当前位置:首页 > 芯闻号 > 充电吧
[导读]#include  "KH25L6406.h"#define    SPI_WAIT()     while(FLASH_SPI->SR & BSY)/*****************
** Function name:       Send_Byte
** Descriptions:        通过硬件SPI发送一个字节到串行Flash器件
** input parameters:    data:  发送的数据
** output parameters:   NONE
** Returned value:      NONE
static void Send_Byte(unsigned char ucdata)
//   SSIDataPut(SSI0_BASE, ucdata);
    SPI_WAIT();
    FLASH_SPI->DR = ucdata;
** Function name:       Get_Byte
** Descriptions:        通过硬件SPI接口接收一个字节到处理器
** input parameters:    NONE
** Returned value:      ReadData  读回的数据
static unsigned char Get_Byte(void)
   uint16_t ulReadData;
//   SSIDataPut(SSI0_BASE, 0xFF);                         //  发送一个无效字节,以产生接收时钟
//   SSIDataGet(SSI0_BASE, &ulReadData);
    SPI_WAIT();
    FLASH_SPI->DR = 0xFF;
    SPI_WAIT();
    while (FLASH_SPI->SR & RNE)
    ulReadData = FLASH_SPI->DR;
    return ((unsigned char)ulReadData);
** Function name:       SPIFIFOClear
** Descriptions:        SPI 清空FIFO
static void SPIFIFOClear(void)
    uint16_t ulRecBuf = 0;
    SPI_WAIT();
      ulRecBuf = FLASH_SPI->DR;
    }                                                   /* 清空FIFO                     */
** Function name:       FLASH_GPIO_Init
** Descriptions:        GPIO口初始化
static void FLASH_KH25L6406E_GPIO_Init(void)
    SPI_CS_FLASH_GPIO ->FIODIR |= _BV(SPI_CS_FLASH_PIN);
** Function name:       serialFlashInit
** Descriptions:        初始化控制串行Flash的SSI管脚
** input parameters:    tAnyDevice:  串行Flash特性描述的结构体指针
void  serialFlashInit ( void)
    FLASH_KH25L6406E_GPIO_Init();
    CE_Low();
    SPIFIFOClear();
    CE_High();
** Function name:       serialFlash_RdID
** Descriptions:        读取串行Flash完整的ID
**                      ulReadID:   存储ID变量的指针
** Returned value:      操作成功则返回FLASH_OK,失败则返回FLASH_ERROR
** 注   意:             若填入的参数不符合要求,则返回FLASH_ERROR
static uint32 serialFlash_RdID ( void)
    uint32 ultemp = 0;
    CE_Low();
    Send_Byte(  ucReadJEDEC_ID);
    SPIFIFOClear();
    ultemp = (ultemp | Get_Byte()) << 8;                        // 接收数据
    ultemp = (ultemp | Get_Byte());
    SPI_WAIT();
    CE_High();
    return ultemp;
** Function name:       serialFlash_SelfTest
** Descriptions:        串行Flash自检程序
** output parameters:   FLASH_OK    : SPI_FLASH正常
**                      FLASH_ERROR : SPI_FLASH器件错误
uint8 serialFlash_SelfTest( void)
    if(serialFlash_RdID() == ulID)
        return FLASH_OK;
    return FLASH_ERROR;
** Function name:       serialFlash_RD
** Descriptions:        从串行Flash的指定起始地址读取指定字节的数据
**                      ulDstAddr:  指定读取数据的起始地址,范围要根据具体的器件而定
**                      pucRcvBuf: 读取数据存放的缓冲区指针
**                      ulNByte: 指定读取数据的大小,以字节为单位。为0,表示不读出任何数据。
** Returned value:      实际取出的字节数。一般情况下,应该等于ulNByte。如果小于ulNByte,则表示读取数据
**                      已经达到最大地址处。
unsigned long serialFlash_RD ( unsigned long ulDstAddr,
                             unsigned char* pucRcvBuf, unsigned long ulNByte)
    unsigned long i = 0;
    if((ulNByte == 0) || (ulDstAddr > (  ulMaxAddr)))
        return (0);                                                     //  检查入口参数
    if ((ulDstAddr + ulNByte - 1) > (  ulMaxAddr))
