dialog,activity 屏蔽Home键详解
相信在Android应用上,很多时候逻辑是需要屏蔽Home键的,但这个用户体验是否需要,就看各位的需求了。
一般的方法屏蔽Home键,大家一定看过不少文章了。我总结一下,先说一下一般情况下Activity的屏蔽按键和Home键吧。
屏蔽其他键,重写onKeyDown
@Override public boolean onKeyDown(int keyCode, KeyEvent event) { Log.i(TAG,"keycode="+keyCode + " isBan="+isBan); switch (keyCode) { case KeyEvent.KEYCODE_BACK: Log.i(TAG,"KEYCODE_BACK"); return true; } return super.onKeyDown(keyCode, event); }
大家会发现,这里屏蔽Home键是捕捉不到的,因为大家的权限一般是User所以是无效的。
而其实android处理Home键等系统级按键是有一定的处理的。
看看源码是怎样处理的 frameworkspoliciesbasephonecomandroidinternalpolicyimplPhoneWindowManager.java #1092
// First we always handle the home key here, so applications // can never break it, although if keyguard is on, we do let // it handle it, because that gives us the correct 5 second // timeout. if (code == KeyEvent.KEYCODE_HOME) { // If a system window has focus, then it doesn't make sense // right now to interact with applications. WindowManager.LayoutParams attrs = win != null ? win.getAttrs() : null; if (attrs != null) { final int type = attrs.type; if (type == WindowManager.LayoutParams.TYPE_KEYGUARD || type == WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG) { // the "app" is keyguard, so give it the key return false; } final int typeCount = WINDOW_TYPES_WHERE_HOME_DOESNT_WORK.length; for (int i=0; i<typeCount; i++) { if (type == WINDOW_TYPES_WHERE_HOME_DOESNT_WORK[i]) { // don't do anything, but also don't pass it to the app return true; } } }
通过源码,我们不难发现两个的参数 WindowManager.LayoutParams.TYPE_KEYGUARD和
借鉴于此,重写onAttachedToWindow,以实现屏蔽Home键
public void onAttachedToWindow() { this.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD); super.onAttachedToWindow(); }
轮到dialog了,如果在Activity弹出dialog,在Activity设置以上2个方法是没办法屏蔽的。
其实,原理是一样的,只是地方不一样而已。
final Dialog dialog = new Dialog(this); dialog.setContentView(R.layout.mydailog); dialog.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD); dialog.show(); dialog.setOnKeyListener(new android.content.DialogInterface.OnKeyListener(){ @Override public boolean onKey(DialogInterface dialog, int keyCode,KeyEvent event) { switch (keyCode) { case KeyEvent.KEYCODE_BACK: Log.i(TAG,"KEYCODE_BACK"); return true; } return false; } });
这样运行后,出错如下:
10-18 13:27:06.380: ERROR/AndroidRuntime(4684): Caused by: android.view.WindowManager$BadTokenException: Unable to add window android.view.ViewRoot$W@2b046d68 -- permission denied for this window type
其实,只需要把dialog.getWindow().setType的位置放在show后面就可以了
dialog.show(); dialog.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD);
这么,就完成了Back键的屏蔽 和Home键盘的屏蔽了!
总结:
1:)在以上用WindowManager.LayoutParams.TYPE_KEYGUARD的地方改用
WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG 效果一样。至于两者的具体差别,得以后再研究研究。
2:)其实,在源码里是这样调用的。
final AlertDialog dialog = new AlertDialog.Builder(mContext) .setTitle(null) .setMessage(message) .setNeutralButton(R.string.ok, null) .create(); dialog.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG); dialog.show();
但我们如果这样调用就会出现之前的那个error:permission denied for this window type 这就显而易见了吧~~
3:)ProgressDialog 默认屏蔽 Back键,Dialog,AlertDialog则需setOnKeyListener
4:)其实屏蔽Home键,在页面的某个地方,例如一个Button的onClick里,去设置setType就可以了,如:
button.setOnClickListener(new View.OnClickListener() { @Override public void onClick(View v) { getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD); } });
但前提是重载Activity的onAttachedToWindow(),哪怕只是一个空实现,然后返回父类方法。
@Override public void onAttachedToWindow() { super.onAttachedToWindow(); }
5:)其实它们,都是常用的~
switch (keyCode) { case KeyEvent.KEYCODE_HOME: Log.i(TAG,"KEYCODE_HOME"); return true; case KeyEvent.KEYCODE_BACK: Log.i(TAG,"KEYCODE_BACK"); return true; case KeyEvent.KEYCODE_CALL: Log.i(TAG,"KEYCODE_CALL"); return true; case KeyEvent.KEYCODE_SYM: Log.i(TAG,"KEYCODE_SYM"); return true; case KeyEvent.KEYCODE_VOLUME_DOWN: Log.i(TAG,"KEYCODE_VOLUME_DOWN"); return true; case KeyEvent.KEYCODE_VOLUME_UP: Log.i(TAG,"KEYCODE_VOLUME_UP"); return true; case KeyEvent.KEYCODE_STAR: Log.i(TAG,"KEYCODE_STAR"); return true; }
总结1:)的问题,有答案了,时间问题我就简单写写吧:
从功能上来说,是一样的,区别在样式。
如果你喜欢用Theme.Dialog去把一个Activity装饰成一个Dialog去显示,你会发现。
在
Androidmanifest.xml代码 android:theme="@android:style/Theme.Dialog"
背景是透明的。
如果在
Android代码
setTheme(android.R.style.Theme_Dialog);
背景则是黑色的。
这是为什么呢?。。。我不知道。
治标不治本的方法来了!若你在Activity重写onAttachedToWindow
Java代码
public void onAttachedToWindow() { this.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG); super.onAttachedToWindow(); }
那么出来的效果,就是透明背景的dialog了,当然前提是你需要实现屏蔽Home键。至于其中到底哪一代码导致样式改变呢,那就以后再去看源代码了~
