BaseAdapter + Gallery
galleryAdapter.java
package com.example.administrator.gallery; import android.content.Context; import android.view.View; import android.view.ViewGroup; import android.widget.BaseAdapter; import android.widget.Gallery; import android.widget.ImageView; /** * Created by Administrator on 2015/7/23. */ public class galleryAdapter extends BaseAdapter{ private int[] resId; private Context mContext; public galleryAdapter(int[] resId,Context mContext) { this.resId = resId; this.mContext = mContext; } @Override public int getCount() { // return resId.length; return Integer.MAX_VALUE; //让gallery循环,所以设置为最大数 } @Override public Object getItem(int position) { return resId[position]; } @Override public long getItemId(int position) { return position; } @Override public View getView(int position, View convertView, ViewGroup parent) { ImageView img = new ImageView(mContext); // img.setBackgroundResource(resId[position]); img.setBackgroundResource(resId[position % resId.length]); //循环 //设置缩放 // img.setLayoutParams(new Gallery.LayoutParams(300,400)); // img.setScaleType(ImageView.ScaleType.FIT_XY); return img; } }
MainActivity.java
package com.example.administrator.gallery; import android.support.v7.app.ActionBarActivity; import android.os.Bundle; import android.view.Menu; import android.view.MenuItem; import android.view.View; import android.view.animation.Animation; import android.view.animation.AnimationUtils; import android.widget.AdapterView; import android.widget.Gallery; import android.widget.ImageSwitcher; import android.widget.ImageView; import android.widget.ViewSwitcher; public class MainActivity extends ActionBarActivity implements ViewSwitcher.ViewFactory{ private Gallery gallery; private ImageSwitcher switcher; private int[] resId = new int[]{R.drawable.item1,R.drawable.item2,R.drawable.item3,R.drawable.item4,R.drawable.item5,R.drawable.item6,R.drawable.item7,R.drawable.item8,R.drawable.item9,R.drawable.item10,R.drawable.item11,R.drawable.item12}; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); gallery = (Gallery)findViewById(R.id.gallery); switcher = (ImageSwitcher)findViewById(R.id.switcher); galleryAdapter adapter = new galleryAdapter(resId,this); gallery.setAdapter(adapter); gallery.setOnItemSelectedListener(new Gallery.OnItemSelectedListener() { @Override public void onItemSelected(AdapterView parent, View view, int position, long id) { // img.setBackgroundResource(resId[position % resId.length]); //循环 switcher.setBackgroundResource(resId[position % resId.length]); } @Override public void onNothingSelected(AdapterView parent) { } }); //ImageSwitcher加载工厂 switcher.setFactory(this); //动画效果 switcher.setInAnimation(AnimationUtils.loadAnimation(this,android.R.anim.fade_in)); switcher.setOutAnimation(AnimationUtils.loadAnimation(this,android.R.anim.fade_out)); } @Override public View makeView() { ImageView img = new ImageView(this); img.setScaleType(ImageView.ScaleType.FIT_CENTER); return img; } }
