当前位置:首页 > 芯闻号 > 充电吧
[导读]#ifndef _W5500_QUEUE_H_ #define _W5500_QUEUE_H_ #include "type.h" #define W5500_FRAME_SIZE
#include "type.h"
#define W5500_FRAME_SIZE          2048
#define W5500_RECV_QUEUE_SIZE     20
typedef enum
  W5500_FAILURE = 0,
  W5500_OK = 1,
} w5500_queue_status_t;
typedef __packed struct
  uint8_t data[W5500_FRAME_SIZE];
  uint16_t length;
} w5500_frame_t;
typedef struct
  uint16_t in;
  uint16_t out;
  uint16_t count;
  uint16_t item_size[W5500_RECV_QUEUE_SIZE];
  uint8_t data[W5500_RECV_QUEUE_SIZE][W5500_FRAME_SIZE];
} w5500_queue_t;
extern w5500_queue_t w5500_queue_recv;
void W5500QueueInit(w5500_queue_t *q);
uint8_t W5500QueueWrite(w5500_queue_t *q, w5500_frame_t *data);
uint8_t W5500QueueRead(w5500_queue_t *q, w5500_frame_t *data);
#endif /* _W5500_QUEUE_H_ */
#include "w5500_queue.h"
#include#include#include "debug.h"
  int i;
  for(i = 0; i < W5500_RECV_QUEUE_SIZE; ++i)
    memset(q->data[i], 0, W5500_FRAME_SIZE);
  memset(q->item_size, 0, sizeof(q->item_size));
  q->in   = 0;
  q->out  = 0;
  q->count = 0;
uint8_t W5500QueueWrite(w5500_queue_t *q, w5500_frame_t *frame)
  if((q->out % W5500_RECV_QUEUE_SIZE == q->in) && (q->count == W5500_RECV_QUEUE_SIZE))
    return W5500_FAILURE;
  q->item_size[q->in] = frame->length;
  memcpy(q->data[q->in], frame->data, frame->length);
  q->in = (q->in + 1) % W5500_RECV_QUEUE_SIZE;
  q->count++;
  return W5500_OK;
uint8_t W5500QueueRead(w5500_queue_t *q, w5500_frame_t *frame)
  if((q->in == q->out) && (q->count == 0))
  frame->length = q->item_size[q->out];
  memcpy(frame->data, q->data[q->out], q->item_size[q->out]);
  q->out = (q->out + 1) % W5500_RECV_QUEUE_SIZE;
  q->count--;
  return W5500_OK;
#ifndef _W5500_H_
#define _W5500_H_
#include "type.h"
#include "debug.h"
/***************** Common Register *****************/
#define MR    0x0000
#define RST   0x80
#define WOL   0x20
#define PB    0x10
#define PPP   0x08
#define FARP  0x02
#define GAR   0x0001
#define SUBR  0x0005
#define SHAR  0x0009
#define SIPR  0x000f
#define INTLEVEL  0x0013
#define IR        0x0015
#define CONFLICT  0x80
#define UNREACH   0x40
#define PPPOE     0x20
#define MP        0x10
#define IMR       0x0016
#define IM_IR7    0x80
#define IM_IR6    0x40
#define IM_IR5    0x20
#define IM_IR4    0x10
#define SIR       0x0017
#define S7_INT    0x80
#define S6_INT    0x40
#define S5_INT    0x20
#define S4_INT    0x10
#define S3_INT    0x08
#define S2_INT    0x04
#define S1_INT    0x02