        ulNByte = (  ulMaxAddr) - ulDstAddr + 1;
     CE_Low();
     Send_Byte(  ucRead);                     // 发送读命令
     Send_Byte(((ulDstAddr & 0xFFFFFF) >> 16));                         // 发送地址信息:该地址由3个字节组成
     Send_Byte(((ulDstAddr & 0xFFFF) >> 8));
     Send_Byte(ulDstAddr & 0xFF);
     if(  ucIsReadWait != 0)
        Send_Byte(0xFF);
     SPIFIFOClear();
     for (i = 0; i < ulNByte; i++)
         pucRcvBuf[i] = Get_Byte();
     SPI_WAIT();
     CE_High();
    return (ulNByte);
** Function name:       serialFlash_WR
** Descriptions:        向串行Flash指定地址写入指定字节的数据
**                      pucSndBuf:  发送缓冲区的指针
**                      ulNByte:    发送数据的大小,以字节为单位。为0,表示不编程任何数据。
**                      已经达到最大地址处。
unsigned char serialFlash_PageProgram ( unsigned long ulDstAddr,
                               unsigned char* pucSndBuf,uint16 ulNByte)
    unsigned char ucTemp = 0, ucStatus = 0;
    uint16 i;
    uint8 ulReturn = 0;
//    if((ulNByte == 0) || (ulDstAddr > ulMaxAddr) || (ulNByte > 0x100))
//        return 0;
//    ulNByte = (ulDstAddr/0x100 + ulNByte)/0x100;
//    if((ulDstAddr/0x100 + ulNByte) > 0x100)
//        ulNByte = 0x100 - ulDstAddr/0x100 + 1;
//        ulReturn = ulNByte;
    do {
        CE_Low();
        Send_Byte( ucReadStatus);  // 发送读状态寄存器命令
        SPIFIFOClear();
        ucTemp = Get_Byte();        // 保存读得的状态寄存器值
        SPI_WAIT();
        CE_High();
    }while(ucTemp & 0x01);
    do {
        CE_Low();
        Send_Byte( ucEnWrite);       // 发送写使能命令
        SPI_WAIT();
        CE_High();
        CE_Low();
        SPIFIFOClear();
        SPI_WAIT();
        CE_High();
    } while(!(ucTemp & 0x02));
    CE_Low();
    Send_Byte(ucWrite);     // 发送字节数据烧写命令
    Send_Byte(((ulDstAddr & 0xFFFFFF) >> 16));    // 发送3个字节的地址信息
    for (i = 0; i <= ulNByte; i ++)
        Send_Byte(*pucSndBuf++);                    // 发送被烧写的数据
    CE_High();
    DelayUS(100);
    do {
        CE_Low();
        SPIFIFOClear();
        SPI_WAIT();
        CE_High();
    CE_Low();
    Send_Byte( ucDisWrite);       // 发送写使能命令
    SPI_WAIT();
    CE_High();
    return ulReturn;
** Function name:           serialFlash_SecErase
** Descriptions:            对串行Flash的指定的扇区进行擦除操作
**                          ulSecNo: 指定需要擦除的扇区,0代表第0扇区
unsigned char serialFlash_SecErase( unsigned long ulSecNo)
    unsigned char ucTemp= 0, ucStatus = 0;
    unsigned long ulAddr = 0;
    if(ulSecNo > (  ulSecMax))
        return (FLASH_ERROR);
    ulAddr = (  ulSecSize) * ulSecNo;// 计算扇区的起始地址
    do {
        CE_Low();
        SPIFIFOClear();
        SPI_WAIT();
        CE_High();
    do {
        CE_Low();
        SPI_WAIT();
        CE_High();
        CE_Low();
        SPIFIFOClear();
        SPI_WAIT();
        CE_High();
    CE_Low();
    Send_Byte(  ucSecErase);      // 发送扇区擦除指令
    Send_Byte(((ulAddr & 0xFFFFFF) >> 16));                 // 发送3个字节的地址信息
    Send_Byte(((ulAddr & 0xFFFF) >> 8));
    Send_Byte(ulAddr & 0xFF);
    SPI_WAIT();
    CE_High();
    do {
        CE_Low();
        SPIFIFOClear();
        SPI_WAIT();
        CE_High();
    CE_Low();
    SPI_WAIT();
    CE_High();
    return (FLASH_OK);
      END FILE
