当前位置:首页 > 芯闻号 > 充电吧
[导读]总共三个类package wyf.lgz; import java.nio.ByteBuffer; import java.nio.ByteOrder; import java.nio.FloatB
总共三个类
package wyf.lgz;
import java.nio.FloatBuffer;
import java.util.ArrayList;
import javax.microedition.khronos.opengles.GL10;
public class DrawCylinder
	private FloatBuffer myVertexBuffer;//顶点坐标缓冲
	private FloatBuffer myNormalBuffer;//法向量缓冲
	private FloatBuffer myTexture;//纹理缓冲
	int textureId;
	int vCount;//顶点数量
	float length;//圆柱长度
	float circle_radius;//圆截环半径
	float degreespan;  //圆截环每一份的度数大小
	public float mAngleX;
	public float mAngleY;
	public float mAngleZ;
	public DrawCylinder(float length,float circle_radius,float degreespan,int textureId)
		this.circle_radius=circle_radius;
		this.length=length;
		this.degreespan=degreespan;
		this.textureId=textureId;
		float collength=(float)length;//圆柱每块所占的长度
		int spannum=(int)(360.0f/degreespan);
		ArrayListval=new ArrayList();//顶点存放列表
		ArrayListial=new ArrayList();//法向量存放列表
		for(float circle_degree=180.0f;circle_degree>0.0f;circle_degree-=degreespan)//循环行
				float x1 =(float)(-length/2);
				float y1=(float) (circle_radius*Math.sin(Math.toRadians(circle_degree)));
				float z1=(float) (circle_radius*Math.cos(Math.toRadians(circle_degree)));
				float a1=0;
				float b1=y1;
				float c1=z1;
				float l1=getVectorLength(a1, b1, c1);//模长
				a1=a1/l1;//法向量规格化
				b1=b1/l1;
				c1=c1/l1;
				float x2 =(float)(-length/2);
				float y2=(float) (circle_radius*Math.sin(Math.toRadians(circle_degree-degreespan)));
				float z2=(float) (circle_radius*Math.cos(Math.toRadians(circle_degree-degreespan)));
				float a2=0;
				float b2=y2;
				float c2=z2;
				float l2=getVectorLength(a2, b2, c2);//模长
				a2=a2/l2;//法向量规格化
				b2=b2/l2;
				c2=c2/l2;
				float x3 =(float)(length/2);
				float y3=(float) (circle_radius*Math.sin(Math.toRadians(circle_degree-degreespan)));
				float z3=(float) (circle_radius*Math.cos(Math.toRadians(circle_degree-degreespan)));
				float a3=0;
				float b3=y3;
				float c3=z3;
				float l3=getVectorLength(a3, b3, c3);//模长
				a3=a3/l3;//法向量规格化
				b3=b3/l3;
				c3=c3/l3;
				float x4 =(float)(length/2);
				float y4=(float) (circle_radius*Math.sin(Math.toRadians(circle_degree)));
				float z4=(float) (circle_radius*Math.cos(Math.toRadians(circle_degree)));
				float a4=0;
				float b4=y4;
				float c4=z4;
				float l4=getVectorLength(a4, b4, c4);//模长
				a4=a4/l4;//法向量规格化
				b4=b4/l4;
				c4=c4/l4;
				val.add(x1);val.add(y1);val.add(z1);//两个三角形,共6个顶点的坐标
				val.add(x2);val.add(y2);val.add(z2);
				val.add(x4);val.add(y4);val.add(z4);
				val.add(x3);val.add(y3);val.add(z3);
				ial.add(a1);ial.add(b1);ial.add(c1);//顶点对应的法向量
				ial.add(a2);ial.add(b2);ial.add(c2);
				ial.add(a4);ial.add(b4);ial.add(c4);
				ial.add(a3);ial.add(b3);ial.add(c3);
		vCount=val.size()/3;//确定顶点数量
		//顶点
		float[] vertexs=new float[vCount*3];
		for(int i=0;i<vCount*3;i++)
			vertexs[i]=val.get(i);
		ByteBuffer vbb=ByteBuffer.allocateDirect(vertexs.length*4);
		vbb.order(ByteOrder.nativeOrder());
		myVertexBuffer=vbb.asFloatBuffer();
		myVertexBuffer.put(vertexs);
