当前位置:首页 > 芯闻号 > 充电吧
[导读]今天就介绍一下vs2013 下面调试libevent源码。不需要创建sln解决方案,只需要创建工程,包含源码目录即可源码调试。 1、手工添加test/print-winsocke-errors.c文件
源码目录即可源码调试。
1、手工添加test/print-winsocke-errors.c文件,不然nmake编译的时候会报错。
print-winsock-errors.c源代码程序:
#include#include#include#include#include "event2/event.h"
#include "event2/util.h"
#include "event2/thread.h"
#define E(x) printf (#x " -> "%s"n", evutil_socket_error_to_string (x));
int main (int argc, char **argv)
  int i, j;
  const char *s1, *s2;
#ifdef EVTHREAD_USE_WINDOWS_THREADS_IMPLEMENTED
  evthread_use_windows_threads ();
#endif
  s1 = evutil_socket_error_to_string (WSAEINTR);
  for (i = 0; i < 3; i++) {
    printf ("niteration %d:nn", i);
    E(WSAEINTR);
    E(WSAEACCES);
    E(WSAEFAULT);
    E(WSAEINVAL);
    E(WSAEMFILE);
    E(WSAEWOULDBLOCK);
    E(WSAEINPROGRESS);
    E(WSAEALREADY);
    E(WSAENOTSOCK);
    E(WSAEDESTADDRREQ);
    E(WSAEMSGSIZE);
    E(WSAEPROTOTYPE);
    E(WSAENOPROTOOPT);
    E(WSAEPROTONOSUPPORT);
    E(WSAESOCKTNOSUPPORT);
    E(WSAEOPNOTSUPP);
    E(WSAEPFNOSUPPORT);
    E(WSAEAFNOSUPPORT);
    E(WSAEADDRINUSE);
    E(WSAEADDRNOTAVAIL);
    E(WSAENETDOWN);
    E(WSAENETUNREACH);
    E(WSAENETRESET);
    E(WSAECONNABORTED);
    E(WSAECONNRESET);
    E(WSAENOBUFS);
    E(WSAEISCONN);
    E(WSAENOTCONN);
    E(WSAESHUTDOWN);
    E(WSAETIMEDOUT);
    E(WSAECONNREFUSED);
    E(WSAEHOSTDOWN);
    E(WSAEHOSTUNREACH);
    E(WSAEPROCLIM);
    E(WSASYSNOTREADY);
    E(WSAVERNOTSUPPORTED);
    E(WSANOTINITIALISED);
    E(WSAEDISCON);
    E(WSATYPE_NOT_FOUND);
    E(WSAHOST_NOT_FOUND);
    E(WSATRY_AGAIN);
    E(WSANO_RECOVERY);
    E(WSANO_DATA);
    E(0xdeadbeef); /* test the case where no message is available */
    /* fill up the hash table a bit to make sure it grows properly */
    for (j = 0; j < 50; j++) {
      int err;
      evutil_secure_rng_get_bytes(&err, sizeof(err));
      evutil_socket_error_to_string(err);
  s2 = evutil_socket_error_to_string (WSAEINTR);
  if (s1 != s2)
    printf ("caching failed!n");
  libevent_global_shutdown ();
  return EXIT_SUCCESS;
2、修改Makefile.nmake
将
CFLAGS=$(CFLAGS) /Ox /W3 /wd4996 /nologo
改为
CFLAGS=$(CFLAGS) /Od /W3 /wd4996 /nologo /Zi
使用/Od禁止优化,使用/Zi 生成调试信息。
3、vs2013命令行编译:nmake /f Makefile.nmake
编译生成:
4、新建工程,附加源码调试
解决方案包含源代码目录:
  以上三个目录添加到VC的附加库目录。
    lib包含目录添加刚才生成的
  所在目录
5、源码跟踪调试
F11跳入源码调试:
附上测试代码:
// libevent-test.cpp : 定义控制台应用程序的入口点。
#include "stdafx.h"
#pragma comment(lib,"ws2_32.lib")
#pragma comment(lib,"wsock32.lib")
#pragma comment(lib,"libevent.lib")
#pragma comment(lib,"libevent_core.lib")
#pragma comment(lib,"libevent_extras.lib")
#include#include#include#ifndef _WIN32
#include#include#endif
#include#ifdef EVENT__HAVE_SYS_TIME_H
#include#endif
#include#include#include#include#include#include#include#include#ifdef _WIN32
#include#endif
struct timeval lasttime;
int event_is_persistent;
static void
timeout_cb(evutil_socket_t fd, short event, void *arg)
    struct timeval newtime, difference;
    struct event *timeout = (struct event *)arg;
    double elapsed;
    evutil_gettimeofday(&newtime, NULL);
    evutil_timersub(&newtime, &lasttime, &difference);
    elapsed = difference.tv_sec +
        (difference.tv_usec / 1.0e6);
    printf("timeout_cb called at %d: %.3f seconds elapsed.n",
        (int)newtime.tv_sec, elapsed);
    lasttime = newtime;
    if (!event_is_persistent) {
        struct timeval tv;
        evutil_timerclear(&tv);
        tv.tv_sec = 2;
        event_add(timeout, &tv);
int
main(int argc, char **argv)
    struct event timeout;
    struct timeval tv;
    struct event_base *base;
    int flags;
#ifdef _WIN32
    WORD wVersionRequested;
    WSADATA wsaData;
    wVersionRequested = MAKEWORD(2, 2);
    (void)WSAStartup(wVersionRequested, &wsaData);
#endif
    if (argc == 2 && !strcmp(argv[1], "-p")) {
        event_is_persistent = 1;
        flags = EV_PERSIST;
    else {
        event_is_persistent = 0;
        flags = 0;
    /* Initalize the event library */
    base = event_base_new();
    /* Initalize one event */
    event_assign(&timeout, base, -1, flags, timeout_cb, (void*)&timeout);
    tv.tv_sec = 2;
    event_add(&timeout, &tv);
    evutil_gettimeofday(&lasttime, NULL);
    event_base_dispatch(base);
    return (0);
原文链接:https://www.cnblogs.com/Forever-Kenlen-Ja/p/7487207.html