#define S0_INT    0x01
#define SIMR      0x0018
#define S7_IMR    0x80
#define S6_IMR    0x40
#define S5_IMR    0x20
#define S4_IMR    0x10
#define S3_IMR    0x08
#define S2_IMR    0x04
#define S1_IMR    0x02
#define S0_IMR    0x01
#define RTR_w5500 0x0019
#define RCR_w5500 0x001b
#define PTIMER  0x001c
#define PMAGIC  0x001d
#define PHA     0x001e
#define PSID    0x0024
#define PMRU    0x0026
#define UIPR    0x0028
#define UPORT   0x002c
#define PHYCFGR 0x002e
#define RST_PHY 0x80
#define OPMODE  0x40
#define DPX     0x04
#define SPD     0x02
#define LINK    0x01
#define VERR    0x0039
/********************* Socket Register *******************/
#define Sn_MR         0x0000
#define MULTI_MFEN    0x80
#define BCASTB        0x40
#define ND_MC_MMB     0x20
#define UCASTB_MIP6B  0x10
#define MR_CLOSE      0x00
#define MR_TCP        0x01
#define MR_UDP        0x02
#define MR_MACRAW     0x04
#define Sn_CR         0x0001
#define OPEN          0x01
#define LISTEN        0x02
#define CONNECT       0x04
#define DISCON        0x08
#define CLOSE         0x10
#define SEND          0x20
#define SEND_MAC      0x21
#define SEND_KEEP     0x22
#define RECV          0x40
#define Sn_IR         0x0002
#define IR_SEND_OK    0x10
#define IR_TIMEOUT    0x08
#define IR_RECV       0x04
#define IR_DISCON     0x02
#define IR_CON        0x01
#define Sn_SR         0x0003
#define SOCK_CLOSED   0x00
#define SOCK_INIT     0x13
#define SOCK_LISTEN   0x14
#define SOCK_ESTABLISHED  0x17
#define SOCK_CLOSE_WAIT   0x1c
#define SOCK_UDP      0x22
#define SOCK_MACRAW   0x02
#define SOCK_SYNSEND  0x15
#define SOCK_SYNRECV  0x16
#define SOCK_FIN_WAI  0x18
#define SOCK_CLOSING  0x1a
#define SOCK_TIME_WAIT  0x1b
#define SOCK_LAST_ACK 0x1d
#define Sn_PORT   0x0004
#define Sn_DHAR   0x0006
#define Sn_DIPR   0x000c
#define Sn_DPORTR 0x0010
#define Sn_MSSR   0x0012
#define Sn_TOS    0x0015
#define Sn_TTL    0x0016
#define Sn_RXBUF_SIZE 0x001e
#define Sn_TXBUF_SIZE 0x001f
#define Sn_TX_FSR 0x0020
#define Sn_TX_RD  0x0022
#define Sn_TX_WR  0x0024
#define Sn_RX_RSR 0x0026
#define Sn_RX_RD  0x0028
#define Sn_RX_WR  0x002a
#define Sn_IMR      0x002c
#define IMR_SENDOK  0x10
#define IMR_TIMEOUT 0x08
#define IMR_RECV    0x04
#define IMR_DISCON  0x02
#define IMR_CON     0x01
#define Sn_FRAG     0x002d
#define Sn_KPALVTR  0x002f
/************************ SPI Control Byte *************************/
/* Operation mode bits */
#define VDM   0x00
#define FDM1  0x01
#define FDM2  0x02
