HDU 5154 拓扑排序
题面:
Harry and Magical Computer
Time Limit: 2000/1000 MS (Java/Others) Memory Limit: 32768/32768 K (Java/Others)
Total Submission(s): 2183 Accepted Submission(s): 862
Problem Description
In reward of being yearly outstanding magic student, Harry gets a magical computer. When the computer begins to deal with a process, it will work until the ending of the processes. One day the computer got n processes to deal with.
We number the processes from 1 to n. However there are some dependencies between some processes. When there exists a dependencies (a, b), it means process b must be finished before process a. By knowing all the m dependencies, Harry wants to know if the computer
can finish all the n processes.
Input
There are several test cases, you should process to the end of file.
For each test case, there are two numbers n m on the first line, indicates the number processes and the number of dependencies.
1≤n≤100,1≤m≤10000
The next following m lines, each line contains two numbers a b, indicates a dependencies (a, b).
1≤a,b≤n
Output
Output one line for each test case.
If the computer can finish all the process print "YES" (Without quotes).
Else print "NO" (Without quotes).
Sample Input
3 2
3 1
2 1
3 3
3 2
2 1
1 3
Sample Output
YES NO
题意:
任务之间有依赖关系,如a->b,那么必须先完成任务b,才能完成任务a,问是否能够完成全部任务。
解题:
经典的拓扑排序,找入度为0的点,不断入队列,广搜即可,最后看是否所有点都被访问了。
代码:
#include#include#include#include#define inf 1000000 using namespace std; struct edge { int fm,to,nxt; }store[10010]; int in[105],vis[105],head[105],n,cnt; void addedge(int a,int b) { store[cnt].nxt=head[a]; head[a]=cnt; store[cnt].fm=a; store[cnt++].to=b; } queueq; void bfs() { int cur; for(int i=1;i<=n;i++) if(in[i]==0) q.push(i); while(!q.empty()) { cur=q.front(); q.pop(); vis[cur]=1; for(int i=head[cur];~i;i=store[i].nxt) { int v=store[i].to; in[v]--; if(in[v]==0) q.push(v); } } } int main() { int m,a,b; while(~scanf("%d%d",&n,&m)) { cnt=0; memset(head,-1,sizeof(head)); memset(in,0,sizeof(in)); memset(vis,0,sizeof(vis)); for(int i=0;i<m;i++) { scanf("%d%d",&a,&b); addedge(b,a); in[a]++; } bfs(); bool flag=1; for(int i=1;i<=n;i++) { if(vis[i]==0) { flag=0; break; } } if(flag) printf("YESn"); else printf("NOn"); } return 0; }
