当前位置:首页 > 芯闻号 > 充电吧
[导读]作者: Sam(甄峰) sam_code@hotmail.com   1. 解读hiddevice probe程序: static int hid_probe(struct usb_interface
static int hid_probe(struct usb_interface*intf, const struct usb_device_id *id)
 struct hid_device *hid;
 char path[64];
 int i;
 char *c;
 dbg_hid("HID probecalled for ifnum %dn",
   intf->altsetting->desc.bInterfaceNumber);
 if (!(hid =usb_hid_configure(intf)))
  return -ENODEV;
 usbhid_init_reports(hid);
 hid_dump_device(hid);
 if (hid->quirks &HID_QUIRK_RESET_LEDS)
  usbhid_set_leds(hid);
 if(!hidinput_connect(hid))
  hid->claimed |=HID_CLAIMED_INPUT;
 if (!hiddev_connect(hid))
  hid->claimed |=HID_CLAIMED_HIDDEV;
 usb_set_intfdata(intf,hid);
 if(!hid->claimed) {
  printk ("HID device not claimedby input or hiddevn");
  hid_disconnect(intf);
  return -ENODEV;
 if((hid->claimed &HID_CLAIMED_INPUT))
  hid_ff_init(hid);
 if(hid->quirks &HID_QUIRK_SONY_PS3_CONTROLLER)
  hid_fixup_sony_ps3_controller(interface_to_usbdev(intf),
   intf->cur_altsetting->desc.bInterfaceNumber);
 printk(KERN_INFO);
 if(hid->claimed &HID_CLAIMED_INPUT)
  printk("input");
 if (hid->claimed ==(HID_CLAIMED_INPUT | HID_CLAIMED_HIDDEV))
  printk(",");
 if (hid->claimed &HID_CLAIMED_HIDDEV)
  printk("hiddev%d",hid->minor);
 c = "Device";
 for (i = 0; i maxcollection; i++) {
  if(hid->collection[i].type ==HID_COLLECTION_APPLICATION &&
     (hid->collection[i].usage &HID_USAGE_PAGE) == HID_UP_GENDESK&&
     (hid->collection[i].usage & 0xffff)< ARRAY_SIZE(hid_types)) {
   c =hid_types[hid->collection[i].usage &0xffff];
   break;
 usb_make_path(interface_to_usbdev(intf),path, 63);
 printk(": USB HIDv%x.%02x %s [%s] on %sn",
  hid->version>> 8, hid->version& 0xff, c, hid->name,path);
 return 0;
1.1:usb_hid_configure(intf)解读:
从字面来看,它是指配置hid。
static struct hid_device*usb_hid_configure(struct usb_interface *intf)
 struct usb_host_interface *interface =intf->cur_altsetting;
 struct usb_device *dev = interface_to_usbdev(intf);
 struct hid_descriptor *hdesc;
 u32 quirks = 0;
 unsigned rsize = 0;
 char *rdesc;
 int n, len, insize = 0;
 struct usbhid_device *usbhid;
//得到对应vid,pid的quriks.如果没有,则返回0
 quirks =usbhid_lookup_quirk(le16_to_cpu(dev->descriptor.idVendor),
   le16_to_cpu(dev->descriptor.idProduct));
//如果为boot设备且为keyboard或mouse.则quirks=HID_QUIRK_NOGET
 if(interface->desc.bInterfaceSubClass ==USB_INTERFACE_SUBCLASS_BOOT) {
  if(interface->desc.bInterfaceProtocol ==USB_INTERFACE_PROTOCOL_KEYBOARD ||
   interface->desc.bInterfaceProtocol== USB_INTERFACE_PROTOCOL_MOUSE)
    quirks|= HID_QUIRK_NOGET;
//如果quirks显示要忽略,则退出probe
 if (quirks& HID_QUIRK_IGNORE)
  return NULL;
//HID_QUIRK_IGNORE_MOUSE表示如果为mouse,则忽略。
 if ((quirks& HID_QUIRK_IGNORE_MOUSE)&&
  (interface->desc.bInterfaceProtocol== USB_INTERFACE_PROTOCOL_MOUSE))
   returnNULL;
//如果interface扩展描述符中没有类型为HID_DT_HID条目,或者interface包含的endpoint数目为0,又或者interfaceendpoint中扩展描述符中没有类型为HID_DT_HID的条目。则退出。
 if(usb_get_extra_descriptor(interface, HID_DT_HID,&hdesc) &&
    (!interface->desc.bNumEndpoints ||
     usb_get_extra_descriptor(&interface->endpoint[0],HID_DT_HID, &hdesc))) {
  dbg_hid("class descriptor notpresentn");
  return NULL;
//得到描述符长度:
 for (n = 0; n< hdesc->bNumDescriptors; n++)
  if(hdesc->desc[n].bDescriptorType ==HID_DT_REPORT)
   rsize =le16_to_cpu(hdesc->desc[n].wDescriptorLength);
//如果描述符长度不对,则退出
 if (!rsize || rsize> HID_MAX_DESCRIPTOR_SIZE) {
  dbg_hid("weird size of reportdescriptor (%u)n", rsize);
  return NULL;
//创建此长度内存空间
 if (!(rdesc =kmalloc(rsize, GFP_KERNEL))) {
  dbg_hid("couldn't allocaterdesc memoryn");
  return NULL;
//向dev的endpoint发送HID_REQ_SET_IDLErequest.
