TQ210 —— s5pv210 start.S分析
/* * armboot - Startup Code for S5PC110/ARM-Cortex CPU-core * * Copyright (c) 2009 Samsung Electronics * * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA * * Base codes by scsuh (sc.suh) */ /* * mod by lhh * * Our U-Boot Memory Map with static mmu_table * (offset) * -------------------------- * | Stack (512KB) | * -------------------------- * | Heap (1MB+envsize) | * -------------------------- * | IRQ Stack (KB) | <------------------------ if exists * -------------------------- * | FIQ Stack (KB) | <------------------------ if exists * -------------------------- * | GBL (B) | * -------------------------- 0x03exxxxx * | BSS and Reserved | * -------------------------- 0x03e60000 * | U-Boot (512KB) | * -------------------------- 0x03e00000 */ #include#include#if defined(CONFIG_ENABLE_MMU) #include#endif #include#ifndef CONFIG_ENABLE_MMU #ifndef CFG_PHY_UBOOT_BASE #define CFG_PHY_UBOOT_BASE CFG_UBOOT_BASE #endif /* CFG_PHY_UBOOT_BASE */ #endif /* CONFIG_ENABLE_MMU */ /* ************************************************************************* * * Jump vector table as in table 3.1 in [1] * ************************************************************************* */ #if defined(CONFIG_EVT1) && !defined(CONFIG_FUSED) .word 0x2000 .word 0x0 .word 0x0 .word 0x0 #endif /****************************************************************************** * .global关键字,相当于C语言extern,全局变量,外部可访问 * _start程序入口,即uboot代码的开始。_start后面“:”标号,类似C中goto后面标号 * _start的值就是代码的最起始,相对0的位置;跳转到reset这个标号执行,即复位向量 * ARM上电复位后,从0x00000000执行,跳转到reset,不会执行异常向量表这部分。 * * 异常向量表:未定义指令异常、软中断异常、预处理指令异常、未使用、数据异常、 * 中断异常、快速中断异常;每条占一字节,地址范围为0x0000 0000~0x0000 0020 * 设置异常向量表的作用是识别bootloader。以后系统每当有异常出现, * 则CPU会根据异常号,从内存的0x00000000处开始查表做相应的处理 *******************************************************************************/ .globl _start _start: b reset @相对跳转,不能用绝对跳转,因为启动代码有可能还运行在IRAM(s5pv210内部的SRAM) ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort ldr pc, _data_abort ldr pc, _not_used ldr pc, _irq ldr pc, _fiq @ .word伪操作,为分配一段字(4字节)内存单元 @ 用C表示:pc = *(_x) = x x=异常向量 _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort _data_abort: .word data_abort _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: @ 这填写的只是一个初始值,填充4字节 .word 0x12345678 /* now 16*4=64 */ .global _end_vect @ 异常向量结束标号 _end_vect: @ 表示接下来的代码使用16字节对齐,不足的使用0xdeadbeef填充(坏牛肉) @ 类似的还有一个0xbadc0de 坏代码(哈哈),十六进制没有o,是数字0 .balignl 16,0xdeadbeef /* ************************************************************************* * * Startup Code (reset vector) * * do important init only if we don't start from memory! * setup Memory and board specific bits prior to relocation. * relocate armboot to ram * setup stack * ************************************************************************* */ @ 代码段基地址,boardsamsungTQ210config.mk中定义,TEXT_BASE=0x23e00000 _TEXT_BASE: .word TEXT_BASE /* * Below variable is very important because we use MMU in U-Boot. * Without it, we cannot run code correctly before MMU is ON. * by scsuh. */ _TEXT_PHY_BASE: .word CFG_PHY_UBOOT_BASE @ *(_armboot_start) = _start .globl _armboot_start _armboot_start: .word _start /* * These are defined in the board-specific linker script. */ @ 栈头和栈尾定义在链接脚本里:boardsamsungTQ210u-boot.lds .globl _bss_start _bss_start: .word __bss_start .globl _bss_end _bss_end: .word _end @ 中断的堆栈设置,在cpu_init中用到 #if defined(CONFIG_USE_IRQ) /* IRQ stack memory (calculated at run-time) */ .globl IRQ_STACK_START IRQ_STACK_START: .word 0x0badc0de /* IRQ stack memory (calculated at run-time) */ .globl FIQ_STACK_START FIQ_STACK_START: .word 0x0badc0de #endif /* CONFIG_USE_IRQ */ /* * the actual reset code */ @ ARM复位执行就是这里的程序,上面那部分异常只有在异常发生才会执行 reset: /* * set the cpu to SVC32 mode and IRQ & FIQ disable */ @;mrs r0,cpsr @;bic r0,r0,#0x1f @;orr r0,r0,#0xd3 @;msr cpsr,r0 @ 置cpu到svc32模式,关闭中断;msr将0xd3写到cpsr_c 31 30 29 28 --- 7 6 - 4 3 2 1 0 说明 N Z C V I F M4 M3 M2 M1 M0 0 0 0 0 0 User模式 0 0 0 0 1 FIQ模式 0 0 0 1 0 IRQ模式 0 0 0 1 1 SVC模式 1 0 0 0 0 User模式 1 0 0 0 1 FIQ模式 1 0 0 1 0 IRQ模式 1 0 0 1 1 SVC模式 1 0 1 1 1 ABT模式 1 1 0 1 1 UND模式 msr cpsr_c, #0xd3 @ I & F disable, Mode: 0x13 - SVC 1101 0011 /* ************************************************************************* * * CPU_init_critical registers * * setup important registers * setup memory timing * ************************************************************************* */ /* * we do sys-critical inits only at reboot, * not when booting from ram! */ @ cpu初始化 cpu_init_crit: @ CONFIG_EVT1定义了,这段不执行 #ifndef CONFIG_EVT1 #if 0 bl v7_flush_dcache_all #else bl disable_l2cache mov r0, #0x0 @ mov r1, #0x0 @ i mov r3, #0x0 mov r4, #0x0 lp1: mov r2, #0x0 @ j lp2: mov r3, r1, LSL #29 @ r3 = r1(i) <<29 mov r4, r2, LSL #6 @ r4 = r2(j) <<6 orr r4, r4, #0x2 @ r3 = (i<<29)|(j<<6)|(1<<1) orr r3, r3, r4 mov r0, r3 @ r0 = r3 bl CoInvalidateDCacheIndex add r2, #0x1 @ r2(j)++ cmp r2, #1024 @ r2 < 1024 bne lp2 @ jump to lp2 add r1, #0x1 @ r1(i)++ cmp r1, #8 @ r1(i) < 8 bne lp1 @ jump to lp1 bl set_l2cache_auxctrl bl enable_l2cache #endif #endif bl disable_l2cache @ 关闭I/D-cache bl set_l2cache_auxctrl_cycle bl enable_l2cache @ 使能I/D-cache /* * Invalidate L1 I/D */ @ ARM Architecture Reference Manual.pdf的745页有例子,可以搜索CP15 @ CP15 —系统控制协处理器 (the system control coprocessor) @ 通过协处理器指令MCR和MRC提供具体的寄存器来配置和控制caches、MMU、保护系统、配置时钟模式(在bootloader时钟初始化用到) @ Register 7 - Cache control Register 8 - TLB operations mov r0, #0 @ set up for MCR mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs 关闭TLB 缓冲页表(虚拟机地址转物理地址的表)的cache mcr p15, 0, r0, c7, c5, 0 @ invalidate icache icache 缓冲指令的I-cache /* * disable MMU stuff and caches */ @ 关闭MMU和cache --- 分析cp15的寄存器1 mrc p15, 0, r0, c1, c0, 0 bic r0, r0, #0x00002000 @ clear bits 13 (--V-) bic r0, r0, #0x00000007 @ clear bits 2:0 (-CAM) orr r0, r0, #0x00000002 @ set bit 1 (--A-) Align orr r0, r0, #0x00000800 @ set bit 12 (Z---) BTB mcr p15, 0, r0, c1, c0, 0 /* Read booting information */ ldr r0, =PRO_ID_BASE ldr r1, [r0,#OMR_OFFSET] bic r2, r1, #0xffffffc1 /*电源管理,保持供电*/ #ifdef CONFIG_TQ210_IIC_PM_CHIP /* PS_HOLD(GPJ2_5) set to output high */ ldr r0, =ELFIN_GPIO_BASE ldr r1, =0x00100000 str