当前位置:首页 > 芯闻号 > 充电吧
[导读]研究一下如何一起使用mpi和openmp先上程序:#include#include#ifdef _OPENMP #include#endif #ifdef MPICH_CC   #include#e
先上程序:
#include#endif
#ifdef MPICH_CC
  #include#endif
#define SIZE 512
#define SIZEM SIZE
#define SIZEN SIZE
#define SIZEK SIZE
#define DISPLAYT 1
double mytic()
	double result = 0.0;
	struct timeval tv;
	gettimeofday( &tv, NULL );
	result = tv.tv_sec*1e6 + tv.tv_usec;
	return result;
int main(int argc, char** argv)
#ifdef MPICH_CC
	int mpirank;
	int mpisize;
	MPI_Status mpistatus;
#endif
	float *ma;
	float *mb;
	float *mc;
	int m, n, k;
	int r, s, t;
	float tsum;
	double tstart, tend;
#ifdef MPICH_CC
	MPI_Init(&argc, &argv);
	MPI_Comm_rank(MPI_COMM_WORLD, &mpirank);
#endif
#ifdef _OPENMP
	omp_set_num_threads(2);
#endif
	/*Matrx A, B, C allocation.*/
	m = SIZEM; n = SIZEN; k = SIZEK;
	ma = (float*)malloc(m*n*sizeof(float));
	if (!ma){return -1;}
	mb = (float*)malloc(n*k*sizeof(float));
	if (!mb){free(ma);return -1;}
	mc = (float*)malloc(m*k*sizeof(float));
	if (!mc){free(ma);free(mb);return -1;}
	/*Matrx A, B, C initialization.*/
	srand((unsigned int)time(0));
	tstart = mytic();
	for (r = 0; r < m; r++)
		for (s = 0; s < n; s++)
			ma[r*n+s] = (1.0*rand())/RAND_MAX;
#if DISPLAYT
	printf("[T] ma initialization time : %.3fmsn", 1e-3*(mytic()-tstart));
#endif
	tstart = mytic();
	for (r = 0; r < n; r++)
		for (s = 0; s < k; s++)
			mb[r*k+s] = (1.0*rand())/RAND_MAX;
#if DISPLAYT
	printf("[T] mb initialization time : %.3fmsn", 1e-3*(mytic()-tstart));
#endif
	/*Compute matrix C*/
	tstart = mytic();
#pragma omp parallel for private(r,t,s,tsum) shared(m,n,k,ma,mb,mc)
		for (t = 0; t < k; t++)
			tsum = 0.0f;
				tsum += ma[r*n+s]*mb[s*k+t];
			mc[r*m+t] = tsum;
#if DISPLAYT
	printf("[T] mc computation time : %.3fmsn", 1e-3*(mytic()-tstart));
#endif
#ifdef MPICH_CC
	printf("[R] rank = %d with ", mpirank);
		if (0==omp_get_thread_num())
			printf("omp_size = %dn", omp_get_num_threads());
#endif
#ifdef MPICH_CC
#endif
#ifdef MPICH_CC
	printf("MPI -- parallel n");
	MPI_Finalize();
#else
	printf("       serial   n");
#endif
	free(ma);free(mb);free(mc);
	return 0;
使用如下命令编译这个代码
gcc -DMPICH_CC -O0 -fopenmp test.c `pkg-config --cflags --libs mpich` -o mpiomp.exe
执行代码(我用的是mpich)
mpiexec -n 2  ./mpiomp.exe
上面启动了两个进程来执行代码。
程序中,每个进程做的是一样的事情,都是计算两个矩阵的乘积,计算矩阵乘积的时候,我用openmp将矩阵乘积的计算分配给几个不同的线程来计算,以增加并行度。
如果你想在执行的时候设置openmp的线程数,可以把代码中第50行注释掉,然后用下面的命令执行。我是在ubuntu12.04上测试的,用的gcc-4.6.3,如果先不注释执行的话,再注释后按下面的命令执行的话,可能会得到跟之前一样的结果。这个原因我不是很清楚。有知道的,烦请告知一下呀。
 mpiexec -n 2 -env OMP_NUM_THREADS 4 ./mpiomp.exe
注意几点:
因为有很多新手,可能以上来执行不出来。所以给出一下几个可能出问提的点。
* 是否安装MPICH? 没有安装的话,麻烦先安装。源码安装的看这里 点击打开链接
* pkg-config出问题。 检查下 mpich.pc是否在pkg-config的搜索路径,或者man pkg-config研究下pkg-config