		myVertexBuffer.position(0);
		//法向量
		float[] normals=new float[vCount*3];
			normals[i]=ial.get(i);
		ByteBuffer ibb=ByteBuffer.allocateDirect(normals.length*4);
		ibb.order(ByteOrder.nativeOrder());
		myNormalBuffer=ibb.asFloatBuffer();
		myNormalBuffer.put(normals);
		myNormalBuffer.position(0);
		//纹理
		float[] textures=generateTexCoor(spannum);
		ByteBuffer tbb=ByteBuffer.allocateDirect(textures.length*4);
		tbb.order(ByteOrder.nativeOrder());
		myTexture=tbb.asFloatBuffer();
		myTexture.put(textures);
		myTexture.position(0);
	public void drawSelf(GL10 gl)
		gl.glRotatef(mAngleX, 1, 0, 0);//旋转
		gl.glRotatef(mAngleY, 0, 1, 0);
		gl.glRotatef(mAngleZ, 0, 0, 1);
		gl.glEnableClientState(GL10.GL_VERTEX_ARRAY);//打开顶点缓冲
		gl.glVertexPointer(3, GL10.GL_FLOAT, 0, myVertexBuffer);//指定顶点缓冲
		gl.glEnableClientState(GL10.GL_NORMAL_ARRAY);//打开法向量缓冲
		gl.glNormalPointer(GL10.GL_FLOAT, 0, myNormalBuffer);//指定法向量缓冲
		gl.glEnable(GL10.GL_TEXTURE_2D);
		gl.glEnableClientState(GL10.GL_TEXTURE_COORD_ARRAY);
		gl.glTexCoordPointer(2, GL10.GL_FLOAT, 0, myTexture);
		gl.glBindTexture(GL10.GL_TEXTURE_2D, textureId);
		gl.glDrawArrays(GL10.GL_TRIANGLES, 0, vCount);//绘制图像
		gl.glDisableClientState(GL10.GL_TEXTURE_COORD_ARRAY);//关闭缓冲
		gl.glDisableClientState(GL10.GL_VERTEX_ARRAY);
		gl.glDisableClientState(GL10.GL_NORMAL_ARRAY);
	//法向量规格化,求模长度
	public float getVectorLength(float x,float y,float z)
		float pingfang=x*x+y*y+z*z;
		float length=(float) Math.sqrt(pingfang);
		return length;
    //自动切分纹理产生纹理数组的方法
    public float[] generateTexCoor(int bh)
    	float[] result=new float[bh*6*2];
    	float REPEAT=2;
    	float sizeh=1.0f/bh;//行数
    	int c=0;
    	for(int i=0;i<bh;i++)
    			//每行列一个矩形,由两个三角形构成,共六个点,12个纹理坐标
    			float t=i*sizeh;
    			result[c++]=0;
    			result[c++]=t;
    			result[c++]=0;
    			result[c++]=t+sizeh;
    			result[c++]=REPEAT;
    			result[c++]=t;
    			result[c++]=0;
    			result[c++]=REPEAT;
    			result[c++]=REPEAT;
    			result[c++]=t;
    	return result;
package wyf.lgz;
import android.app.Activity;
import android.content.pm.ActivityInfo;
import android.os.Bundle;
import android.view.Window;
import android.view.WindowManager;
public class Activity_GL_Cylinder extends Activity {
	private MyGLSurfaceView mGLSurfaceView;
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        requestWindowFeature(Window.FEATURE_NO_TITLE);
        getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN, WindowManager.LayoutParams.FLAG_FULLSCREEN);
        setRequestedOrientation(ActivityInfo.SCREEN_ORIENTATION_LANDSCAPE);
        mGLSurfaceView = new MyGLSurfaceView(this);
        setContentView(mGLSurfaceView);
        mGLSurfaceView.setFocusableInTouchMode(true);//设置为可触控
        mGLSurfaceView.requestFocus();//获取焦点
    @Override
    protected void onResume() {
        super.onResume();
        mGLSurfaceView.onResume();
    @Override
    protected void onPause() {
        super.onPause();
        mGLSurfaceView.onPause();
package wyf.lgz;
import java.io.IOException;
import java.io.InputStream;
import android.opengl.GLSurfaceView;
