当前位置:首页 > 芯闻号 > 充电吧
[导读]package com.example.administrator.spinner; import android.content.Context; import android.support.v
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.widget.AdapterView;
import android.widget.ArrayAdapter;
import android.widget.SimpleAdapter;
import android.widget.Spinner;
import android.widget.TextView;
import android.widget.Toast;
import java.lang.reflect.Array;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
public class MainActivity extends ActionBarActivity implements Spinner.OnItemSelectedListener{
    private TextView textView;
    private Spinner spinner;
    private List data;
    private List<Map> data_list;
    private Context mContext;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mContext = this;
        textView = (TextView)findViewById(R.id.text);
        spinner = (Spinner)findViewById(R.id.spinner);
        //1 数据源
        data = new ArrayList();
        data.add("北京");
        data.add("上海");
        data.add("广州");
        data.add("重庆");
        data_list = new ArrayList<Map>();
        //2 适配器
        ArrayAdapter adapter = new ArrayAdapter(this,android.R.layout.simple_list_item_1,data);
        SimpleAdapter s_adapter = new SimpleAdapter(this,getData(),R.layout.item,new String[]{"text","pic"},new int[]{R.id.text,R.id.pic});
        //3 适配器样式
        //adapter.setDropDownViewResource(android.R.layout.simple_spinner_dropdown_item);
        adapter.setDropDownViewResource(R.layout.item);
        //4 注入适配器
       // spinner.setAdapter(adapter);
        spinner.setAdapter(s_adapter);
        spinner.setOnItemSelectedListener(this);
    @Override
    public void onItemSelected(AdapterView parent, View view, int position, long id) {
        textView.setText(spinner.getItemAtPosition(position).toString());
    @Override
    public void onNothingSelected(AdapterView parent) {
        Toast.makeText(mContext,"NotingSelected",Toast.LENGTH_SHORT);
    private List<Map> getData(){
        Mapmap = new HashMap();
        map.put("text","上海");
        map.put("pic",R.mipmap.ic_launcher);
        data_list.add(map);
        map.put("text","北京");
        data_list.add(map);
        map.put("text","深圳");
        data_list.add(map);
        map.put("text","广州");
        data_list.add(map);
        return data_list;
item.xml