#define FDM4  0x03
/* Read_Write control bit */
#define RWB_READ  0x00
#define RWB_WRITE 0x04
/* Block select bits */
#define COMMON_R  0x00
/* Socket 0 */
#define S0_REG    0x08
#define S0_TX_BUF 0x10
#define S0_RX_BUF 0x18
/* Socket 1 */
#define S1_REG    0x28
#define S1_TX_BUF 0x30
#define S1_RX_BUF 0x38
/* Socket 2 */
#define S2_REG    0x48
#define S2_TX_BUF 0x50
#define S2_RX_BUF 0x58
/* Socket 3 */
#define S3_REG    0x68
#define S3_TX_BUF 0x70
#define S3_RX_BUF 0x78
/* Socket 4 */
#define S4_REG    0x88
#define S4_TX_BUF 0x90
#define S4_RX_BUF 0x98
/* Socket 5 */
#define S5_REG    0xa8
#define S5_TX_BUF 0xb0
#define S5_RX_BUF 0xb8
/* Socket 6 */
#define S6_REG    0xc8
#define S6_TX_BUF 0xd0
#define S6_RX_BUF 0xd8
/* Socket 7 */
#define S7_REG    0xe8
#define S7_TX_BUF 0xf0
#define S7_RX_BUF 0xf8
#define SOCKET_OK  0xff
#define SOCKET_FAILURE 0x00
#define S_RX_SIZE 2048  /*定义Socket接收缓冲区的大小,可以根据W5500_RMSR的设置修改 */
#define S_TX_SIZE 2048    /*定义Socket发送缓冲区的大小,可以根据W5500_TMSR的设置修改 */
/***************----- 端口数据缓冲区 -----***************/
extern uint8_t socket_rx_buffer[2048]; //端口接收数据缓冲区
extern uint8_t socket_tx_buffer[2048]; //端口发送数据缓冲区
typedef unsigned char SOCKET;     //自定义端口号数据类型
void W5500Init(void);
void W5500SocketScan(void);
uint16_t W5500SocketRecv(uint8_t *buffer);
void W5500SocketSend(uint8_t *buffer, uint16_t length);
void W5500Process(void);
extern void w5500_test(void);
#endif
#include#include "stm32f10x.h"
#include "stm32f10x_spi.h"
#include "target.h"
#include "delay.h"
#include "w5500.h"
#include "debug.h"
static uint8_t gateway_addr[4];
static uint8_t sub_mask[4];
static uint8_t mac_addr[6];
static uint8_t ip_addr[4];
static uint8_t s0_port[2];   //端口0的端口号(5000)
static uint8_t s0_dip[4];    //端口0目的IP地址
static uint8_t s0_dport[2];  //端口0目的端口号(6000)
static uint8_t udp_daddr[4]; //UDP(广播)模式,目的主机IP地址
static uint8_t udp_dport[2]; //UDP(广播)模式,目的主机端口号
/***************----- 端口的运行模式 -----***************/
static uint8_t s0_mode = 3; //端口0的运行模式,0:TCP服务器模式,1:TCP客户端模式,2:UDP(广播)模式
#define TCP_SERVER  0x00  //TCP服务器模式
#define TCP_CLIENT  0x01  //TCP客户端模式
#define UDP_MODE    0x02  //UDP(广播)模式
/***************----- 端口的运行状态 -----***************/
static uint8_t s0_state = 0; //端口0状态记录,1:端口完成初始化,2端口完成连接(可以正常传输数据)
#define S_INIT    0x01  //端口完成初始化
#define S_CONN    0x02  //端口完成连接,可以正常传输数据
/***************----- 端口收发数据的状态 -----***************/
static uint8_t s0_data;    //端口0接收和发送数据的状态,1:端口接收到数据,2:端口发送数据完成
#define S_RECEIVE    0x01 //端口接收到一个数据包
