当前位置:首页 > 芯闻号 > 充电吧
[导读]1、AnimationDrawablejava.lang.Object    ↳ android.graphics.drawable.Drawable      ↳ android.graphics.
1、AnimationDrawable
java.lang.Object    ↳ android.graphics.drawable.Drawable      ↳ android.graphics.drawable.DrawableContainer        ↳ android.graphics.drawable.AnimationDrawable 文档概述:
An object used to create frame-by-frame animations, defined by a series of Drawable objects, which can be used as a View object's background.
An AnimationDrawable defined in XML consists of a single element, and a series of nested tags. Each item defines a frame of the animation. See the example below.
Here is the code to load and play this animation.
 // Load the ImageView that will host the animation and
 // set its background to our AnimationDrawable XML resource.
 ImageView img = (ImageView)findViewById(R.id.spinning_wheel_image);
 img.setBackgroundResource(R.drawable.spin_animation);
 // Get the background, which has been compiled to an AnimationDrawable object.
 AnimationDrawable frameAnimation = (AnimationDrawable) img.getBackground();
 // Start the animation (looped playback by default).
 frameAnimation.start();
https://github.com/FlyRecker/FlyMukeRefreshListView GitHub开源项目:仿慕课下拉刷新
RefreshListView.java
package com.example.openrefreshlistview;
import android.annotation.SuppressLint;
import android.content.Context;
import android.graphics.drawable.AnimationDrawable;
import android.util.AttributeSet;
import android.util.Log;
import android.view.LayoutInflater;
import android.view.MotionEvent;
import android.view.View;
import android.view.ViewGroup;
import android.widget.AbsListView;
import android.widget.ImageView;
import android.widget.ListView;
import android.widget.TextView;
 * Created by recker on 16/5/13.
public class RefreshListView extends ListView implements AbsListView.OnScrollListener {
    private final int NONE = 0;//正常状态
    private final int PULL = 1;//提示下拉刷新状态
    private final int RELESE = 2;//提示释放状态
    private final int REFLASHING = 3;//正在刷新状态
    private final int RATIO = 3;//比值
    private View headerView;//顶部刷新视图
    private int headerViewHeight;//顶部布局文件的高度
    private int firstVisibleItem;//当前第一个可见的item的位置
    private boolean isEnd;//是否结束刷新
    private boolean isRefreable;//是否可以刷新
    private boolean isRemark;//标记,当前是在ListView是否是在第一个
    private float startY;
    private float offsetY;
    private int state;//当前的状态
    private TextView tip;
    private ImageView img;
    private AnimationDrawable drawableAnim;
    public RefreshListView(Context context) {
        super(context);
        init(context);
    public RefreshListView(Context context, AttributeSet attrs) {
        super(context, attrs);
        init(context);
    public RefreshListView(Context context, AttributeSet attrs, int defStyleAttr) {
        super(context, attrs, defStyleAttr);
        init(context);
    @SuppressLint("NewApi")
	private void init(Context context) {
        headerView = LayoutInflater.from(context).inflate(R.layout.header_layout, null);
  /*void android.widget.ListView.addHeaderView(View v)
Add a fixed view to appear at the top of the list.
        addHeaderView(headerView);
        measureView(headerView);
        headerViewHeight = headerView.getMeasuredHeight();
        topPadding(-headerViewHeight);
        //添加动画
        tip = (TextView) headerView.findViewById(R.id.tip);
        img = (ImageView) headerView.findViewById(R.id.img);
        img.setBackgroundResource(R.drawable.c);
        drawableAnim = (AnimationDrawable) img.getBackground();
        //关闭view的OverScroll
        setOverScrollMode(OVER_SCROLL_NEVER);
        setOnScrollListener(this);
        state = NONE;
        isEnd = true;
        isRefreable = false;
     * 通知父布局,占用的宽,高
     * @param view
    private void measureView(View view) {
        ViewGroup.LayoutParams p = view.getLayoutParams();
        if (p == null) {
            p = new ViewGroup.LayoutParams(ViewGroup.LayoutParams.MATCH_PARENT,
                    ViewGroup.LayoutParams.WRAP_CONTENT);
        int width = ViewGroup.getChildMeasureSpec(0, 0, p.width);
        int height;
        int tempHeight = p.height;
        if (tempHeight > 0) {
            height = MeasureSpec.makeMeasureSpec(tempHeight, MeasureSpec.EXACTLY);
        } else {
            height = MeasureSpec.makeMeasureSpec(0, MeasureSpec.UNSPECIFIED);
        view.measure(width, height);
    private void topPadding(int topPadding) {
        headerView.setPadding(headerView.getPaddingLeft(), topPadding,
                headerView.getPaddingRight(), headerView.getPaddingBottom());
        headerView.invalidate();
    @Override
    public void onScrollStateChanged(AbsListView absListView, int scrollState) {
    @Override
    public void onScroll(AbsListView absListView, int firstVisibleItem,
                         int visibleItemCount, int totalItemCount) {
        this.firstVisibleItem = firstVisibleItem;
    @Override
    public boolean onTouchEvent(MotionEvent ev) {