 hid_set_idle(dev,interface->desc.bInterfaceNumber, 0, 0);
//取得reportdescription的详细信息,放到rdesc中。
 if ((n =hid_get_class_descriptor(dev,interface->desc.bInterfaceNumber, HID_DT_REPORT,rdesc, rsize)) < 0) {
  dbg_hid("reading reportdescriptor failedn");
  kfree(rdesc);
  return NULL;
 usbhid_fixup_report_descriptor(le16_to_cpu(dev->descriptor.idVendor),
   le16_to_cpu(dev->descriptor.idProduct),rdesc,
   rsize,rdesc_quirks_param);
 dbg_hid("reportdescriptor (size %u, read %d) = ", rsize, n);
 for (n = 0; n < rsize; n++)
  dbg_hid_line(" %02x", (unsignedchar) rdesc[n]);
 dbg_hid_line("n");
//解析report。并建立hid_device.返回给hid.
 if (!(hid =hid_parse_report(rdesc, n))) {
  dbg_hid("parsing reportdescriptor failedn");
  kfree(rdesc);
  return NULL;
 kfree(rdesc);
 hid->quirks = quirks;
 if (!(usbhid =kzalloc(sizeof(struct usbhid_device), GFP_KERNEL)))
  goto fail_no_usbhid;
 hid->driver_data =usbhid;
 usbhid->hid = hid;
 usbhid->bufsize =HID_MIN_BUFFER_SIZE;
 hid_find_max_report(hid, HID_INPUT_REPORT,&usbhid->bufsize);
 hid_find_max_report(hid, HID_OUTPUT_REPORT,&usbhid->bufsize);
 hid_find_max_report(hid, HID_FEATURE_REPORT,&usbhid->bufsize);
 if(usbhid->bufsize >HID_MAX_BUFFER_SIZE)
  usbhid->bufsize= HID_MAX_BUFFER_SIZE;
 hid_find_max_report(hid,HID_INPUT_REPORT, &insize);
 if (insize> HID_MAX_BUFFER_SIZE)
  insize =HID_MAX_BUFFER_SIZE;
 if(hid_alloc_buffers(dev, hid)) {
  hid_free_buffers(dev,hid);
  goto fail;
 for (n = 0; n< interface->desc.bNumEndpoints; n++){
  structusb_endpoint_descriptor *endpoint;
  int pipe;
  int interval;
  endpoint =&interface->endpoint[n].desc;
  if((endpoint->bmAttributes & 3) !=3)
   continue;
  interval =endpoint->bInterval;
  if(hid->collection->usage ==HID_GD_MOUSE &&hid_mousepoll_interval > 0)
   interval =hid_mousepoll_interval;
  if(usb_endpoint_dir_in(endpoint)) {
   if(usbhid->urbin)
    continue;
   if(!(usbhid->urbin = usb_alloc_urb(0,GFP_KERNEL)))
    gotofail;
   pipe =usb_rcvintpipe(dev,endpoint->bEndpointAddress);
   usb_fill_int_urb(usbhid->urbin,dev, pipe, usbhid->inbuf, insize,
     hid_irq_in, hid, interval);
   usbhid->urbin->transfer_dma= usbhid->inbuf_dma;
   usbhid->urbin->transfer_flags|= URB_NO_TRANSFER_DMA_MAP;
  } else {
   if(usbhid->urbout)
    continue;
   if(!(usbhid->urbout = usb_alloc_urb(0,GFP_KERNEL)))
    gotofail;
   pipe =usb_sndintpipe(dev,endpoint->bEndpointAddress);
   usb_fill_int_urb(usbhid->urbout,dev, pipe, usbhid->outbuf, 0,
     hid_irq_out, hid, interval);
   usbhid->urbout->transfer_dma= usbhid->outbuf_dma;
   usbhid->urbout->transfer_flags|= URB_NO_TRANSFER_DMA_MAP;
 if(!usbhid->urbin) {
  err_hid("couldn't find an inputinterrupt endpoint");
  goto fail;
 init_waitqueue_head(&hid->wait);
 INIT_WORK(&usbhid->reset_work,hid_reset);
 setup_timer(&usbhid->io_retry,hid_retry_timeout, (unsigned long) hid);
 spin_lock_init(&usbhid->inlock);
 spin_lock_init(&usbhid->outlock);
 spin_lock_init(&usbhid->ctrllock);
 hid->version =le16_to_cpu(hdesc->bcdHID);
 hid->country =hdesc->bCountryCode;
 hid->dev =&intf->dev;
 usbhid->intf = intf;
 usbhid->ifnum =interface->desc.bInterfaceNumber;
 hid->name[0] =0;
 if(dev->manufacturer)
  strlcpy(hid->name,dev->manufacturer,sizeof(hid->name));