#define S_TRANSMITOK 0x02 //端口发送一个数据包完成
static void w5500_gpio_init(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  W5500_RST_CONFIG();
  W5500_RST_LOW();
  W5500_INT_CONFIG();
  W5500_CS_CONFIG();
  W5500_SPI_CONFIG(); // clk  miso  mosi
static void w5500_spi_init(void)
  SPI_InitTypeDef SPI_InitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(W5500_SPI, &SPI_InitStructure);
  SPI_Cmd(W5500_SPI, ENABLE);
static void w5500_send_byte(uint8_t data)
  SPI_I2S_SendData(W5500_SPI, data);//写1个字节数据
  while(SPI_I2S_GetFlagStatus(W5500_SPI, SPI_I2S_FLAG_TXE) == RESET);//等待数据寄存器空
static void w5500_send_short(uint16_t data)
  w5500_send_byte(data / 256);
  w5500_send_byte(data);
static void w5500_write_byte(uint16_t reg, uint8_t data)
  W5500_CS_LOW();
  w5500_send_short(reg);
  w5500_send_byte(FDM1 | RWB_WRITE | COMMON_R); // 写控制字节,1个字节数据长度,写数据,选择通用寄存器
  W5500_CS_HIGH();
static void w5500_write_short(uint16_t reg, uint16_t data)
  W5500_CS_LOW();
  w5500_send_byte(FDM2 | RWB_WRITE | COMMON_R); // 写控制字节,2个字节数据长度,写数据,选择通用寄存器
  w5500_send_short(data);
  W5500_CS_HIGH();
static void w5500_write(uint16_t reg, uint8_t *buffer, uint16_t length)
  uint16_t i;
  W5500_CS_LOW();
  w5500_send_byte(VDM | RWB_WRITE | COMMON_R);
  for(i = 0; i < length; ++i)
    w5500_send_byte(*buffer++);
  W5500_CS_HIGH();
static void w5500_sock_write_byte(SOCKET s, uint16_t reg, uint8_t data)
  W5500_CS_LOW();
  w5500_send_byte(FDM1 | RWB_WRITE | (s * 0x20 + 0x08)); // 写控制字节,1个字节数据长度,写数据,选择端口s的寄存器
  W5500_CS_HIGH();
static void w5500_sock_write_short(SOCKET s, uint16_t reg, uint16_t data)
  W5500_CS_LOW();
  w5500_send_byte(FDM2 | RWB_WRITE | (s * 0x20 + 0x08)); // 写控制字节,2个字节数据长度,写数据,选择端口s的寄存器
  W5500_CS_HIGH();
static void w5500_sock_write_4bytes(SOCKET s, uint16_t reg, uint8_t *buffer)
  W5500_CS_LOW();
  w5500_send_byte(FDM4 | RWB_WRITE | (s * 0x20 + 0x08)); // 写控制字节,4个字节数据长度,写数据,选择端口s的寄存器
  W5500_CS_HIGH();
static uint8_t w5500_read_byte(uint16_t reg)
  uint8_t value;
  W5500_CS_LOW();
  w5500_send_byte(FDM1 | RWB_READ | COMMON_R); // 写控制字节,1个字节数据长度,读数据,选择通用寄存器
  value = SPI_I2S_ReceiveData(W5500_SPI);
  w5500_send_byte(0x00);
  W5500_CS_HIGH();
  return value;
static uint8_t w5500_sock_read_byte(SOCKET s, uint16_t reg)
  uint8_t value;
  W5500_CS_LOW();
  w5500_send_byte(FDM1 | RWB_READ | (s * 0x20 + 0x08)); // 写控制字节,1个字节数据长度,读数据,选择端口s的寄存器
  W5500_CS_HIGH();
  return value;
static uint16_t w5500_sock_read_2bytes(SOCKET s, uint16_t reg)
