名/android.jar:你的应用程序/app/build/intermediates/classes/debug/ 你的包名.主类名
如:
javah -d jni -classpath /opt/AndroidSDK/platforms/android-23/android.jar:/home/callon/Downloads/callon_ndk_led/ndk_led/app/build/intermediates/classes/debug/ com.led.ndk.example.callon.ndk_led.MainActivity
此时自动产生出jni文件夹,其中包含头文件com_led_ndk_example_callon_ndk_led_MainActivity.h,头文件比较重要的:
JNIEXPORT void JNICALL Java_com_led_ndk_example_callon_ndk_1led_MainActivity_cmdLeds (JNIEnv *, jobject, jint, jint);
这也就是我们编写源文件需要实现的方法名,下面直接编写源文件:
#include "com_led_ndk_example_callon_ndk_led_MainActivity.h" #include#include#include#include#include#include#include#define LED_ON _IOW('G',0,int) #define LED_OFF _IOW('G',1,int) JNIEXPORT void JNICALL Java_com_led_ndk_example_callon_ndk_1led_MainActivity_cmdLeds (JNIEnv * env, jobject thiz, jint cmd, jint arg) { int fd; int temp_cmd; fd = open("/dev/callon_led",O_WRONLY); if(cmd == 1) temp_cmd = LED_ON; else temp_cmd = LED_OFF; ioctl(fd, temp_cmd, arg); close(fd); }
就是一些对内核驱动文件的操作,然后编写Android.mk即makefile:
LOCAL_PATH := $(call my-dir) include $(CLEAR_VARS) LOCAL_MODULE := callon_ndk_led LOCAL_SRC_FILES := ndk_led.c include $(BUILD_SHARED_LIBRARY)
此时,在你的jni文件夹应该有这三个文件了,退到jni文件夹之外,使用命令ndk-build即可:
callon@ubuntu:~/Downloads/callon_ndk_led/jni$ ls Android.mk com_led_ndk_example_callon_ndk_led_MainActivity.h ndk_led.c callon@ubuntu:~/Downloads/callon_ndk_led/jni$ cd .. callon@ubuntu:~/Downloads/callon_ndk_led$ ndk-build [armeabi] Compile thumb : callon_ndk_led libs/armeabi/libcallon_ndk_led.so callon@ubuntu:~/Downloads/callon_ndk_led$
最后一步,完善app:
首先,用Project形式来看我们的app,并在app->src->main下创建一个目录"jniLibs";
然后,将我们.so所在的armeabi目录拷贝到jniLibs目录下;
最后在我们的app代码的最后加上:
static { System.loadLibrary("callon_ndk_led"); }
然后Rebuild Project即可!
3 实现第二种方法:
1.HAL程序编写:
首先在 安卓源代码根目录/hardware/libhardware/modules/下创建自己的hal代码存放路径,如led。
最终编写的文件为:安卓源代码根目录/hardware/libhardware/modules/led/led_hal.c和Android.mk,安卓源代码根目录/hardware/libhardware/include/hardware/led.h。
#include#include#include#include#include#include#include#include#include#include#define LOG_TAG "callon_led" static int fd; static int led_close(struct hw_device_t *device) { struct led_device_t* led = (struct led_device_t*)device; free(led); close(fd); return 0; } int led_on(struct led_device_t* dev,int arg) { ioctl(fd,LED_ON,arg); return 0; } int led_off(struct led_device_t* dev,int arg) { ioctl(fd,LED_OFF,arg); return 0; } static struct led_device_t led_dev = { .led_device = { .tag = HARDWARE_DEVICE_TAG, .close = led_close, }, .set_on = led_on, .set_off = led_off, }; static int open_led(const struct hw_module_t* module, char const* name, struct hw_device_t** device) { *device = &led_dev; fd = open("/dev/callon_led",O_RDWR); if(fd < 0) { ALOGD(LOG_TAG, "open device fail!"); return -1; } return 0; } static struct hw_module_methods_t led_methods = { .open = open_led, }; struct hw_module_t HAL_MODULE_INFO_SYM = { .tag = HARDWARE_MODULE_TAG, .id = "led", .methods = &led_methods, };
led.h
#ifndef _HARDWARE_LED_H #define _HARDWARE_LED_H #include#define LED_ON _IOW('G',0,int) #define LED_OFF _IOW('G',1,int) struct led_device_t { struct hw_device_t led_device; int (*set_on)(struct led_device_t* dev,int arg);//means led_number int (*set_off)(struct led_device_t* dev,int arg); }; #endif // _HARDWARE_LED_H
Android.mk
LOCAL_PATH := $(call my-dir) include $(CLEAR_VARS) LOCAL_MODULE := led.default # HAL module implementation stored in # hw/.default.so LOCAL_MODULE_RELATIVE_PATH := hw LOCAL_C_INCLUDES := hardware/libhardware LOCAL_SRC_FILES := led_hal.c LOCAL_SHARED_LIBRARIES := liblog LOCAL_MODULE_TAGS := eng include $(BUILD_SHARED_LIBRARY)
编译则在 安卓源代码根目录下使用
$ . setenv $ lunch $ mmm hardware/libhardware/modules/led/
看到