r1, [r0, #GPJ2CON_OFFSET] ldr r1, =0x0400 str r1, [r0, #GPJ2PUD_OFFSET] ldr r1, =0x20 str r1, [r0, #GPJ2DAT_OFFSET] #endif /* CONFIG_TQ210_IIC_PM_CHIP */ #ifdef CONFIG_VOGUES /* PS_HOLD(GPH0_0) set to output high */ ldr r0, =ELFIN_GPIO_BASE ldr r1, =0x00000001 str r1, [r0, #GPH0CON_OFFSET] ldr r1, =0x5500 str r1, [r0, #GPH0PUD_OFFSET] ldr r1, =0x01 str r1, [r0, #GPH0DAT_OFFSET] #endif @ 启动方式nand,SD,nor /* NAND BOOT */ cmp r2, #0x0 @ 512B 4-cycle moveq r3, #BOOT_NAND cmp r2, #0x2 @ 2KB 5-cycle moveq r3, #BOOT_NAND cmp r2, #0x4 @ 4KB 5-cycle 8-bit ECC moveq r3, #BOOT_NAND cmp r2, #0x6 @ 4KB 5-cycle 16-bit ECC moveq r3, #BOOT_NAND cmp r2, #0x8 @ OneNAND Mux moveq r3, #BOOT_ONENAND /* SD/MMC BOOT */ cmp r2, #0xc moveq r3, #BOOT_MMCSD /* NOR BOOT */ cmp r2, #0x14 moveq r3, #BOOT_NOR #if 0 /* Android C110 BSP uses OneNAND booting! */ /* For second device booting */ /* OneNAND BOOTONG failed */ cmp r2, #0x8 moveq r3, #BOOT_SEC_DEV #endif /* Uart BOOTONG failed */ cmp r2, #(0x1<<4) moveq r3, #BOOT_SEC_DEV ldr r0, =INF_REG_BASE str r3, [r0, #INF_REG3_OFFSET] /* * Go setup Memory and board specific bits prior to relocation. */ ldr sp, =0xd0036000 /* end of sram dedicated to u-boot */ sub sp, sp, #12 /* set stack */ mov fp, #0 @ 跳到底层硬件初始化,这部分代码在自己建立的开发板目录下的lowlevel_init.S中 @ 会返回 bl lowlevel_init /* go setup pll,mux,memory */ /* To hold max8698 output before releasing power on switch, * set PS_HOLD signal to high */ ldr r0, =0xE010E81C /* PS_HOLD_CONTROL register */ ldr r1, =0x00005301 /* PS_HOLD output high */ str r1, [r0] /* get ready to call C functions */ ldr sp, _TEXT_PHY_BASE /* setup temp stack pointer */ sub sp, sp, #12 mov fp, #0 /* no previous frame, so fp=0 */ /* when we already run in ram, we don't need to relocate U-Boot. * and actually, memory controller must be configured before U-Boot * is running in ram. */ @ 比较r1和r2,拷贝到sram ldr r0, =0xff000fff bic r1, pc, r0 /* r0 <- current base addr of code */ ldr r2, _TEXT_BASE /* r1 <- original base addr in ram */ bic r2, r2, r0 /* r0 boot device is nand */ beq nand_boot cmp r1, #BOOT_ONENAND /* 0x1 => boot device is onenand */ beq onenand_boot cmp r1, #BOOT_MMCSD beq mmcsd_boot cmp r1, #BOOT_NOR beq nor_boot cmp r1, #BOOT_SEC_DEV beq mmcsd_boot nand_boot: mov r0, #0x1000 bl copy_from_nand b after_copy onenand_boot: bl onenand_bl2_copy b after_copy mmcsd_boot: #if DELETE ldr sp, _TEXT_PHY_BASE sub sp, sp, #12 mov fp, #0 #endif bl movi_bl2_copy b after_copy nor_boot: bl read_hword b after_copy after_copy: #if defined(CONFIG_ENABLE_MMU) enable_mmu: /* enable domain access */ ldr r5, =0x0000ffff mcr p15, 0, r5, c3, c0, 0 @load domain access register /* Set the TTB register */ ldr r0, _mmu_table_base ldr r1, =CFG_PHY_UBOOT_BASE ldr r2, =0xfff00000 bic r0, r0, r2 orr r1, r0, r1 mcr p15, 0, r1, c2, c0, 0 /* Enable the MMU */ mmu_on: mrc p15, 0, r0, c1, c0, 0 orr r0, r0, #1 mcr p15, 0, r0, c1, c0, 0 nop nop nop nop #endif skip_hw_init: /* Set up the stack */ @ 初始化栈,为第二阶段的C语言部分做准备 stack_setup: #if defined(CONFIG_MEMORY_UPPER_CODE) ldr sp, =(CFG_UBOOT_BASE + CFG_UBOOT_SIZE - 0x1000) #else ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CFG_MALLOC_LEN /* malloc area */ sub r0, r0, #CFG_GBL_DATA_SIZE /* bdinfo */ #if defined(CONFIG_USE_IRQ) sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif sub sp, r0, #12 /* leave 3 words for abort-stack */ #endif @ 清楚堆栈 clear_bss: ldr r0, _bss_start /* find start of bss segment */ ldr r1, _bss_end /* stop here */ mov r2, #0x00000000 /* clear */ @ 初始化直接使用双字,一次就是64个位 clbss_l: str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 ble clbss_l ldr pc, _start_armboot @ 跳转到stage2 _start_armboot: .word start_armboot #if defined(CONFIG_ENABLE_MMU) _mmu_table_base: .word mmu_table #endif /* * copy U-Boot to SDRAM and jump to ram (from NAND or OneNAND) * r0: size to be compared * Load 1'st 2blocks to RAM because U-boot's size is larger than 1block(128k) size */ .globl copy_from_nand copy_from_nand: push {lr} /* save return address */ mov r9, r0 mov r9, #0x100 /* Compare about 8KB */ bl copy_uboot_to_ram tst r0, #0x0 bne copy_failed #if defined(CONFIG_EVT1) ldr r0, =0xd0020000 #else ldr r0, =0xd0030000 #endif ldr r1, _TEXT_PHY_BASE /* 0x23e00000 */ #if !defined(CONFIG_SECURE_BOOT) 1: ldr r3, [r0], #4 ldr r4, [r1], #4 teq r3, r4 bne compare_failed /* not matched */ subs r9, r9, #4 bne 1b #endif pop {pc} /* all is OK */ copy_failed: /**************lhh add start******************/ ldr r0,= 0xE0200080 ldr r1, =(0x11<<12) str r1, [r0, #0] ldr r1, =(0x2<<3) str r1, [r0, #4] /**************lhh add end *******************/ nop /* copy from nand failed */ b copy_failed compare_failed: nop /* compare failed */ b compare_failed /* * we assume that cache operation is done before. (eg. cleanup_before_linux()) * actually, we don't need to do anything about cache if not use d-cache in U-Boot * So, in this function we clean only MMU. by scsuh * * void theLastJump(void *kernel, int arch_num, uint boot_params); */ #if defined(CONFIG_ENABLE_MMU) .globl theLastJump theLastJump: mov r9, r0 ldr r3, =0xfff00000 ldr r4, _TEXT_PHY_BASE adr r5, phy_last_jump bic r5, r5, r3 orr r5, r5, r4 mov pc, r5 phy_last_jump: /* * disable MMU stuff */ mrc p15, 0, r0, c1, c0, 0 bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */ bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */ orr r0, r0, #0x00000002 /* set bit 2 (A) Align */ orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ mcr p15, 0, r0, c1, c0, 0 mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ mov r0, #0 mov pc, r9 #endif /* ************************************************************************* * * Interrupt handling * ************************************************************************* */ @ @ IRQ stack frame. @ #define S_FRAME_SIZE 72 #define S_OLD_R0 68 #define S_PSR 64 #define S_PC 60 #define S_LR 56 #define S_SP 52 #define S_IP 48 #define S_FP 44 #define S_R10 40 #define S_R9 36 #define S_R8 32 #define S_R7 28 #define S_R6 24 #define S_R5 20 #define S_R4 16 #define S_R3 12 #define S_R2 8 #define S_R1 4 #define S_R0 0 #define MODE_SVC 0x13 #define I_BIT 0x80 /* * use bad_save_user_regs