import android.opengl.GLUtils;
import javax.microedition.khronos.egl.EGLConfig;
import javax.microedition.khronos.opengles.GL11;
import android.content.Context;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.view.MotionEvent;
public class MyGLSurfaceView extends GLSurfaceView {
    private final float TOUCH_SCALE_FACTOR = 180.0f/320;//角度缩放比例
    private SceneRenderer mRenderer;//场景渲染器
    private float mPreviousY;//上次的触控位置Y坐标
    private float mPreviousX;//上次的触控位置Y坐标
	private int lightAngle=90;//灯的当前角度
	public MyGLSurfaceView(Context context) {
        super(context);
        mRenderer = new SceneRenderer();	//创建场景渲染器
        setRenderer(mRenderer);				//设置渲染器
        setRenderMode(GLSurfaceView.RENDERMODE_CONTINUOUSLY);//设置渲染模式为主动渲染
    //触摸事件回调方法
    @Override
    public boolean onTouchEvent(MotionEvent e) {
        float y = e.getY();
        float x = e.getX();
        switch (e.getAction()) {
        case MotionEvent.ACTION_MOVE:
            float dy = y - mPreviousY;//计算触控笔Y位移
            float dx = x - mPreviousX;//计算触控笔Y位移
            mRenderer.cylinder.mAngleX += dy * TOUCH_SCALE_FACTOR;//设置沿x轴旋转角度
            mRenderer.cylinder.mAngleZ += dx * TOUCH_SCALE_FACTOR;//设置沿z轴旋转角度
            requestRender();//重绘画面
        mPreviousY = y;//记录触控笔位置
        mPreviousX = x;//记录触控笔位置
        return true;
	private class SceneRenderer implements GLSurfaceView.Renderer
		int textureId;//纹理名称ID
    	DrawCylinder cylinder;//创建圆柱体
    	public SceneRenderer()
        public void onDrawFrame(GL10 gl) {
        	//清除颜色缓存
        	gl.glClear(GL10.GL_COLOR_BUFFER_BIT | GL10.GL_DEPTH_BUFFER_BIT);
        	//设置当前矩阵为模式矩阵
            gl.glMatrixMode(GL10.GL_MODELVIEW);
            //设置当前矩阵为单位矩阵
            gl.glLoadIdentity();
            gl.glPushMatrix();//保护变换矩阵现场
        	float lx=0; //设定光源的位置
            float ly=(float)(7*Math.cos(Math.toRadians(lightAngle)));
        	float lz=(float)(7*Math.sin(Math.toRadians(lightAngle)));
            float[] positionParamsRed={lx,ly,lz,0};
            gl.glLightfv(GL10.GL_LIGHT1, GL10.GL_POSITION, positionParamsRed,0);
            initMaterial(gl);//初始化纹理
            gl.glTranslatef(0, 0, -10f);//平移
            initLight(gl);//开灯
            cylinder.drawSelf(gl);//绘制
            closeLight(gl);//关灯
            gl.glPopMatrix();//恢复变换矩阵现场
        public void onSurfaceChanged(GL10 gl, int width, int height) {
            //设置视窗大小及位置
        	gl.glViewport(0, 0, width, height);
        	//设置当前矩阵为投影矩阵
            gl.glMatrixMode(GL10.GL_PROJECTION);
            //设置当前矩阵为单位矩阵
            //计算透视投影的比例
            float ratio = (float) width / height;
            //调用此方法计算产生透视投影矩阵
            gl.glFrustumf(-ratio, ratio, -1, 1, 1, 100);
        public void onSurfaceCreated(GL10 gl, EGLConfig config) {
            //关闭抗抖动
        	gl.glDisable(GL10.GL_DITHER);
        	//设置特定Hint项目的模式,这里为设置为使用快速模式
            gl.glHint(GL10.GL_PERSPECTIVE_CORRECTION_HINT,GL10.GL_FASTEST);
            //设置屏幕背景色黑色RGBA
            gl.glClearColor(0,0,0,0);
            //设置着色模型为平滑着色
            gl.glShadeModel(GL10.GL_SMOOTH);