        if (isEnd) {//如果现在时结束的状态,即刷新完毕了,可以再次刷新了,在refreshComplete中设置
            if (isRefreable) {//如果现在是可刷新状态   在setOnRefreshListener中设置为true
                switch (ev.getAction()) {
                    case MotionEvent.ACTION_DOWN:
                        if (firstVisibleItem == 0 && !isRemark) {
                            isRemark = true;
                            startY = ev.getY();
                        break;
                    case MotionEvent.ACTION_MOVE:
                        onMove(ev);
                        break;
                    case MotionEvent.ACTION_UP:
                        if (state == RELESE) {
                            state = REFLASHING;
                            //加载最新数据
                            refreshViewByState();
                            onRefreshListener.onRefresh();
                        } else if (state == PULL) {
                            state = NONE;
                            setSelection(0);
                        isRemark = false;
                        break;
        return super.onTouchEvent(ev);
     * 判断移动过程操作
     * @param ev
    private void onMove(MotionEvent ev) {
        //再次得到y坐标,用来和startY相减来计算offsetY位移值
        float tempY = ev.getY();
        //再起判断一下是否为listview顶部并且没有记录y坐标
            isRemark = true;
            startY = tempY;
        if (state != REFLASHING && isRemark) {
            //计算y的偏移量
            offsetY = tempY - startY;
            //计算当前滑动的高度
            float currentHeight = (-headerViewHeight+offsetY/3);
            //如果当前的状态是释放刷新,并且已经记录y坐标
            if (state == RELESE && isRemark) {
                setSelection(0);
                //如果当前滑动的距离小于headerView的总高度
                if (-headerViewHeight+offsetY/RATIO<0) {
                    //状态改为下拉刷新
                    state = PULL;
                } else if (offsetY =0) {
                    //状态改为释放刷新
                    state = RELESE;
                    //将状态改为释放刷新状态
                    state = PULL;
            //如果为下拉刷新状态
                topPadding((int)(-headerViewHeight+offsetY/RATIO));
            //如果为释放刷新状态
     * 根据当前状态,改变界面显示
    private void refreshViewByState() {
        switch (state) {
            case NONE:
                drawableAnim.stop();
                break;
            case PULL:
                tip.setText("下拉刷新");
                break;
            case RELESE:
                tip.setText("释放刷新");
                break;
            case REFLASHING:
                drawableAnim.start();
                tip.setText("正在刷新");
                break;
     * 获取完数据
    public void refreshComplete() {
        isEnd = true;
        state = NONE;
    private OnRefreshListener onRefreshListener;
    public void setOnRefreshListener(OnRefreshListener listener) {
        this.onRefreshListener = listener;
        isRefreable = true;
    public interface OnRefreshListener {
        void onRefresh();
    private void debug(String str) {
        Log.d(RefreshListView.class.getSimpleName(), str);
header_layout.xml
activity_main.xml
MainActivity.java
import android.os.Handler;
//import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.support.v7.app.ActionBarActivity;
import android.widget.ArrayAdapter;
import java.util.ArrayList;
import java.util.Arrays;
import java.util.List;
public class MainActivity extends ActionBarActivity
        implements RefreshListView.OnRefreshListener  {
    private RefreshListView mListView;
    private ListmDatas;
    private ArrayAdaptermAdapter;
    private final static int REFRESH_COMPLETE = 0;
    private Handler mHandler = new Handler(){
        public void handleMessage(android.os.Message msg) {
            switch (msg.what) {
                case REFRESH_COMPLETE:
                    mListView.refreshComplete();
                    mAdapter.notifyDataSetChanged();
                    break;
                default:
                    break;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mListView = (RefreshListView) findViewById(R.id.listview);
        String[] data = new String[]{"a","b","c","d",
                "e","f","g","h","i",
                "j","k","l","m","n","o","p","q","r","s"};
        mDatas = new ArrayList(Arrays.asList(data));
        /*Open Declaration android.widget.ArrayAdapter.ArrayAdapter(Context context,
          int textViewResourceId, Listobjects)*/
        mAdapter = new ArrayAdapter(this, android.R.layout.simple_list_item_1,mDatas);
        mListView.setAdapter(mAdapter);
        mListView.setOnRefreshListener(this);
    @Override
    public void onRefresh() {
        new Thread(new Runnable() {
            @Override
            public void run() {
                try {
                    Thread.sleep(3000);
                    mDatas.add(0, "new data");
                    mHandler.sendEmptyMessage(REFRESH_COMPLETE);
                } catch (InterruptedException e) {
                    e.printStackTrace();
        }).start();
