字符设备驱动-LED驱动
a.看原理图-确定引脚
b.看2440数据手册
c.写代码
写代码注意:裸机代码用的是物理地址PA,驱动代码用的是虚拟地址VA<虚拟地址需要用ioremap函数映射>
驱动程序first_drv.c
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static struct class *firstdrv_class;
static struct class_device *firstdrv_class_dev;
/*第一步 根据原理图定义操作寄存器*/
volatile unsigned long *gpfcon = NULL;
volatile unsigned long *gpfdat = NULL;
static int first_drv_open(struct inode *inode,struct file *file)
printk("first_drv_openn");
//配置GPF456为输出引脚
/*第四步 配置Open函数 将引脚配置为输出模式*/
*gpfcon &= ~((0x3<<4*2) | (0x3<<5*2) | (0x3<<6*2));
*gpfcon |= ((1<<4*2) | (1<<5*2) | (1<<6*2));
return 0;
static ssize_t first_drv_write(struct file *file,const char __user *buf, size_t count,loff_t *ppos)
int val;
printk("first_drv_writen");
/*第五步 将用户空间的操作内容传给内核*/
copy_from_user(&val,buf,count);
if(1 == val)
*gpfdat &= ~((1<<4) | (1<<5) | (1<<6));
else
*gpfdat |= ((1<<4) | (1<<5) | (1<<6));
return 0;
static struct file_operations first_drv_fops = {
.owner = THIS_MODULE, /* 这是一个宏,推向编译模块时自动创建的__this_module变量 */
.open = first_drv_open,
.write = first_drv_write,
int major;
static int first_drv_init(void)
major = register_chrdev(0,"first_drv",&first_drv_fops);// 注册,告诉内核
//printk("first_drv_initn");
firstdrv_class = class_create(THIS_MODULE, "firstdrv");
firstdrv_class_dev = class_device_create(firstdrv_class, NULL, MKDEV(major, 0), NULL, "xyz"); /* /dev/xyz */
/*第二步 根据数据手册 入口函数映射VA*/
gpfcon = (volatile unsigned long *)ioremap(0x56000050,16);
gpfdat = gpfcon + 1;
return 0;
static void first_drv_exit(void)
unregister_chrdev(major,"first_drv");//卸载
class_device_unregister(firstdrv_class_dev);
class_destroy(firstdrv_class);
/*第三步 出口函数去掉映射*/
iounmap(gpfcon);
module_init(first_drv_init);
module_exit(first_drv_exit);
MODULE_LICENSE("GPL");
驱动测试程序firstdrvtest.c
#include
#include
#include
#include
/* firstdrvtest on
* firstdrvtest off
int main(int argc, char **argv)
int fd;
int val = 1;
fd = open("/dev/xyz",O_RDWR);
if(fd < 0)
printf("can't open!n");
if (argc != 2)
printf("Usage : n");
printf("%s n", argv[0] );
return 0;
if (strcmp(argv[1],"on") == 0)
val = 1 ;
else
val = 0 ;
write(fd,&val,4);
return 0;
测试:
①make
-编译驱动程序
②arm-linux-gcc -o firstdrvtest firstdrvtest.c
-编译驱动测试程序
③cp first_drv.ko /work/nfs_root/czg
-拷贝至nfs文件夹
④cp firstdrvtest /work/nfs_root/czg
-拷贝至nfs文件夹
⑤rmmod first_drv
-卸载先前驱动//cat proc/devices 查看
⑥insmod first_drv.ko
-加载驱动
⑦./firstdrvtest
-测试驱动
(1)根据修改传入参数,执行多种操作
(2)通过此设备号的不同来实现,执行不同的硬件操作
驱动程序myleds.c
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define DEVICE_NAME "leds" /* 加载模式后,执行”cat /proc/devices”命令看到的设备名称 */
#define LED_MAJOR 231 /* 主设备号 */
static struct class *leds_class;
static struct class_device *leds_class_devs[4];
/* bit0<=>D10, 0:亮, 1:灭
