SQL当前的进程信息,当前的执行语句
bb
-- List expensive queries DECLARE @MinExecutions int; SET @MinExecutions = 5 SELECT EQS.total_worker_time AS TotalWorkerTime ,EQS.total_logical_reads + EQS.total_logical_writes AS TotalLogicalIO ,EQS.execution_count As ExeCnt ,EQS.last_execution_time AS LastUsage ,EQS.total_worker_time / EQS.execution_count as AvgCPUTimeMiS ,(EQS.total_logical_reads + EQS.total_logical_writes) / EQS.execution_count AS AvgLogicalIO ,DB.name AS DatabaseName ,SUBSTRING(EST.text ,1 + EQS.statement_start_offset / 2 ,(CASE WHEN EQS.statement_end_offset = -1 THEN LEN(convert(nvarchar(max), EST.text)) * 2 ELSE EQS.statement_end_offset END - EQS.statement_start_offset) / 2 ) AS SqlStatement -- Optional with Query plan; remove comment to show, but then the query takes !!much longer time!! --,EQP.[query_plan] AS [QueryPlan] FROM sys.dm_exec_query_stats AS EQS CROSS APPLY sys.dm_exec_sql_text(EQS.sql_handle) AS EST CROSS APPLY sys.dm_exec_query_plan(EQS.plan_handle) AS EQP LEFT JOIN sys.databases AS DB ON EST.dbid = DB.database_id WHERE EQS.execution_count > @MinExecutions AND EQS.last_execution_time > DATEDIFF(MONTH, -1, GETDATE()) ORDER BY AvgLogicalIo DESC ,AvgCPUTimeMiS DESC
a
