当前位置:首页 > 芯闻号 > 充电吧
[导读]package com.example.administrator.progressbar; import android.app.ActionBar; import android.app.Act
import android.app.Activity;
import android.app.ProgressDialog;
import android.content.DialogInterface;
import android.os.Bundle;
import android.util.Property;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.view.Window;
import android.widget.Button;
import android.widget.ProgressBar;
import android.widget.Toast;
public class MainActivity extends Activity implements Button.OnClickListener{
    private ProgressBar progressBar;
    private Button btn_add;
    private Button btn_sub;
    private Button btn_reset;
    private Button btn_dialog;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
         * actionBar 进度条
        // 1、设置窗口特征
        requestWindowFeature(Window.FEATURE_PROGRESS); //进度条
        requestWindowFeature(Window.FEATURE_INDETERMINATE_PROGRESS); //loading
        setContentView(R.layout.activity_main);
        // 2、显示进度条
        setProgressBarVisibility(true);
        // 2、显示loading
        setProgressBarIndeterminateVisibility(true);
        setProgress(Window.PROGRESS_END / 2); //进度条长度为50% 最大为 10000
         * 进度条组件
        // 1、
        progressBar = (ProgressBar)findViewById(R.id.progressBar4);
        btn_add = (Button)findViewById(R.id.btn_add);
        btn_sub = (Button)findViewById(R.id.btn_sub);
        btn_reset = (Button)findViewById(R.id.btn_reset);
        btn_add.setOnClickListener(this);
        btn_sub.setOnClickListener(this);
        btn_reset.setOnClickListener(this);
         * 进度条对话框
        btn_dialog = (Button)findViewById(R.id.btn_dialog);
        btn_dialog.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                ProgressDialog progressBar_dialog = new ProgressDialog(MainActivity.this);
                progressBar_dialog.setTitle("进度条对话框");
                progressBar_dialog.setMessage("进度条对话框描述");
                progressBar_dialog.setIcon(R.mipmap.ic_launcher);
                progressBar_dialog.setProgressStyle(ProgressDialog.STYLE_HORIZONTAL);
                //这里不使用 setProgress、setSecondaryProgress 因为只会改变进度条 不会改变进度条下面的百分比文字
                progressBar_dialog.incrementProgressBy(50);
                progressBar_dialog.incrementSecondaryProgressBy(80);
                progressBar_dialog.setMax(100);
                progressBar_dialog.setButton(DialogInterface.BUTTON_POSITIVE, "确定", new DialogInterface.OnClickListener() {
                    @Override
                    public void onClick(DialogInterface dialog, int which) {
                        Toast.makeText(MainActivity.this, "点击了确定", Toast.LENGTH_SHORT).show();
                //不允许通过返回键关闭dialog 默认为 true
                progressBar_dialog.setCancelable(false);
                progressBar_dialog.show();
    @Override
        int _progress = progressBar.getProgress();
        int _second_progress = progressBar.getSecondaryProgress();
        switch (v.getId()){
            case R.id.btn_add:
                progressBar.incrementProgressBy(10);
                progressBar.incrementSecondaryProgressBy(10);
                break;
            case R.id.btn_sub:
                progressBar.setProgress(_progress - 10);
                progressBar.setSecondaryProgress(_second_progress - 10);
                break;
            case R.id.btn_reset:
                progressBar.setProgress(50);
                progressBar.setSecondaryProgress(80);
                break;
ActivityMain.xml
Progress_style.xml
