Atitit 流水线子线程异常处理
Atitit 流水线子线程异常处理
1.1. 大概原理是 FutureTask排除异常 FutureTask.get can throw ExecutionException,can catch this ex... 1
1.2. code 1
1.1. 大概原理是 FutureTaskt throw 异常 FutureTask.get can throw ExecutionException,can catch this ex...
Throwable cause = e.getCause();
if(cause.getMessage().contains("sub task err"))
RunEx re=(RunEx) cause;
System.out.println(JSON.toJSONString( re.returnObj));
System.out.println();
}else
ExUtil.throwExV2(e);
1.2. code
package com.cnhis.cloudhealth.clinical.clidoctor.clisendadvice.bo;
import java.util.Map;
import java.util.concurrent.Callable;
import java.util.concurrent.ExecutionException;
import java.util.concurrent.FutureTask;
import com.alibaba.fastjson.JSON;
import com.cnhis.cloudhealth.commons.util.oplogutil.AsynUtil;
import com.cnhis.cloudhealth.util.ExUtil;
import com.cnhis.cloudhealth.util.RunEx;
import com.google.common.collect.Maps;
public class FuturetaskExTest {
public static void main(String[] args) {
// TODO Auto-generated method stub
FutureTask tsk= subtask();
System.out.println("--");
try {
tsk.get();
} catch (InterruptedException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} catch (ExecutionException e) {
}else
//System.out.println("--");
public static FutureTask subtask() {
FutureTask
@Override
public Object call() {
System.out.println("--e in sub thread");
if("a".equals("a"))
Map m=Maps.newConcurrentMap();m.put("k", "vv");
throw new RunEx("sub task err",m);
return "err";
AsynUtil.execMeth_Ays( FutureTask_updateCviBdj,"");
return FutureTask_updateCviBdj;