target SharedLib: led.default (out/target/product/tiny4412/obj/SHARED_LIBRARIES/led.default_intermediates/LINKED/led.default.so) target Symbolic: led.default (out/target/product/tiny4412/symbols/system/lib/hw/led.default.so) Export includes file: hardware/libhardware/modules/led/Android.mk -- out/target/product/tiny4412/obj/SHARED_LIBRARIES/led.default_intermediates/export_includes target Strip: led.default (out/target/product/tiny4412/obj/lib/led.default.so) Install: out/target/product/tiny4412/system/lib/hw/led.default.so make: Leaving directory `/opt/Tiny4412/Android/android-5.0.2' #### make completed successfully (1 seconds) ####
即可,最后产生的就在out/target/product/tiny4412/system/lib/hw/led.default.so了。
我们将system.img重做,这里通过一个脚本./gen-img.sh完成。
2.硬件服务编写:
首先,Service Manager为了解决访问冲突而存在的,在有Service Manager的基础之上,我们的底层需要先编写硬件服务,注册到Service Manager,我们的app才能通过Service Manager获取到服务,操作底层。
由于涉及到许多目录操作,细化操作后为:
1.创建 ILedService.aidl
仿照 frameworks/base/core/java/android/os/IVibratorService.aidl
package android.os; /** {@hide} */ interface ILedService { int LedOpen(); int LedOn(int arg); int LedOff(int arg); }
2.修改frameworks/base/Android.mk 增加
core/java/android/os/ILedService.aidl
3.自动生成ILedService.java
mmm frameworks/base/编译自动生成out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/src/core/java/android/os/ILedService.java
4.创建 LedService.java 实现接口函数
仿照frameworks/base/services/core/java/com/android/server/VibratorService.java
package com.android.server; import android.util.Slog; import android.os.ILedService; public class LedService extends ILedService.Stub{ private static final String TAG = "LedService"; public LedService() { Slog.d(TAG,"LedService"); } public int LedOpen() throws android.os.RemoteException { return native_LedOpen(); } public int LedOn(int arg) throws android.os.RemoteException { return native_LedOn(arg); } public int LedOff(int arg) throws android.os.RemoteException { return native_LedOff(arg); } public static native int native_LedOpen(); public static native int native_LedOn(int arg); public static native int native_LedOff(int arg); }
5.将服务注册到Service Manager当中
修改frameworks/base/services/java/com/android/server/SystemServer.java
参考vibrator修改的地方
LedService led = null;
Slog.i(TAG, "Led Service"); led = new LedService(); ServiceManager.addService("led", led);
6.实现com_android_server_LedService.cpp
为什么需要它?因为我们的hal代码并没有提供jni的接口(这里提供了一种新的方法来提供native方法,之前是自动产生头文件然后来实现的)。
根据frameworks/base/services/core/jni/com_android_server_VibratorService.cpp
/* * Copyright (C) 2009 The Android Open Source Project * * Licensed under the Apache License, Version 2.0 (the "License"); * you may not use this file except in compliance with the License. * You may obtain a copy of the License at * * http://www.apache.org/licenses/LICENSE-2.0 * * Unless required by applicable law or agreed to in writing, software * distributed under the License is distributed on an "AS IS" BASIS, * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. * See the License for the specific language governing permissions and * limitations under the License. */ #define LOG_TAG "LedService" #include "jni.h" #include "JNIHelp.h" #include "android_runtime/AndroidRuntime.h" #include#include#include#includestruct led_device_t *led_dev; namespace android { static jint LedOpen(JNIEnv *env, jobject clazz) { hw_module_t *module; hw_device_t *device; hw_get_module("led",(hw_module_t const **)&module); module->methods->open(module, NULL, &device); led_dev = (struct led_device_t*)device; return 0; } static jint LedOn(JNIEnv *env, jobject clazz, int arg) { led_dev->set_on(led_dev,arg); return 0; } static jint LedOff(JNIEnv *env, jobject clazz, int arg) { led_dev->set_off(led_dev,arg); return 0; } static JNINativeMethod method_table[] = { { "native_LedOpen", "()I", (void*)LedOpen }, { "native_LedOn", "(I)I", (void*)LedOn }, { "native_LedOff", "(I)I", (void*)LedOff} }; int register_android_server_LedService(JNIEnv *env) { return jniRegisterNativeMethods(env, "com/android/server/LedService", method_table, NELEM(method_table)); } };