  uint16_t value;
  W5500_CS_LOW();
  w5500_send_byte(FDM2 | RWB_READ | (s * 0x20 + 0x08)); // 写控制字节,2个字节数据长度,读数据,选择端口s的寄存器
  value *= 256;
  value += SPI_I2S_ReceiveData(W5500_SPI);
  W5500_CS_HIGH();
  return value;
static uint16_t w5500_socket_read(SOCKET s, uint8_t *buffer)
  uint16_t rx_size, offset, offset1, i;
  uint8_t j;
  rx_size = w5500_sock_read_2bytes(s, Sn_RX_RSR);
  if(rx_size == 0)
    return 0;  //没接收到数据则返回
  if(rx_size > 1460)
    rx_size = 1460;
  offset = w5500_sock_read_2bytes(s, Sn_RX_RD);
  offset1 = offset;
  offset &= (S_RX_SIZE - 1); //计算实际的物理地址
  W5500_CS_LOW();
  w5500_send_short(offset);//写16位地址
  w5500_send_byte(VDM | RWB_READ | (s * 0x20 + 0x18)); //写控制字节,N个字节数据长度,读数据,选择端口s的寄存器
  j = SPI_I2S_ReceiveData(SPI2);
  if((offset + rx_size) < S_RX_SIZE) //如果最大地址未超过W5500接收缓冲区寄存器的最大地址
    for(i = 0; i < rx_size; i++) //循环读取rx_size个字节数据
      w5500_send_byte(0x00);//发送一个哑数据
      j = SPI_I2S_ReceiveData(SPI2); //读取1个字节数据
      *buffer = j; //将读取到的数据保存到数据保存缓冲区
      buffer++;//数据保存缓冲区指针地址自增1
  else//如果最大地址超过W5500接收缓冲区寄存器的最大地址
    offset = S_RX_SIZE - offset;
    for(i = 0; i < offset; i++) //循环读取出前offset个字节数据
    W5500_CS_HIGH();
    W5500_CS_LOW();
    w5500_send_short(0x00);//写16位地址
    for(; i < rx_size; i++) //循环读取后rx_size-offset个字节数据
  W5500_CS_HIGH();
  offset1 += rx_size; //更新实际物理地址,即下次读取接收到的数据的起始地址
  w5500_sock_write_short(s, Sn_RX_RD, offset1);
  w5500_sock_write_byte(s, Sn_CR, RECV);//发送启动接收命令
  return rx_size;//返回接收到数据的长度
static void w5500_socket_write(SOCKET s, uint8_t *buffer, uint16_t length)
  uint16_t offset, offset1, i;
  //如果是UDP模式,可以在此设置目的主机的IP和端口号
  if((w5500_sock_read_byte(s, Sn_MR) & 0x0f) != SOCK_UDP) //如果Socket打开失败
    w5500_sock_write_4bytes(s, Sn_DIPR, udp_daddr);//设置目的主机IP
    w5500_sock_write_short(s, Sn_DPORTR, udp_dport[0] * 256 + udp_dport[1]); //设置目的主机端口号
  offset = w5500_sock_read_2bytes(s, Sn_TX_WR);
  offset1 = offset;
  offset &= (S_TX_SIZE - 1); //计算实际的物理地址
  W5500_CS_LOW();
  w5500_send_byte(VDM | RWB_WRITE | (s * 0x20 + 0x10)); //写控制字节,N个字节数据长度,写数据,选择端口s的寄存器
  if((offset + length) < S_TX_SIZE) //如果最大地址未超过W5500发送缓冲区寄存器的最大地址
    for(i = 0; i < length; ++i) //循环写入size个字节数据
      w5500_send_byte(*buffer++);//写入一个字节的数据
  else//如果最大地址超过W5500发送缓冲区寄存器的最大地址
    offset = S_TX_SIZE - offset;
    for(i = 0; i < offset; ++i) //循环写入前offset个字节数据
    W5500_CS_HIGH();
    W5500_CS_LOW();
    for(; i < length; i++) //循环写入size-offset个字节数据
  W5500_CS_HIGH();