* bit1<=>D11, 0:亮, 1:灭
* bit2<=>D12, 0:亮, 1:灭
static char leds_status = 0x0;
static DECLARE_MUTEX(leds_lock); // 定义赋值
//static int minor;
static unsigned long gpio_va;
#define GPIO_OFT(x) ((x) - 0x56000000)
#define GPFCON (*(volatile unsigned long *)(gpio_va + GPIO_OFT(0x56000050)))
#define GPFDAT (*(volatile unsigned long *)(gpio_va + GPIO_OFT(0x56000054)))
/* 应用程序对设备文件/dev/leds执行open(...)时,
* 就会调用s3c24xx_leds_open函数
static int s3c24xx_leds_open(struct inode *inode, struct file *file)
int minor = MINOR(inode->i_rdev); //MINOR(inode->i_cdev);
switch(minor)
case 0: /* /dev/leds */
// 配置3引脚为输出
//s3c2410_gpio_cfgpin(S3C2410_GPF4, S3C2410_GPF4_OUTP);
GPFCON &= ~(0x3<<(4*2));
GPFCON |= (1<<(4*2));
//s3c2410_gpio_cfgpin(S3C2410_GPF5, S3C2410_GPF5_OUTP);
GPFCON &= ~(0x3<<(5*2));
GPFCON |= (1<<(5*2));
//s3c2410_gpio_cfgpin(S3C2410_GPF6, S3C2410_GPF6_OUTP);
GPFCON &= ~(0x3<<(6*2));
GPFCON |= (1<<(6*2));
// 都输出0
//s3c2410_gpio_setpin(S3C2410_GPF4, 0);
GPFDAT &= ~(1<<4);
//s3c2410_gpio_setpin(S3C2410_GPF5, 0);
GPFDAT &= ~(1<<5);
//s3c2410_gpio_setpin(S3C2410_GPF6, 0);
GPFDAT &= ~(1<<6);
down(&leds_lock);
leds_status = 0x0;
up(&leds_lock);
break;
case 1: /* /dev/led1 */
down(&leds_lock);
leds_status &= ~(1<<0);
up(&leds_lock);
break;
case 2: /* /dev/led2 */
leds_status &= ~(1<<1);
break;
case 3: /* /dev/led3 */
down(&leds_lock);
leds_status &= ~(1<<2);
up(&leds_lock);
break;
return 0;
static int s3c24xx_leds_read(struct file *filp, char __user *buff,
size_t count, loff_t *offp)
int minor = MINOR(filp->f_dentry->d_inode->i_rdev);
char val;
switch (minor)
copy_to_user(buff, (const void *)&leds_status, 1);
break;
down(&leds_lock);
val = leds_status & 0x1;
up(&leds_lock);
copy_to_user(buff, (const void *)&val, 1);
break;
down(&leds_lock);
val = (leds_status>>1) & 0x1;
up(&leds_lock);
break;
down(&leds_lock);
val = (leds_status>>2) & 0x1;
up(&leds_lock);
break;
return 1;
static ssize_t s3c24xx_leds_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos)
//int minor = MINOR(inode->i_rdev); //MINOR(inode->i_cdev);
int minor = MINOR(file->f_dentry->d_inode->i_rdev);
char val;
copy_from_user(&val, buf, 1);
switch (minor)
s3c2410_gpio_setpin(S3C2410_GPF4, (val & 0x1));
s3c2410_gpio_setpin(S3C2410_GPF5, (val & 0x1));
s3c2410_gpio_setpin(S3C2410_GPF6, (val & 0x1));
down(&leds_lock);
leds_status = val;
up(&leds_lock);
break;
s3c2410_gpio_setpin(S3C2410_GPF4, val);
if (val == 0)
down(&leds_lock);
up(&leds_lock);
else
down(&leds_lock);
leds_status |= (1<<0);
up(&leds_lock);
break;
s3c2410_gpio_setpin(S3C2410_GPF5, val);
if (val == 0)
down(&leds_lock);
up(&leds_lock);
else
down(&leds_lock);
leds_status |= (1<<1);
up(&leds_lock);
break;
s3c2410_gpio_setpin(S3C2410_GPF6, val);