for abort/prefetch/undef/swi ... * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling */ .macro bad_save_user_regs sub sp, sp, #S_FRAME_SIZE @ carve out a frame on current user stack stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12 ldr r2, _armboot_start sub r2, r2, #(CFG_MALLOC_LEN) sub r2, r2, #(CFG_GBL_DATA_SIZE+8) @ set base 2 words into abort stack ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack add r5, sp, #S_SP mov r1, lr stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr mov r0, sp @ save current stack into r0 (param register) .endm .macro irq_save_user_regs sub sp, sp, #S_FRAME_SIZE stmia sp, {r0 - r12} @ Calling r0-r12 add r8, sp, #S_PC @ !!!! R8 NEEDS to be saved !!!! a reserved stack spot would be good. stmdb r8, {sp, lr}^ @ Calling SP, LR str lr, [r8, #0] @ Save calling PC mrs r6, spsr str r6, [r8, #4] @ Save CPSR str r0, [r8, #8] @ Save OLD_R0 mov r0, sp .endm .macro irq_restore_user_regs ldmia sp, {r0 - lr}^ @ Calling r0 - lr mov r0, r0 ldr lr, [sp, #S_PC] @ Get PC add sp, sp, #S_FRAME_SIZE subs pc, lr, #4 @ return & move spsr_svc into cpsr .endm .macro get_bad_stack ldr r13, _armboot_start @ setup our mode stack (enter in banked mode) sub r13, r13, #(CFG_MALLOC_LEN) @ move past malloc pool sub r13, r13, #(CFG_GBL_DATA_SIZE+8) @ move to reserved a couple spots for abort stack str lr, [r13] @ save caller lr in position 0 of saved stack mrs lr, spsr @ get the spsr str lr, [r13, #4] @ save spsr in position 1 of saved stack mov r13, #MODE_SVC @ prepare SVC-Mode @ msr spsr_c, r13 msr spsr, r13 @ switch modes, make sure moves will execute mov lr, pc @ capture return pc movs pc, lr @ jump to next instruction & switch modes. .endm .macro get_bad_stack_swi sub r13, r13, #4 @ space on current stack for scratch reg. str r0, [r13] @ save R0's value. ldr r0, _armboot_start @ get data regions start sub r0, r0, #(CFG_MALLOC_LEN) @ move past malloc pool sub r0, r0, #(CFG_GBL_DATA_SIZE+8) @ move past gbl and a couple spots for abort stack str lr, [r0] @ save caller lr in position 0 of saved stack mrs r0, spsr @ get the spsr str lr, [r0, #4] @ save spsr in position 1 of saved stack ldr r0, [r13] @ restore r0 add r13, r13, #4 @ pop stack entry .endm .macro get_irq_stack @ setup IRQ stack ldr sp, IRQ_STACK_START .endm .macro get_fiq_stack @ setup FIQ stack ldr sp, FIQ_STACK_START .endm /* * exception handlers */ .align 5 @32字节对齐 undefined_instruction: get_bad_stack @宏,保存现场栈 bad_save_user_regs @宏,保存现场 bl do_undefined_instruction @宏,答应现场 .align 5 software_interrupt: get_bad_stack_swi bad_save_user_regs bl do_software_interrupt .align 5 prefetch_abort: get_bad_stack bad_save_user_regs bl do_prefetch_abort .align 5 data_abort: get_bad_stack bad_save_user_regs bl do_data_abort .align 5 not_used: get_bad_stack bad_save_user_regs bl do_not_used #if defined(CONFIG_USE_IRQ) .align 5 irq: get_irq_stack irq_save_user_regs bl do_irq irq_restore_user_regs .align 5 fiq: get_fiq_stack /* someone ought to write a more effiction fiq_save_user_regs */ irq_save_user_regs bl do_fiq