            //启用深度测试
            gl.glEnable(GL10.GL_DEPTH_TEST);
            textureId=initTexture(gl,R.drawable.stone);//纹理ID
            cylinder=new DrawCylinder(10f,2f,18f,textureId);//创建圆柱体
//            //开启一个线程自动旋转光源
//            new Thread()
//          	  public void run()
//          		  while(true)
//          			lightAngle+=5;//转动灯
//          			mRenderer.cylinder.mAngleY+=2*TOUCH_SCALE_FACTOR;//球沿Y轴转动
//                    requestRender();//重绘画面
//                    try
//                  	  Thread.sleep(50);//休息10ms再重绘
//                    catch(Exception e)
//                  	  e.printStackTrace();
//            }.start();
	//初始化白色灯
	private void initLight(GL10 gl)
        gl.glEnable(GL10.GL_LIGHTING);//允许光照
        gl.glEnable(GL10.GL_LIGHT1);//打开1号灯
        //环境光设置
        float[] ambientParams={0.2f,0.2f,0.2f,1.0f};//光参数 RGBA
        gl.glLightfv(GL10.GL_LIGHT1, GL10.GL_AMBIENT, ambientParams,0);
        //散射光设置
        float[] diffuseParams={1f,1f,1f,1.0f};//光参数 RGBA
        gl.glLightfv(GL10.GL_LIGHT1, GL10.GL_DIFFUSE, diffuseParams,0);
        //反射光设置
        float[] specularParams={1f,1f,1f,1.0f};//光参数 RGBA
        gl.glLightfv(GL10.GL_LIGHT1, GL10.GL_SPECULAR, specularParams,0);
	//关闭灯
	private void closeLight(GL10 gl)
		gl.glDisable(GL10.GL_LIGHT1);
		gl.glDisable(GL10.GL_LIGHTING);
	//初始化材质
	private void initMaterial(GL10 gl)
        //环境光
        float ambientMaterial[] = {248f/255f, 242f/255f, 144f/255f, 1.0f};
        gl.glMaterialfv(GL10.GL_FRONT_AND_BACK, GL10.GL_AMBIENT, ambientMaterial,0);
        //散射光
        float diffuseMaterial[] = {248f/255f, 242f/255f, 144f/255f, 1.0f};
        gl.glMaterialfv(GL10.GL_FRONT_AND_BACK, GL10.GL_DIFFUSE, diffuseMaterial,0);
        //高光材质
        float specularMaterial[] = {248f/255f, 242f/255f, 144f/255f, 1.0f};
        gl.glMaterialfv(GL10.GL_FRONT_AND_BACK, GL10.GL_SPECULAR, specularMaterial,0);
        gl.glMaterialf(GL10.GL_FRONT_AND_BACK, GL10.GL_SHININESS, 100.0f);
	//初始化纹理
	public int initTexture(GL10 gl,int drawableId)//textureId
		//生成纹理ID
		int[] textures = new int[1];
		gl.glGenTextures(1, textures, 0);
		int currTextureId=textures[0];
		gl.glBindTexture(GL10.GL_TEXTURE_2D, currTextureId);
		gl.glTexParameterf(GL10.GL_TEXTURE_2D, GL10.GL_TEXTURE_MIN_FILTER,GL10.GL_LINEAR_MIPMAP_NEAREST);
        gl.glTexParameterf(GL10.GL_TEXTURE_2D,GL10.GL_TEXTURE_MAG_FILTER,GL10.GL_LINEAR_MIPMAP_LINEAR);
        ((GL11)gl).glTexParameterf(GL10.GL_TEXTURE_2D, GL11.GL_GENERATE_MIPMAP, GL10.GL_TRUE);
        gl.glTexParameterf(GL10.GL_TEXTURE_2D, GL10.GL_TEXTURE_WRAP_S,GL10.GL_REPEAT);
        gl.glTexParameterf(GL10.GL_TEXTURE_2D, GL10.GL_TEXTURE_WRAP_T,GL10.GL_REPEAT);
        InputStream is = this.getResources().openRawResource(drawableId);
        Bitmap bitmapTmp;
        try
        	bitmapTmp = BitmapFactory.decodeStream(is);
        finally
            try
                is.close();
            catch(IOException e)
        GLUtils.texImage2D(GL10.GL_TEXTURE_2D, 0, bitmapTmp, 0);
        bitmapTmp.recycle();
        return currTextureId;