if (val == 0)
down(&leds_lock);
up(&leds_lock);
else
down(&leds_lock);
leds_status |= (1<<2);
up(&leds_lock);
break;
return 1;
/* 这个结构是字符设备驱动程序的核心
* 当应用程序操作设备文件时所调用的open、read、write等函数,
* 最终会调用这个结构中指定的对应函数
static struct file_operations s3c24xx_leds_fops = {
.open = s3c24xx_leds_open,
.read = s3c24xx_leds_read,
.write = s3c24xx_leds_write,
* 执行insmod命令时就会调用这个函数
static int __init s3c24xx_leds_init(void)
//static int __init init_module(void)
int ret;
int minor = 0;
gpio_va = ioremap(0x56000000, 0x100000);
if (!gpio_va) {
return -EIO;
/* 注册字符设备
* 参数为主设备号、设备名字、file_operations结构;
* 这样,主设备号就和具体的file_operations结构联系起来了,
* 操作主设备为LED_MAJOR的设备文件时,就会调用s3c24xx_leds_fops中的相关成员函数
* LED_MAJOR可以设为0,表示由内核自动分配主设备号
ret = register_chrdev(LED_MAJOR, DEVICE_NAME, &s3c24xx_leds_fops);
if (ret < 0) {
printk(DEVICE_NAME " can't register major numbern");
return ret;
leds_class = class_create(THIS_MODULE, "leds");
if (IS_ERR(leds_class))
return PTR_ERR(leds_class);
leds_class_devs[0] = class_device_create(leds_class, NULL, MKDEV(LED_MAJOR, 0), NULL, "leds"); /* /dev/leds */
for (minor = 1; minor < 4; minor++) /* /dev/led1,2,3 */
leds_class_devs[minor] = class_device_create(leds_class, NULL, MKDEV(LED_MAJOR, minor), NULL, "led%d", minor);
if (unlikely(IS_ERR(leds_class_devs[minor])))
return PTR_ERR(leds_class_devs[minor]);
printk(DEVICE_NAME " initializedn");
return 0;
* 执行rmmod命令时就会调用这个函数
static void __exit s3c24xx_leds_exit(void)
int minor;
/* 卸载驱动程序 */
unregister_chrdev(LED_MAJOR, DEVICE_NAME);
for (minor = 0; minor < 4; minor++)
class_device_unregister(leds_class_devs[minor]);
class_destroy(leds_class);
iounmap(gpio_va);
/* 这两行指定驱动程序的初始化函数和卸载函数 */
module_init(s3c24xx_leds_init);
module_exit(s3c24xx_leds_exit);
/* 描述驱动程序的一些信息,不是必须的 */
MODULE_AUTHOR("http://www.100ask.net");
MODULE_VERSION("0.1.0");
MODULE_DESCRIPTION("S3C2410/S3C2440 LED Driver");
驱动测试程序ledtest.c
#include
#include
#include
#include
* ledtest
void print_usage(char *file)
printf("Usage:n");
printf("%s n",file);
printf("eg. n");
printf("%s /dev/leds onn", file);
printf("%s /dev/leds offn", file);
printf("%s /dev/led1 onn", file);
printf("%s /dev/led1 offn", file);
int fd;
char* filename;
char val;
if (argc != 3)
print_usage(argv[0]);
return 0;
filename = argv[1];
fd = open(filename, O_RDWR);
if (fd < 0)
printf("error, can't open %sn", filename);
return 0;
if (!strcmp("on", argv[2]))
// 亮灯
val = 0;
write(fd, &val, 1);
else if (!strcmp("off", argv[2]))
// 灭灯
val = 1;
write(fd, &val, 1);
else
return 0;
return 0;
Makefile
KERN_DIR = /work/system/linux-2.6.22.6
all:
make -C $(KERN_DIR) M=`pwd` modules
clean:
make -C $(KERN_DIR) M=`pwd` modules clean
rm -rf modules.order
obj-m += myleds.o