 if(dev->product) {
   strlcat(hid->name," ", sizeof(hid->name));
  strlcat(hid->name,dev->product,sizeof(hid->name));
 if(!strlen(hid->name))
  snprintf(hid->name,sizeof(hid->name), "HID %04x:%04x",
 hid->bus= BUS_USB;
 hid->vendor =le16_to_cpu(dev->descriptor.idVendor);
 hid->product =le16_to_cpu(dev->descriptor.idProduct);
 usb_make_path(dev,hid->phys, sizeof(hid->phys));
 strlcat(hid->phys, "/input",sizeof(hid->phys));
 len = strlen(hid->phys);
 if (len phys) - 1)
  snprintf(hid->phys+ len, sizeof(hid->phys) - len,
    "%d",intf->altsetting[0].desc.bInterfaceNumber);
 if (usb_string(dev,dev->descriptor.iSerialNumber,hid->uniq, 64) <= 0)
  hid->uniq[0] =0;
 usbhid->urbctrl =usb_alloc_urb(0, GFP_KERNEL);
 if (!usbhid->urbctrl)
  goto fail;
 usb_fill_control_urb(usbhid->urbctrl,dev, 0, (void *) usbhid->cr,
       usbhid->ctrlbuf, 1, hid_ctrl, hid);
 usbhid->urbctrl->setup_dma= usbhid->cr_dma;
 usbhid->urbctrl->transfer_dma= usbhid->ctrlbuf_dma;
 usbhid->urbctrl->transfer_flags|= (URB_NO_TRANSFER_DMA_MAP | URB_NO_SETUP_DMA_MAP);
 hid->hidinput_input_event =usb_hidinput_input_event;
 hid->hid_open = usbhid_open;
 hid->hid_close =usbhid_close;
#ifdef CONFIG_USB_HIDDEV
 hid->hiddev_hid_event =hiddev_hid_event;
 hid->hiddev_report_event =hiddev_report_event;
#endif
 return hid;
fail:
 usb_free_urb(usbhid->urbin);
 usb_free_urb(usbhid->urbout);
 usb_free_urb(usbhid->urbctrl);
 hid_free_buffers(dev, hid);
 kfree(usbhid);
fail_no_usbhid:
 hid_free_device(hid);
 return NULL;
1.1.1:usbhid_lookup_quirk(pid,vid)解析:
分别使用usbhid_exists_dquirk(pid,vid),usbhid_exists_squirk(pid,vid)来查看动态和静态的quirks-list.如果有,则返回此quirks.没有,则返回0。
1.1.2:usb_get_extra_descriptor(descriptor, type,&hdesc)解析:
它调用__usb_get_extra_descriptor()来解析参数一(interface或endpoint描述符)中的扩展描述符区--extra。看是否有类型为参数二(type)的条目,然后把地址交给参数三。
Sam未经证明的猜测:HID设备中,interface描述符中包含的这个扩展描述符。其中存放的都是HID信息,以hid_descriptor结构存放。
对于HID设备来说,在interface description之后会附加一个hid description, hiddescription中的最后部份包含有Report description或者PhysicalDescriptors的长度.
hid_descriptor->usb_descriptor_header->bDescriptorType为HID_DT_HID
后面描述符(包括它自己)hid_descriptor->hid_class_descriptor->bDescriptorType为HID_DT_REPORT
1.1.3:hid_set_idle(structusb_device *dev, int ifnum, int report, intidle):
它简单的调用usb_control_msg() 发送或接收一个usb控制消息。
具体到这个例子中:
usb_control_msg(dev, usb_sndctrlpipe(dev, 0),
  HID_REQ_SET_IDLE,USB_TYPE_CLASS | USB_RECIP_INTERFACE, (idle<< 8) | report,
  ifnum, NULL, 0,USB_CTRL_SET_TIMEOUT);
usb_sndctrlpipe(dev,0):指出将dev中endpoint 0 设为发送control管道。
HID_REQ_SET_IDLE:此控制消息的Request。
USB_TYPE_CLASS |USB_RECIP_INTERFACE:请求类型.
调用成功才会返回。
1.1.4:hid_get_class_descriptor(dev,interface->desc.bInterfaceNumber, HID_DT_REPORT,rdesc, rsize)
也是通过调用usb_control_msg() 发送或接收一个usb控制消息。
发送USB_REQ_GET_DESCRIPTOR,将得到的report descriptor放到rdesc中。
1.1.5: hid_parse_report(__u8*start, unsigned size)
参数一:通过usb_control_msg发送request(USB_REQ_GET_DESCRIPTOR)从设备得到的report descriptor.
参数二:是此report Descriptor的长度。
1).首先创建hid_device类型设备。
2).将参数一中数据保存在hid_device->rdesc中。长度保存在hid_device->rsize中。
3). 使用fetch_item(__u8 *start, __u8 *end, struct hid_item*item)得到report description的下一项数据。放到item中。
4). 根据不同的item.type.分别调用
hid_parser_main,
  hid_parser_global,
  hid_parser_local,
  hid_parser_reserved
来处理。
