Sorting It All Out
An ascending sorted sequence of distinct values is one in which some form of a less-than operator is used to order the elements from smallest to largest. For example, the sorted sequence A, B, C, D implies that A < B, B < C and C < D. in this problem, we will give you a set of relations of the form A < B and ask you to determine whether a sorted order has been specified or not.
Input
Input consists of multiple problem instances. Each instance starts with a line containing two positive integers n and m. the first value indicated the number of objects to sort, where 2 <= n <= 26. The objects to be sorted will be the first n characters of the uppercase alphabet. The second value m indicates the number of relations of the form A < B which will be given in this problem instance. Next will be m lines, each containing one such relation consisting of three characters: an uppercase letter, the character "<" and a second uppercase letter. No letter will be outside the range of the first n letters of the alphabet. Values of n = m = 0 indicate end of input.
Output
For each problem instance, output consists of one line. This line should be one of the following three:
Sorted sequence determined after xxx relations: yyy...y.
Sorted sequence cannot be determined.
Inconsistency found after xxx relations.
where xxx is the number of relations processed at the time either a sorted sequence is determined or an inconsistency is found, whichever comes first, and yyy...y is the sorted, ascending sequence.
输入样例
4 6
A
A
A
B
26 1
A
输出样例
Sorted sequence determined after 4 relations: ABCD.
Inconsistency found after 2 relations.
我们现在只看样例:4和6的含义分别是:
4表示表达式中一共含有4个字符,也就是说我们需要排序的是4个样例,6呢,就是需要用户输入6个表达式,我们根据这两个数值和相应的表达式,去推算字符的先后顺序
,可能会有三种结果,一种当然是排序成功,比如第一个输入,一种是会有逻辑冲突,比如第二个输入,一种就是条件不足,不能判断
我的算法思想是这样的,定义一个结构体,该结构体有三个变量,一个是key表示字符,一个是value,表示权重,一个就是布尔变量,表示该值是否已经参加运算
1.根据用户输入初始换结构体数组变量(chain_head),将相应的key值存到结构体当中,value则是UNSET,布尔类型变量则是false,表示还未参加到运算当中,
2.接下来,计算第n个表达式(n初始化成0),我们获取第n个表达式的第一个和第三个字符,分别获得该key在结构体数组中的索引,index_a和index_b,这样需要比较的就是
chain_head[index_a]和chain_head[index_b]了,首先看下chain_head[index_a].value是否小于chain_head[index_b].value,如果小于,则不进行任何操作,继续计算第n+1个
表达式,如果chain_head[index_a].value大于chain_head[index_b].value并且,chain_head[index_b].FirstApper=true(index_b的结构体从未参加运算),则表示逻辑冲突,停
止循环,输出结构,如果chain_head[index_a].value==chain_head[index_b].value则chain_head[index_b].value=chain_head[index_a].value+1;即可,然后进行第n+1个表达
式的计算,继续进行第二步的运算
3.清理现场,输出结果
源代码如下:
// Sort_It.cpp : 定义控制台应用程序的入口点。
#include "stdafx.h"
#include
using namespace std;
***文件名称:Sort_It.cpp
***文件描述:根据表达式对字符进行排序
typedef struct {
char key;
int value;
bool FirstApper;
}Key_Value;
Key_Value* chain_head=NULL;
int nCount=0;//需要排序的字符个数
int nCur_Count=0;//当前已经赋值的个数
int result=0;
#define DONE 1
#define INCONSIST 2
#define UNENOUGH 3
#define UNSET 1
void operation(char key_a,char key_b);
///函数名称:TestOver
///函数描述:检测根据当前获得信息,检测是否已经可以完成排序(value的值叠加,如果等于1,2,3的和则表示排序完成)
bool TestOver(Key_Value* head)
int nSum_1=0,nSum=0;
for(int i=0;i