  offset1 += length; //更新实际物理地址,即下次写待发送数据到发送数据缓冲区的起始地址
  w5500_sock_write_short(s, Sn_TX_WR, offset1);
  w5500_sock_write_byte(s, Sn_CR, SEND);//发送启动发送命令
static void w5500_hardware_reset(void)
  W5500_RST_LOW();
  delay_ms(5);
  W5500_RST_HIGH();
  delay_ms(20);
  while((w5500_read_byte(PHYCFGR) & LINK) == 0);//等待以太网连接完成
static void w5500_reg_init(void)
  uint8_t i = 0;
  w5500_write_byte(MR, RST);//软件复位W5500,置1有效,复位后自动清0
  delay_ms(10);
  //设置网关(Gateway)的IP地址,Gateway_IP为4字节unsigned char数组,自己定义
  //使用网关可以使通信突破子网的局限,通过网关可以访问到其它子网或进入Internet
  w5500_write(GAR, gateway_addr, 4);
  //设置子网掩码(MASK)值,SUB_MASK为4字节unsigned char数组,自己定义
  //子网掩码用于子网运算
  w5500_write(SUBR, sub_mask, 4);
  //设置物理地址,PHY_ADDR为6字节unsigned char数组,自己定义,用于唯一标识网络设备的物理地址值
  //该地址值需要到IEEE申请,按照OUI的规定,前3个字节为厂商代码,后三个字节为产品序号
  //如果自己定义物理地址,注意第一个字节必须为偶数
  w5500_write(SHAR, mac_addr, 6);
  //设置本机的IP地址,IP_ADDR为4字节unsigned char数组,自己定义
  //注意,网关IP必须与本机IP属于同一个子网,否则本机将无法找到网关
  w5500_write(SIPR, ip_addr, 4);
  //设置发送缓冲区和接收缓冲区的大小,参考W5500数据手册
  for(i = 0; i < 8; i++)
    w5500_sock_write_byte(i, Sn_RXBUF_SIZE, 0x02); //Socket Rx memory size=2k
    w5500_sock_write_byte(i, Sn_TXBUF_SIZE, 0x02); //Socket Tx mempry size=2k
  //设置重试时间,默认为2000(200ms)
  //每一单位数值为100微秒,初始化时值设为2000(0x07D0),等于200毫秒
  w5500_write_short(RTR_w5500, 0x07d0);
  //设置重试次数,默认为8次
  //如果重发的次数超过设定值,则产生超时中断(相关的端口中断寄存器中的Sn_IR 超时位(TIMEOUT)置“1”)
  w5500_write_byte(RCR_w5500, 8);
  //启动中断,参考W5500数据手册确定自己需要的中断类型
  //IMR_CONFLICT是IP地址冲突异常中断,IMR_UNREACH是UDP通信时,地址无法到达的异常中断
  //其它是Socket事件中断,根据需要添加
  w5500_write_byte(IMR, IM_IR7 | IM_IR6);
  w5500_write_byte(SIMR, S0_IMR);
  w5500_sock_write_byte(0, Sn_IMR, IMR_SENDOK | IMR_TIMEOUT | IMR_RECV | IMR_DISCON | IMR_CON);
static uint8_t w5500_gateway_check(void)
  uint8_t ip_adde[4];
  ip_adde[0] = ip_addr[0] + 1;
  ip_adde[1] = ip_addr[1] + 1;
  ip_adde[2] = ip_addr[2] + 1;
  ip_adde[3] = ip_addr[3] + 1;
  //检查网关及获取网关的物理地址
  w5500_sock_write_4bytes(0, Sn_DIPR, ip_adde); //向目的地址寄存器写入与本机IP不同的IP值
  w5500_sock_write_byte(0, Sn_MR, MR_TCP); //设置socket为TCP模式
  w5500_sock_write_byte(0, Sn_CR, OPEN); //打开Socket
  delay_ms(5);//延时5ms
  if(w5500_sock_read_byte(0, Sn_SR) != SOCK_INIT) //如果socket打开失败
    w5500_sock_write_byte(0, Sn_CR, CLOSE); //打开不成功,关闭Socket
    return SOCKET_FAILURE;//返回FALSE(0x00)
  w5500_sock_write_byte(0, Sn_CR, CONNECT); //设置Socket为Connect模式
  do
    uint8_t j = 0;
    j = w5500_sock_read_byte(0, Sn_IR); //读取Socket0中断标志寄存器
    if(j != 0)
      w5500_sock_write_byte(0, Sn_IR, j);