7.注册native接口
在frameworks/base/services/core/jni/onload.cpp中添加
int register_android_server_LedService(JNIEnv* env);
register_android_server_LedService(env);
8.修改Android.mk
在frameworks/base/services/core/jni/Android.mk中加入自己写的com_android_server_LedService.cpp
$(LOCAL_REL_DIR)/com_android_server_LedService.cpp
9.mmm frameworks/base/services/编译
Copying: out/target/common/obj/JAVA_LIBRARIES/services_intermediates/classes.dex target Jar: services (out/target/common/obj/JAVA_LIBRARIES/services_intermediates/javalib.jar) Install: out/target/product/tiny4412/system/framework/services.jar make: Leaving directory `/opt/Tiny4412/Android/android-5.0.2' #### make completed successfully (50 seconds) ####
其中碰到一阵错误,非常无语:
make: Entering directory `/opt/Tiny4412/Android/android-5.0.2' make: *** No rule to make target `frameworks/base/services/core/.java', needed by `out/target/common/obj/JAVA_LIBRARIES/services.core_intermediates/classes-full-debug.jar'. Stop. make: Leaving directory `/opt/Tiny4412/Android/android-5.0.2' #### make failed to build some targets (1 seconds) ####
直接不往下编译,直接报错,非常难找错误,最后发现由于LedService.java的文件名多了个空格。出现这种错误一定要耐心,一定是某个小地方出错的。
最后继续使用./gen-img.sh完成system.img的编译,烧写进开发板,为写应用程序做准备。
3.应用程序设计:
package com.led.hal.example.callon.callonhalled; import android.os.RemoteException; import android.support.v7.app.AppCompatActivity; import android.os.Bundle; import android.view.View; import android.widget.CheckBox; import android.os.ILedService; import android.os.ServiceManager; public class MainActivity extends AppCompatActivity { private CheckBox[] Led = new CheckBox[4]; private ILedService iLedService = null; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); Led[0] = (CheckBox)findViewById(R.id.checkbox_led1); Led[1] = (CheckBox)findViewById(R.id.checkbox_led2); Led[2] = (CheckBox)findViewById(R.id.checkbox_led3); Led[3] = (CheckBox)findViewById(R.id.checkbox_led4); iLedService = ILedService.Stub.asInterface(ServiceManager.getService("led")); try { iLedService.LedOpen(); }catch(RemoteException e){ e.printStackTrace(); } } private void SendCmd(View view) { for(int i =1; i<5; i++) { if(Led[i].isChecked()) { try { iLedService.LedOn(i); }catch (RemoteException e){ e.printStackTrace(); } } else { try { iLedService.LedOff(i); }catch (RemoteException e){ e.printStackTrace(); } } } } }
程序其实很简单,但是涉及到android 中隐藏类的使用,我们的ILedService和ServiceManager其实都是隐藏类,你编译不过去的,添加相应的jar包才可以,参考
http://blog.csdn.net/wukunting/article/details/5788196
首先拷贝out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes.jar到工程下
然后AndroidStudio中File->Project Structure点击其中的'+'->选择Import .JAR/.AAR Package->选择classes.jar->Finish
继续在Project Structure下选择app->Dependencies->选择'+'->Module Dependency->选择'classes'即可。
这时候整个源码都好了,但是下载速度会很慢,改善基于frameworks设计的app下载和运行速度的方案:
1.修改build.gradle(Module:app)
apply plugin: 'com.android.application' android { compileSdkVersion 23 buildToolsVersion "23.0.2" defaultConfig { applicationId "com.led.hal.example.callon.callonhalled" minSdkVersion 21 targetSdkVersion 23 versionCode 1 versionName "1.0" multiDexEnabled true } dexOptions { javaMaxHeapSize "4g" } buildTypes { release { minifyEnabled false proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro' } } } dependencies { compile fileTree(dir: 'libs', include: ['*.jar']) testCompile 'junit:junit:4.12' compile 'com.android.support:appcompat-v7:23.2.0' compile project(':classes') compile 'com.android.support:multidex:1.0.0' }
2.修改AndroidManifest.xml
在application下增加
android:name="android.support.multidex.MultiDexApplication"
最后下载运行吧!
