当前位置:首页 > 芯闻号 > 充电吧
[导读] z-stack中的voidHalLedBlink (uint8 leds, uint8 numBlinks, uint8 percent, uint16 period)函数的深度解析 :参数:
参数:
      Leds:                 哪个led;
      numBlinks:       闪烁次数
      percent:        闪烁的占空比(就是高电平持续的时间)
      period:         一个闪烁的周期多少
HalLedBlink函数原型------
第一段代码:
void HalLedBlink (uint8 leds, uint8numBlinks, uint8 percent, uint16 period)
#if (defined (BLINK_LEDS)) &&(HAL_LED == TRUE)
 uint8 led;
 HalLedControl_t *sts;
  if(leds && percent && period)
   if (percent < 100)
     led = HAL_LED_1;
     leds &= HAL_LED_ALL;
     sts = HalLedStatusControl.HalLedControlTable;
      while (leds)                 //循环通过led <<= 1 找出需要闪烁的灯;sts++相对应的状态
        if (leds & led)            //找出我们设置闪烁的灯后满足条件进入设置对应的参数,这里涉及两个结构体
//HalLedControl_t和HalLedStatus_t,里面分别定义了相应的属性(请看其定义这里不列出);
// HalLedControlTable这个是HalLedControl_t结构体变量,用来存放控制灯模式的表,
//这个在HalLedStatus_t结构体里面定义,其实就相当一个结构体数组,
         /* Store the current state of the led before going to blinking if notalready blinking */
         if(sts->mode < HAL_LED_MODE_BLINK )
            preBlinkState |= (led &HalLedState);
         sts->mode  =HAL_LED_MODE_OFF;                    /*Stop previous blink */
         sts->time  = period;                              /* Time for oneon/off cycle */
         sts->onPct = percent;                             /* % of cycle LED ison */
         sts->todo  = numBlinks;                           /* Number of blinkcycles */
         if (!numBlinks) sts->mode |= HAL_LED_MODE_FLASH;  /* Continuous */
         sts->next = osal_GetSystemClock();                /* Start now */
          sts->mode |= HAL_LED_MODE_BLINK;                  /* Enable blinking */
         leds ^= led;
       led <<= 1;
       sts++;
     // Cancel any overlapping timer for blink events
     osal_stop_timerEx(Hal_TaskID, HAL_LED_BLINK_EVENT);
     osal_set_event (Hal_TaskID, HAL_LED_BLINK_EVENT);        //设置led闪烁事件,通过这个事件对灯进行控制,跳到第二段程序执行
   else
     HalLedSet (leds, HAL_LED_MODE_ON);                    /* >= 100%, turn on */
 else
   HalLedSet (leds, HAL_LED_MODE_OFF);                     /* No on time, turn off */
#elif (HAL_LED == TRUE)
 percent = (leds & HalLedState) ? HAL_LED_MODE_OFF : HAL_LED_MODE_ON;
 HalLedOnOff (leds, percent);                              /* Toggle */
#else
  //HAL LED is disabled, suppress unused argument warnings
 (void) leds;
 (void) numBlinks;
 (void) percent;
 (void) period;
#endif /* BLINK_LEDS && HAL_LED */
第二段代码:
if ( events & HAL_LED_BLINK_EVENT )
   HalLedUpdate();                                 //如果定义了BLINK_LEDS和HAL_LED == TRUE就执行此句,下面继续看第三段代码
   return events ^ HAL_LED_BLINK_EVENT;
第三段代码:
void HalLedUpdate (void)
   while (leds)
     if (leds & led)
       if (sts->mode & HAL_LED_MODE_BLINK)
         time = osal_GetSystemClock();
         if (time >= sts->next)
           if (sts->mode & HAL_LED_MODE_ON)
              pct = 100 - sts->onPct;              /* Percentage of cycle for off */
              sts->mode &=~HAL_LED_MODE_ON;       /* Say it's not on */
              HalLedOnOff (led,HAL_LED_MODE_OFF); /* Turn it off */ //重点来了,这个就是操作led电平函数,继续看第四段代码
                                                        //由于这个函数太多没有完全列出来,也没分析完我们就看重点
              if (!(sts->mode &HAL_LED_MODE_FLASH))
                sts->todo--;                        /* Not continuous,reduce count */
           else if ( (!sts->todo) && !(sts->mode &HAL_LED_MODE_FLASH) )
              sts->mode ^=HAL_LED_MODE_BLINK;      /* No moreblinks */
           else
              pct = sts->onPct;                     /* Percentage of cycle foron */
              sts->mode |= HAL_LED_MODE_ON;         /* Say it's on */
              HalLedOnOff (led,HAL_LED_MODE_ON);   /* Turn it on */
第四段代码
void HalLedOnOff (uint8 leds, uint8 mode)
  if(leds & HAL_LED_1)
   if (mode == HAL_LED_MODE_ON)
     HAL_TURN_ON_LED1();               //继续追踪下去,就找到对应的管脚,这里就不多说了,先介绍到这自己搞定后面的
   else
     HAL_TURN_OFF_LED1();
本人,刚写博客,这是我学习心得,有过之处望指出