    delay_ms(5);//延时5ms
    if((j & IR_TIMEOUT) == IR_TIMEOUT)
    else if(w5500_sock_read_byte(0, Sn_DHAR) != 0xff)
      w5500_sock_write_byte(0, Sn_CR, CLOSE); //关闭Socket
      return SOCKET_OK;
  while(1);
static void w5500_socket_init(SOCKET s)
  //设置分片长度,参考W5500数据手册,该值可以不修改
  w5500_sock_write_short(0, Sn_MSSR, 1460);//最大分片字节数=1460(0x5b4)
  //设置指定端口
  switch(s)
  case 0:
    if(UDP_MODE == s0_mode)
      //设置端口0的端口号
      w5500_sock_write_short(0, Sn_PORT, s0_port[0] * 256 + s0_port[1]);
    else if(TCP_CLIENT == s0_mode)
      //设置端口0的端口号
      //设置端口0目的(远程)端口号
      w5500_sock_write_short(0, Sn_DPORTR, s0_dport[0] * 256 + s0_dport[1]);
      //设置端口0目的(远程)IP地址
      w5500_sock_write_4bytes(0, Sn_DIPR, s0_dip);
    else if(TCP_SERVER == s0_mode)
      //设置端口0的端口号
  break;
  case 1:
    break;
  case 2:
    break;
  case 3:
    break;
  case 4:
    break;
  case 5:
    break;
  case 6:
    break;
  case 7:
    break;
  default:
    break;
static uint8_t w5500_socket_connect(SOCKET s)
  w5500_sock_write_byte(s, Sn_MR, MR_TCP);
  w5500_sock_write_byte(s, Sn_CR, OPEN);
  delay_ms(5);
  if(w5500_sock_read_byte(s, Sn_SR) != SOCK_INIT)
    w5500_sock_write_byte(s, Sn_CR, CLOSE);
  w5500_sock_write_byte(s, Sn_CR, CONNECT);
  return SOCKET_OK;
static uint8_t w5500_socket_listen(SOCKET s)
  delay_ms(5);
  w5500_sock_write_byte(s, Sn_CR, LISTEN);
  delay_ms(5);
  if(w5500_sock_read_byte(s, Sn_SR) != SOCK_LISTEN)
  return SOCKET_OK;
static uint8_t w5500_socket_udp(SOCKET s)
  w5500_sock_write_byte(s, Sn_MR, MR_UDP);
  delay_ms(5);
  if(w5500_sock_read_byte(s, Sn_SR) != SOCK_UDP)
  else
    return SOCKET_OK;
static void w5500_load_para(void)
  gateway_addr[0] = 192;
  gateway_addr[1] = 168;
  gateway_addr[2] = 1;
  gateway_addr[3] = 1;
  sub_mask[0] = 255;
  sub_mask[1] = 255;
  sub_mask[2] = 255;
  sub_mask[3] = 0;
  mac_addr[0] = 0x0c;
  mac_addr[1] = 0x29;
  mac_addr[2] = 0xab;
  mac_addr[3] = 0x7c;
  mac_addr[4] = 0x00;
  mac_addr[5] = 0x02;
  ip_addr[0] = 192;
  ip_addr[1] = 168;
  ip_addr[2] = 1;
  ip_addr[3] = 199;
  s0_port[0] = 0x18;
  s0_port[1] = 0x56;
  udp_daddr[0] = 192;
  udp_daddr[1] = 168;
  udp_daddr[2] = 1;
  udp_daddr[3] = 190;
#if 0
  s0_dip[0] = 192;
  s0_dip[1] = 168;
  s0_dip[2] = 1;
  s0_dip[3] = 99;
  s0_dport[0] = 0x18;
  s0_dport[1] = 0x56;
#endif
  udp_dport[0] = 0x17;
  udp_dport[1] = 0x70;
  s0_mode = UDP_MODE;
  w5500_gpio_init();
  w5500_spi_init();
  w5500_load_para(); // load net para [ip, port, mask...]
