当前位置:首页 > 芯闻号 > 充电吧
[导读]用C++11绑定信号和槽,能使代码可读性更高,灵活性更强 注:connect()中可声明连接类型,默认缺省为AutoConnection 点击滚动到 “连接类型” 介绍↓ :#include#incl
点击滚动到 “连接类型” 介绍↓
#include#includeclass MyWindow : public QWidget
    Q_OBJECT
public:
    typedef  std::functionfuc1;
    MyWindow(QWidget *parent = 0);
    ~MyWindow();
    QPushButton *  btn;
    QLabel* label;  QVBoxLayout* Vbox;
    QGridLayout* grid;
    void click2(bool checked);
    void set(QString s);
public slots:
    void On_TestBtn_Cliked();
    void set2(QString s);
MyWindow::MyWindow(QWidget *parent)
    : QWidget(parent)
    label = new QLabel(QStringLiteral("你好"));
    btn  = new QPushButton("Test");
    grid = new QGridLayout();
    grid->addWidget(btn,0,0);
    Vbox = new QVBoxLayout();
    Vbox->addLayout(grid);
    Vbox->addWidget(label);
    setLayout(Vbox);
    fuc1 fu = std::bind(&MyWindow::click2, this, std::placeholders::_1);
    connect(btn, &QPushButton::clicked, this, fu);
MyWindow::~MyWindow()
void MyWindow::set(QString s)
    qDebug() <<"set:"<< QThread::currentThreadId();
    label->setText(s);
void MyWindow::set2(QString s)
    qDebug() << "set:" << QThread::currentThreadId();
    label->setText(s);
void MyWindow::click2(bool checked)
    qDebug() << "clcik2:"<start();
void MyWindow::On_TestBtn_Cliked()
    qDebug() << "click";
线程:
#pragma once
#include#includeclass MyThread :
    public QThread
    Q_OBJECT
public:
    QObject*  window;
    void run();
    MyThread(QObject* parent=NULL);
    ~MyThread();
signals:
    void  print(QString);
#include "MyThread.h"
#include "MainWindow.h"
MyThread::MyThread(QObject* parent):QThread(parent)
    window = parent;
    MyWindow*  w = (MyWindow*)parent;
 std::functionfu = std::bind(&MyWindow::set, w, std::placeholders::_1);
    connect(this, &MyThread::print, w,fu);
MyThread::~MyThread()
void  MyThread::run()
    qDebug() << "Thread Begin";
    int cout = 0;
    while (true)
        qDebug() << "MyThread::run:" << QThread::currentThreadId();
        emit print(QString::number(cout));
        Sleep(1);
        cout++;
可以看到,print绑定的线程id和主线程相同,为线程安全
    connect(this, &MyThread::print, w, [=](QString s) {
        w->set(s);
        qDebug() << "connet fuc:" << s << " " << QThread::currentThreadId();
        //此时 线程id为主线程,可随意调用主线程对象的界面操作
    int cout = 0;
    while (true)
      QMetaObject::invokeMethod(w, "set2", Q_ARG(QString, QString::number(cout)));
        Sleep(1);
        cout++;
    window = parent;
    connect(this, &MyThread::print, w, std::bind(&QLabel::setText, w->label , std::placeholders::_1));
connect(this, &MyThread::print, w->label, [=](QString s)
        //if(s.indexOf(xxxxx)) 此处可以对字符串进行过滤
        qDebug() << "Bind Fuc:" << QThread::currentThreadId();
        w->label->setText(s);
或者
修改界面中的槽set2为:
void MyWindow::set2(QString s, int pid)
    if (pid ==(int)QThread::currentThreadId())
        qDebug() << QStringLiteral(" 此类型的线程不在主线程中::" )<< s;
        qDebug() << "id_1:" << pid << " id_2:" << QThread::currentThreadId();
线程:
    int cout = 0;
    int _pid;
    while (true)
        _pid = (int)QThread::currentThreadId();
        qDebug() << "MyThread::run:" << _pid;
       // emit print(QString::number(cout));
        MyWindow*  w = (MyWindow*)window;
        QMetaObject::invokeMethod(w, "set2", Qt::ConnectionType::QueuedConnection,
            Q_ARG(QString, "QueuedConnection"), Q_ARG(int, _pid)
        QMetaObject::invokeMethod(w, "set2", Qt::ConnectionType::AutoConnection,
            Q_ARG(QString,"AutoConnection"), Q_ARG(int, _pid)
        QMetaObject::invokeMethod(w, "set2", Qt::ConnectionType::BlockingQueuedConnection,
            Q_ARG(QString, "BlockingQueuedConnection"),Q_ARG(int, _pid)
        QMetaObject::invokeMethod(w, "set2", Qt::ConnectionType::DirectConnection,
            Q_ARG(QString, "DirectConnection"), Q_ARG(int, _pid)
        QMetaObject::invokeMethod(w, "set2", Qt::ConnectionType::UniqueConnection,
            Q_ARG(QString, "UniqueConnection"), Q_ARG(int, _pid)
        Sleep(1);
        cout++;
可见,DirectConnection连接类型的线程ID与主线程不同,与线程相同,不是线程安全,其他连接类型暂时无法找到方法测试,有例子的朋友可以跟我交流下,谢谢
是官方说明的连接类型,翻译
说明:信号:发送者  槽:接受者  信号和槽所在的线程是创建他们的线程,而不是调用connnet的时候所在的线程 AutoConnection
如果接收方住在线程发出信号,使用Qt::DirectConnection。否则,使用Qt::QueuedConnection。连接类型发送信号时决定。
解释:
也就是说,自动判断,如果信号和槽在同一个线程,就调用Qt::DirectConnection,否则调用Qt::QueuedConnection
DirectConnection
调用插槽立即发出信号时。槽是在信号线程中执行的。
QueuedConnection
可以理解为异步?
当槽发送给调用接收事件循环的线程时,槽在接收者的线程中执行。
也就是说,此连接类型,只管把信号发送到槽所在的线程事件中,不会等待槽所在的线程事件处理完毕
,槽所在线程事件循环当处理到此信号时,才会执行相应操作
可以理解为同步,阻塞当前线程直到同步?
也就是说,此连接类型,不但把信号发送到槽所在的线程事件中,而且会等待槽所在的线程事件处理完毕
,槽所在线程事件循环当处理到此信号时,才会执行相应操作,信号所在的线程才会继续下一行代码
UniqueConnection
资料太少,不知道此类型的大概用途。。。
这是一个标志,可以结合上述任何一个连接类型,使用逐位或。当Qt:UniqueConnection,QObject:connect()将会失败如果连接已经存在(即如果相同的信号已经连接到同一个槽同一双对象)。这个标志是在Qt 4.6中引入的。
