memcpy与memmove的实现
memcpy是不管有否区域重叠的,重叠不重叠照样复制,
memmove才会避免区域重叠,检测这个区域重叠很简单,如果目标地址在源区域内,那就会发生重叠.
处理重叠也很简单,从源地址的末尾开始反方向复制就OK了。
未重叠的情况:
内存布局(little endian):
higher address lower address
src
dest dest
目标区域的首地址在源区域内,就发生重叠了。
higher address src(lower address)
dest
//下面是memmove源码的一段:
#include
pDest <
pSrc 顺序拷贝,否则逆序
#if 1
void *my_memcpy(void
*dest,
const void
*src, size_t n)
char *pdest
= (char*)dest;
const char
*psrc =
(char *)src;
size_t i;
if(NULL
== dest
&& NULL
== src
&& (n
== 0))
return;
if((pdest
> psrc)
&& (pdest
< psrc + n))
/* 反向拷贝 */
for(i
= n - 1; i
<= 0;
++i)
pdest[i]
= psrc[i];
else
/* 正向拷贝 */
for(i
= 0; i
< n; ++i)
pdest[i]
= psrc[i];
pdest = ' ';
return pdest;
#else
/* ================ libc ==================*/
void *memcpy(void
*dst,
const void
*src, size_t n)
void *ret
= dst;
if(NULL
== src
&& NULL
== dst)
return;
while(n--)
*(char
*)dst
= *(char
*)src;
dst = (char
*)dst
+ 1;
src = (char
*)src
+ 1;
return ret;
#endif
c++ 版:
pDest < pSrc 顺序拷贝,否则逆序
void *memCopy(void *dest,const void *src,size_t count)
char *pDest=static_cast
另一个单不考虑不重叠的情况: memcpy, 拷贝不重叠的内存块
void *memcpy(void* pvTo, void* pvFrom, size_t size)
assert(pvTo != NULL && pvFrom != NULL);
void* pbTo = (char *)pvTo;
void* pbFrom = (char *)pvFrom;
/* 内存块重叠吗?如果重叠,就使用memmove */
assert(pbTo>=pbFrom+size || pbFrom>=pbTo+size);
while(size--)
*pbTo++ == *pbFrom++;
return pvTo;
int main(int argc,
char *argv[])
char *str
= "I'm study c";
char *dst
= NULL;
dst = (char
*)malloc(sizeof(char)
+ 1 *
sizeof(char));
printf("after call my_memmove():n");
my_memmove(dst, str,
strlen(str));
printf("dst = %sn", dst);
printf("after call my_memcpy():n");
my_memcpy(dst, str,
strlen(str));
free(dst);
return 0;