  w5500_hardware_reset();
  w5500_reg_init();
  w5500_gateway_check();
  w5500_socket_init(0);
  if(s0_state == 0)
    if(s0_mode == TCP_SERVER)
      if(w5500_socket_listen(0) == SOCKET_OK)
        s0_state = S_INIT;
      else
        s0_state = 0;
    else if(s0_mode == TCP_CLIENT)
      if(w5500_socket_connect(0) == SOCKET_OK)
        s0_state = S_INIT;
      else
        s0_state = 0;
    else
      if(w5500_socket_udp(0) == SOCKET_OK)
        debug("1234rn");
        s0_state = S_INIT | S_CONN;
      else
        s0_state = 0;
  uint16_t length;
  if((s0_data & S_RECEIVE) == S_RECEIVE)
    s0_data &= ~S_RECEIVE;
    length = w5500_socket_read(0, buffer);
  return length;
  if(s0_state == (S_INIT | S_CONN))
    s0_data &= ~S_TRANSMITOK;
    w5500_socket_write(0, buffer, length);
void W5500InterruptProcess(void)
  uint8_t i, j;
IntDispose:
  i = w5500_read_byte(IR);//读取中断标志寄存器
  w5500_write_byte(IR, (i & 0xf0));//回写清除中断标志
  if((i & CONFLICT) == CONFLICT)//IP地址冲突异常处理
    //自己添加代码
  if((i & UNREACH) == UNREACH)//UDP模式下地址无法到达异常处理
    debug("-------n");
    //自己添加代码
  i = w5500_read_byte(SIR); //读取端口中断标志寄存器
  if((i & S0_INT) == S0_INT)//Socket0事件处理
    if(j & IR_CON) //在TCP模式下,Socket0成功连接
      s0_state |= S_CONN; //网络连接状态0x02,端口完成连接,可以正常传输数据
    if(j & IR_DISCON) //在TCP模式下Socket断开连接处理
      w5500_sock_write_byte(0, Sn_CR, CLOSE); //关闭端口,等待重新打开连接
      w5500_socket_init(0);   //指定Socket(0~7)初始化,初始化端口0
      s0_state = 0; //网络连接状态0x00,端口连接失败
    if(j & IR_SEND_OK) //Socket0数据发送完成,可以再次启动S_tx_process()函数发送数据
      s0_data |= S_TRANSMITOK; //端口发送一个数据包完成
    if(j & IR_RECV) //Socket接收到数据,可以启动S_rx_process()函数
      s0_data |= S_RECEIVE; //端口接收到一个数据包
    if(j & IR_TIMEOUT) //Socket连接或数据传输超时处理
      w5500_sock_write_byte(0, Sn_CR, CLOSE); // 关闭端口,等待重新打开连接
  if(w5500_read_byte(SIR) != 0)
    goto IntDispose;
// test use
static void socket_data_process(SOCKET s)
  w5500_frame_t frame;
  frame.length = w5500_socket_read(s, frame.data);
// debug("socket_data_process...rn");
  W5500QueueWrite(&w5500_queue_recv, &frame);
    udp_daddr[0] = frame.data[0];
    udp_daddr[1] = frame.data[1];
    udp_daddr[2] = frame.data[2];
    udp_daddr[3] = frame.data[3];
    udp_dport[0] = frame.data[4];
    udp_dport[1] = frame.data[5];
  W5500SocketScan();
  debug("22222rn");
  W5500InterruptProcess();
  debug("3333rn");
  if((s0_data & S_RECEIVE) == S_RECEIVE)//如果Socket0接收到数据
    socket_data_process(0);//W5500接收并发送接收到的数据
  debug("1111rn");
  static uint16_t W5500_Send_Delay_Counter = 0;
  W5500_Send_Delay_Counter++;
  W5500SocketScan();
  else if(W5500_Send_Delay_Counter >= 500)//定时发送字符串
      memcpy(socket_tx_buffer, "rn123456rn", 10);
      w5500_socket_write(0, socket_tx_buffer, 10);//指定Socket(0~7)发送数据处理,端口0发送23字节数据