irq_restore_user_regs #else .align 5 irq: get_bad_stack bad_save_user_regs bl do_irq .align 5 fiq: get_bad_stack bad_save_user_regs bl do_fiq #endif .align 5 .global arm_cache_flush arm_cache_flush: mcr p15, 0, r1, c7, c5, 0 @ invalidate I cache mov pc, lr @ back to caller /* * v7_flush_dcache_all() * * Flush the whole D-cache. * * Corrupted registers: r0-r5, r7, r9-r11 * * - mm - mm_struct describing address space */ .align 5 .global v7_flush_dcache_all v7_flush_dcache_all: ldr r0, =0xffffffff mrc p15, 1, r0, c0, c0, 1 @ Read CLIDR ands r3, r0, #0x7000000 mov r3, r3, LSR #23 @ Cache level value (naturally aligned) beq Finished mov r10, #0 Loop1: add r2, r10, r10, LSR #1 @ Work out 3xcachelevel mov r1, r0, LSR r2 @ bottom 3 bits are the Ctype for this level and r1, r1, #7 @ get those 3 bits alone cmp r1, #2 blt Skip @ no cache or only instruction cache at this level mcr p15, 2, r10, c0, c0, 0 @ write the Cache Size selection register mov r1, #0 mcr p15, 0, r1, c7, c5, 4 @ PrefetchFlush to sync the change to the CacheSizeID reg mrc p15, 1, r1, c0, c0, 0 @ reads current Cache Size ID register and r2, r1, #0x7 @ extract the line length field add r2, r2, #4 @ add 4 for the line length offset (log2 16 bytes) ldr r4, =0x3FF ands r4, r4, r1, LSR #3 @ R4 is the max number on the way size (right aligned) clz r5, r4 @ R5 is the bit position of the way size increment ldr r7, =0x00007FFF ands r7, r7, r1, LSR #13 @ R7 is the max number of the index size (right aligned) Loop2: mov r9, r4 @ R9 working copy of the max way size (right aligned) Loop3: orr r11, r10, r9, LSL r5 @ factor in the way number and cache number into R11 orr r11, r11, r7, LSL r2 @ factor in the index number mcr p15, 0, r11, c7, c6, 2 @ invalidate by set/way subs r9, r9, #1 @ decrement the way number bge Loop3 subs r7, r7, #1 @ decrement the index bge Loop2 Skip: add r10, r10, #2 @ increment the cache number cmp r3, r10 bgt Loop1 Finished: mov pc, lr .align 5 .global disable_l2cache disable_l2cache: mrc p15, 0, r0, c1, c0, 1 bic r0, r0, #(1<<1) mcr p15, 0, r0, c1, c0, 1 mov pc, lr .align 5 .global enable_l2cache enable_l2cache: mrc p15, 0, r0, c1, c0, 1 orr r0, r0, #(1<<1) mcr p15, 0, r0, c1, c0, 1 mov pc, lr .align 5 .global set_l2cache_auxctrl set_l2cache_auxctrl: mov r0, #0x0 mcr p15, 1, r0, c9, c0, 2 mov pc, lr .align 5 .global set_l2cache_auxctrl_cycle set_l2cache_auxctrl_cycle: mrc p15, 1, r0, c9, c0, 2 bic r0, r0, #(0x1<<29) bic r0, r0, #(0x1<<21) bic r0, r0, #(0x7<<6) bic r0, r0, #(0x7<<0) mcr p15, 1, r0, c9, c0, 2 mov pc,lr .align 5 CoInvalidateDCacheIndex: ;/* r0 = index */ mcr p15, 0, r0, c7, c6, 2 mov pc,lr #if defined(CONFIG_INTEGRATOR) && defined(CONFIG_ARCH_CINTEGRATOR) /* Use the IntegratorCP function from board/integratorcp/platform.S */ #elif defined(CONFIG_S5PC11X) /* For future usage of S3C64XX*/ #else .align 5 .globl reset_cpu reset_cpu: ldr r1, rstctl /* get addr for global reset reg */ mov r3, #0x2 /* full reset pll+mpu */ str r3, [r1] /* force reset */ mov r0, r0 _loop_forever: b _loop_forever rstctl: .word PM_RSTCTRL_WKUP #endif
