当前位置:首页 > 芯闻号 > 充电吧
[导读]n选m排列是一个经典算法题,如果m = n则称为全排列。 n选m排列问题的递归算法逻辑为: 1,将m个数的排列分为两部分:一部分为包含某个数k(1
n选m排列问题的递归算法逻辑为:
1,将m个数的排列分为两部分:一部分为包含某个数k(1 <= k <= n)的m排列,一部分为不包含k的m排列;
2,对于包含k的排列,又可以分为两部分:一部分为包含某个数s(k < s <= n)的m-1排列,一部分为不包含s的m-1排列;
3,对于2步所得m-1排列,将k插入到每一个排列中的m个位置可以得到m个新的m排列;
4,同步骤2,对于不包含k的排列可以进行类似的操作,最终将得到所有的n个元素的m排列。
递归算法的伪代码:
Begin:
input m, n;
if m is bigger than n, then set m = n;
if m is smaller than or equal to 0, then return;
if n is smaller than or equal to 0, then return;
PartA: get m permutation contains 1;
PartB: get m permutation not contains 1;
collect two permutations;
End;
PartA:
input k, m, n;
if m is equal to 1, then return 1 permutation only k;
PartA: get m-1 permutation contains k+1;
if m is smaller than (n - k + 1), then:
PartB: get m-1 permutation not contains k+1;
collect two permutation sets in one set;
foreach m-1 permutation, insert k to m different positions in this permutation, then get m permutation sets;
 End;
PartB:
input k, m, n
if m is equal to 1, then return (n-k+1) ones 1 permutation, each 1 permutation only contains k ~ n one element;
PartA: get m permutation contains k;
PartB: get m permutation not contains k;
collect two m permutation;
End;
C++代码实现:
#include
#include
#include
using namespace std;
void FullPremutationPartA(int firstNo, int numPremu, int numCount, vector> &vec);
void FullPremutationPartB(int secNo, int numPremu, int numCount, vector> &vec);
void FullPremutation(int numPremu, int numCount, vector> &vec);
int main()
	int numPremu,
		numCount;
	vector> vec;
	cout << "Input number of Premutation: ";
	cin >> numPremu;
	cout << "Input number of count: ";
	cin >> numCount;
	FullPremutation(numPremu, numCount, vec);
	int vecSize = vec.size();
	//for (int vecIndex = 0; vecIndex < vecSize; vecIndex++)
	//	int termSize = vec[vecIndex].size();
	//	for (int tIndex = 0; tIndex < termSize; tIndex++)
	//		cout << vec[vecIndex][tIndex] << "t";
	//	cout << endl;
	cout << "count = " << vecSize << endl;
	return 0;
	if ((numPremu <= 0) || (numCount <= 0))
		return;
	if (1 == numPremu)
		for (int premuIndex = 1; premuIndex <= numCount; premuIndex++)
			vector premuvec;
			premuvec.push_back(premuIndex);
			vec.push_back(premuvec);
		return;
	if (1 == numCount)
		vector premuvec;
		premuvec.push_back(numCount);
		return;
	if (numPremu > numCount)
		FullPremutation(numCount, numCount, vec);
		return;
	vector> PartAVector;
	FullPremutationPartA(1, numPremu, numCount, PartAVector);
	vec.insert(vec.end(), PartAVector.begin(), PartAVector.end());
	if (numPremu < numCount)
		vector> PartBVector;
		FullPremutationPartB(2, numPremu, numCount, PartBVector);
		vec.insert(vec.end(), PartBVector.begin(), PartBVector.end());
	return;
 * Function that process Premutation from firstNo to numCount
 * with count number of numPremu containing firstNo.
	if (firstNo > numCount)
		return;
	if ((1 == numPremu) || (firstNo == numCount))
		vector premuVec;
		premuVec.push_back(firstNo);
		vec.push_back(premuVec);
		return;
	FullPremutationPartA(firstNo + 1, numPremu - 1, numCount, PartAVector);
	vector> nunFullVector;
	nunFullVector.insert(nunFullVector.end(), PartAVector.begin(), PartAVector.end());
	if (numPremu < (numCount - firstNo + 1))
		FullPremutationPartB(firstNo + 2, numPremu - 1, numCount, PartBVector);
		nunFullVector.insert(nunFullVector.end(), PartBVector.begin(), PartBVector.end());
	int fullSize = nunFullVector.size();
	int termSize = nunFullVector[0].size();
	vec.resize(fullSize * (termSize + 1));
	int vecIndex = 0;
	for (int preIndex = 0; preIndex < fullSize; preIndex++)
		vector tmpVector;
		tmpVector.resize(termSize + 1);
		copy(nunFullVector[preIndex].begin(), nunFullVector[preIndex].end(), tmpVector.begin());
		tmpVector[termSize] = firstNo;
		vec[vecIndex].assign(tmpVector.begin(), tmpVector.end());
		vecIndex++;
		for (int termIndex = termSize; termIndex > 0 ; termIndex--)
			tmpVector[termIndex] = tmpVector[termIndex - 1];
			tmpVector[termIndex - 1] = firstNo;
			vecIndex++;
	return;
 * Function that process Premutation from SecNo to numCount
	if (secNo > numCount)
		return;
	if (1 == numPremu)
		for (int premuIndex = secNo; premuIndex <= numCount; premuIndex++)
			vector premuVec;
			premuVec.push_back(premuIndex);
		return;
	if (secNo == numCount)
		vector premuVec;
		premuVec.push_back(secNo);
		return;
	FullPremutationPartA(secNo, numPremu, numCount, PartAVector);
	if (numPremu < (numCount - secNo + 1))
		FullPremutationPartB(secNo + 1, numPremu, numCount, PartBVector);
	return;
我的实现对于n较小的时候,效率问题体现不出来,当n比较大的时候,效率特别慢,有更好的方法的朋友可以提点一些。
在实现的过程中,发现设计很重要,刚开始没有进行详细的设计,仅仅根据一点思路去实现,走了很多弯路,也花了很多的时间。所以算法设计一定要设计清晰,在实现中才能有的放矢的完善细节。
