Ubuntu下安装GTK环境
要生成C图形界面的程序,得安装GTK环境
安装GTK环境只要安装一个gnome-core-devel就可以了,里面集成了很多其他的包。除此之外还要转一些其他的 东西,如libglib2.0 -doc、libgtk2.0-doc帮助文档,devhelp帮助文档查看,glade-gnome、glade-common、glade-doc图形界面设计等。
代码:
sudo apt-get install gnome-core-devel sudo apt-get install libglib2.0-doc libgtk2.0-doc sudo apt-get install devhelp sudo apt-get install glade-gnome glade-common glade-doc
写个测试程序,全是抄别人的,相当于windows下的SDK了。
记事本编写,终端命令编译:
#includevoid hello(GtkWidget *widget,gpointer data) { g_print("Hello Ubuntu!n"); } gint delete_event(GtkWidget *widget,GdkEvent *event,gpointer data) { g_print ("delete event occurredn"); return(TRUE); } void destroy(GtkWidget *widget,gpointer data) { gtk_main_quit(); } int main( int argc, char *argv[] ) { GtkWidget *window; GtkWidget *button; gtk_init (&argc, &argv); window=gtk_window_new (GTK_WINDOW_TOPLEVEL); gtk_signal_connect (GTK_OBJECT(window),"delete_event",GTK_SIGNAL_FUNC(delete_event),NULL); gtk_signal_connect (GTK_OBJECT (window), "destroy",GTK_SIGNAL_FUNC (destroy), NULL); gtk_container_set_border_width (GTK_CONTAINER (window), 10); button = gtk_button_new_with_label ("Hello Ubuntu!"); gtk_signal_connect (GTK_OBJECT (button), "clicked",GTK_SIGNAL_FUNC (hello), NULL); gtk_signal_connect_object (GTK_OBJECT (button), "clicked",GTK_SIGNAL_FUNC (gtk_widget_destroy),GTK_OBJECT (window)); gtk_container_add (GTK_CONTAINER (window), button); gtk_widget_show (button); gtk_widget_show (window); /*显示一个窗口*/ gtk_main(); /*进入主循环*/ return(0); }
保存为:gtkhello.c
用下面命令编译运行
代码:
$ gcc gtkhello.c -o gtktest `pkg-config --cflags --libs gtk+-2.0`
$ ./gtktest
会显示一个带有一个按钮的窗口,点击按钮以后窗口关闭,命令行显示Hello Ubuntu!
