CUDA5.5 的环境变量设置
为了方便,我写了这个文件用于设置cuda5.5的环境变量。
其中有些环境变量可能用不到,大家根据需要修改就是了。
export CUDA_HOME=/usr/local/cuda-5.5 export CUDA_INC_PATH=${CUDA_HOME}/include export CUDA_LIB_PATH=${CUDA_HOME}/lib64 export CUDA_INSTALL_PATH=${CUDA_HOME} export PATH=${CUDA_HOME}/bin:$PATH export PATH=${CUDA_HOME}/computeprof/bin:$PATH export LD_LIBRARY_PATH=${CUDA_HOME}/computeprof/bin:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=${CUDA_HOME}/lib64:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=${CUDA_HOME}/extras/CUPTI/lib64:$LD_LIBRARY_PATH export MANPATH=${CUDA_HOME}/man:$MANPATH export OPENCL_HOME=${CUDA_HOME} export OPENCL_INC_PATH=${OPENCL_HOME}/include export OPENCL_LIB_PATH=${OPENCL_HOME}/lib64 export LD_LIBRARY_PATH=${OPENCL_LIB_PATH}:$LD_LIBRARY_PATH
